The Mitsubishi TV information : Model # WS 65311, Serial # 120372. I was setting up the Direct TV remote and the power button, volume and channels worked perfectly. I attempting to set up the Direct TV input button and the TV went to White noise. I do not have a Remote for the Mitsubishi TV, and the buttons on the TV do not work. I read your blogs to reset the TV to factory defaults unplug for 4 hours, now I can not turn the TV on. I can not control the tv at all with the Direct TV remote. Gerri Navarro (gerania25@yahoo.com)
  • gerania25 Apr 26, 2010
    The television is not working at all now. I can not turn it on with the buttons on the television. The Direct TV remote is not controlling the TV either. The Direct TV remote only works with the direct tv box.
    After I unplugged the Televesion for four hours, it does not respond to anything.
    Thank you.
    I just finished reading the manual that I downloaded from on-line.
    I found out how to unlock the front panel controls.
    I HELD THE MENU BUTTON FOR 8 SECONDS, THEN I WAS ABLE TO CONTROL THE TV WITH THE FRONT BUTTONS.
    THANK YOU VERY MUCH.
    GN
  • 5,138 Answers
Mats Electronics has remotes for this TV 1-800-628-1118 $3.95 and up
Encompass Parts Distribution go to this website and type in your model number it will List Parts/ Prices available. In the mean time go to the Dollar store they will have a 4 in 1 RCA remote with code book for $6.00
I have used this remote on many different TVs it works almost all TVs.
The reset button should be on front of TV under a panel door .I also know that Mitisubishi has poor solder connections on IF and Tuner boards you may want to resolder theses boards.Your DirectTv book in the back should list TV codes for your TV to program their handunits to control your TV,if you cannot find your book then Call Them, they should be able to talk you throught in programing your TV to their hand unit.
Posted on Apr 26, 2010
    Genius:
  • 1,043 Answers
The code that you had originally chosen to operate your TV should still work. If none of the Mitsubishi codes will work your TV then you will have to do a code scan. Essentially you will have to scan all of the TV codes that are in the Direct TV remote until you find the one that will operate your TV. These are the steps to do it:
1. Turn on the TV.
2. Slide the MODE switch to the TV position.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by the 1 key for TV.
5. Press PWR, and the other functions you want to use.
6. Point the remote at the TV and press CHAN+. Repeatedly press CHAN+ until the TV turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
To make a note of the code that the remote is using do the following:
1. Slide the MODE switch to TV.
2. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
3. Enter 9-9-0. (The green light under the selected switch position flashes twice.)
4. To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down.
5. Repeat step 4 four more times for the remaining digits; i.e., press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.
As the remote did work with your TV before the Input mishap you should be able to find a working code. If for some reason you are unable to find a working code then there is the possibility that either the remote itself or the TV chose that time to stop working. The easiest way to identify if this is the case is to have Direct TV exchange your remote for you. If you are able to program in the code that originally worked for you then your original remote stopped working correctly. If however you are unable to either scan a code or input the original one then you have an issue with your TV.
Posted on Apr 25, 2010
65 inch tv turned on and volumn went all the way high remote does not work also can't change devices
Make sure the button either on the remote is not depressed all the time or on the front of the television!! This will be the main reason that the volume is going to MAX all the time. Usually if you press any button on the tv or remote and hold it down such as you mentioned, it will lockup the microprocessor to that function specificly and it won't take anyother instructions until you unstick the button or get it to stop going all the way UP!
Try that and let me know if i solved your problem.. God luck from the TV GURU
Jun 09, 2010 | Mitsubishi WS-65311 65" Rear Projection...
Mitsubishi 55" rear projection TV, wouldn't turn off
um . that model doesn't have a reset button . but if no lights on front of the set even blink when you press the power button on the front or on the remote .then suspect front panel buttons ,with that model.
Sep 29, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi Model # WS 65311 HD 1080 turns on then shuts off.
try holding in the menu and input/device buttons on the front of the set both together and see if it blinks a series of blinks, pause briefly then blinks a second series of blinks, let me know what the blinks were sush as 22 or 24
Mar 12, 2009 | Mitsubishi WS-65311 65" Rear Projection...
Image outside of bounds of television.
There should be a format button on the remote you can hit. This should cycle thru all the "formats" that the set can do. 16x9, 4x3, wide mode, Full mode, stretched mode, etc.. Let me know if that helps you.. Happy holidays... Jay
Dec 08, 2008 | Mitsubishi WS-65311 65" Rear Projection...
Mitsubishi 1080 series, ws-65311 model
Same problem.. Checked the fuses but they're fine no reset switch to be found.
Sep 07, 2008 | Mitsubishi WS-65311 65" Rear Projection...
Mitsubishi WS-65611 power and volume problems
when it shuts down Try pushing the input and menu buttons together on the set it self and hold them both in for 8 seconds.and see if the LED blinks a diagnostic code.
Mar 29, 2008 | Mitsubishi WS-65611 65" Rear Projection...
WS-55908 remote control
Take out the batteries or simply reprogram the remote by using the manual search function on the remote. There is probably a couple of different settings in the remote for this type of TV set, Good Luck
Jul 02, 2007 | Mitsubishi WS-55908 55" Rear Projection...
Televison & Video Logo
156 people viewed this question
Top Televison & Video Experts
