Question about 321studios DVD X Copy Platinum (200000) for PC
I need a drive for DVD X Copy Platinum for my PC. I transferred my program from my old computer to my new computer, but it didn't transfer the driver. What do I do?
    Brigadier General:
  • 10,406 Answers
Login to: http://www.dvdxcopy.com
with your E-mail ID & password,
and see if you can download the license-key and a copy of the software.
Posted on Apr 25, 2010
Just got new HP laptop and i'd like to transfer photo's and some files from my old HP desk top computer. What do I need to do this?
If the old computer still works, see the following. Otherwise look for the * for a solution further below. If the old desktop has Windows XP SP3 or newer, you can use the easy transfer wizard. It is included in Windows 7.
If the old desktop has a network connection, you can use an ethernet switch to create a network to share files. Once both computers recognize the switch, set up a network. If you have Windows 7 on one computer and do not have it on the other, do not use the Homegroup network. This may come up automatically; otherwise, use the Network Control Panel and add a network. Start the Easy Transfer Wizard and set this computer as the new computer. There may be an option to get the Transfer Wizard to copy and install to the old computer. Note the code for the Easy Transfer Wizard. Then install the Windows Easy Transfer Wizard on the old computer and launch it. Set this computer as the old computer. Use the code given in on the first computer to synch the transfer. Go through the settings to select the files to transfer and then start the transfer. Prepare to wait a while for the transfer.
If you can't use the Easy Transfer Wizard, set the hard drive on one computer to Share (click Computer (My Computer) and right click on the hard drive and select Properties. Then choose the Sharing tab. Enable Sharing by clicking the Share button.) On the other computer, map to a network drive and locate the Shared drive. Drag and drop the files to the new computer.
If you already have a network connection to a cable or DSL router, you will be asked about "New network found" and to define it. Make sure to make it the home network on both computers. (If you were directly connected to a cable or DSL modem, then you will again get this question. Note the switch will not let your computers talk to the outside network without a router though.)
(Alternatively, use a cross-over ethernet cable with the direct cable networking option.)
Other options: use the Microsoft Easy Transfer Wizard to put the photos and files on a DVD, external hard drive or flash drive with sufficient capacity. You may need to download and install this program to the old computer. For the optical drive option, you need a DVD-RW drive on the desktop and a DVD reader (minimum) on the laptop. (You can use an external optical drive, if you have one.) Another option is a USB file transfer device. Some of these come with the Easy Transfer Wizard on their install disc.
*If the old computer will not turn on, take the hard drive out of the computer and use a USB to IDE/SATA adapter. Follow the directions for the device and attach it to a USB port on the laptop. See if the drive mounts (is listed when you open the Computer File Explorer). Then drag and drop the files from one drive to another.
Note you may need to change the owner of the files on the new computer. (This doesn't apply with the Easy Transfer Wizard if the old user is made equivalent to the new user in the setup of the wizard.) To change the owner, right click on the file in the File Explorer and choose the Security tab. Select the Advanced settings.
I hope this helps.
Jun 30, 2012 | detto intellimover usb data migration kit...
How do I transfer files from old computer to new
You can't transfer programs, programs have to be reinstalled.
You can copy things like your My Documents Folder, My Pictures, My Videos, and Favorites to a usb flash drive or an external drive then put the drive into the usb port of the new computer and copy them to the appropriate folders (Documents, Pictures, Music, Videos, etc).
Apr 07, 2012 | Acer Aspire 5050 5430 Laptop
Can't transfer my email files from old computer to new computer
Good Day!
To transfer files from an old computer you can use USB or flash drives, copy the files from your Old Computer to Flash drive, after copying---attach the flash drive to your new computer then copy the files and save it. This is the easiest way to transfer files.
Other way of transferring;
-You can also transfer files by Burning your files into a CD/DVD and copy it to your new computer.
-Get your hard disk from the old computer and attached it to your new computer
-Or connect/network your two computers.
I recommend USB or Flash drives, the simplest and easy way.
Hope I was able to help.
Jul 16, 2010 | Microsoft Windows XP Professional for PC
Transfer info from this computer to my new comp. things like Pictures Music.
Copy all your data from the old computer onto a blank CD, blank DVD, or onto a USB flash drive, or external hard drive. Then copy it to the new computer.
When both computers are in the same location, you can use an Ethernet cable to transfer information between machines. If you don’t have a hub, router, or switch, look for a crossover cable to complete the process.
Jun 23, 2010 | Dell OptiPlex GX270 PC Desktop
Flash drive transfer
yep ... just use thew copy feature ... not cut
May 02, 2010 | Computers & Internet
I used PC Relocator to transfer items on my old computer to a new computer. It worked great for files and settings, but didn't transfer programs. Any suggestions? Thanks.
Most programs such as this ONLY copy/transfer the files and setting. It doesn't "Do" the programs, you have to back those up, some other way. Usually however "Programs" are to be re-installed anew, on the "New" PC, as generally the "New" PC is different to the "Old" and maybe the "Old" settings would not "Run" on the new system.
Jan 21, 2010 | Eisenworld Alohabob PC Relocator Ultra...
How to get information from an old XP computer to a new Windows 7 computer
Copy the files you want from the old PC to some kind of removable media, i.e. CD, flash drive, etc. and copy them to the new one from the media you have chosen.
Dec 31, 2009 | Gateway ONE GZ7108 All-in-One Desktop PC
Need to know how to transfer programs and files from old to new PC
There are three sets of items that you need to transfer.
It would be best to use an external USB drive and keep the data on the drive as a backup.
1. Settings (Internet favorites, desktop settings, cookies, address book, etc.)
2. Data (My Documents, and multimedia content)
3. Programs
It would be easy if the old computer was also a Dell; however, you can't simply "copy" to the new computer.
#1. Settings: There is a built-in utility called "Files and Settings Transfer Wizard". [Start] [All Programs] [Accessories] [System Tools] [Files and Settings Transfer Wizard]
#2. The transfer wizard has an option to copy "settings only", "Data Only", Settings and Data". Transfer only the settings and then transfer the data. It will go much smoother.
#3. Some programs are already on your new computer; however, unless the old computer was also a Dell, you will have to re-install most or all of your programs like MS Office, Printers, Scanners, Camera and Video applications, etc.
If you need more detail, please post a comment... Thanks .
Oct 08, 2009 | Dell Dimension 4600 PC Desktop
Studio 321 DVD X Copy Platinum
Make a copy of the old computer's register files of the program as a backup.
Aug 07, 2008 | 321studios DVD X Copy Platinum (200000)...
321 Studios DVD X Copy Paltinum
You would need to call customer support for the vendor and get that information.
Jul 26, 2008 | 321studios DVD X Copy Platinum (200000)...
321studios DVD X Copy Platinum (200000) for PC Logo
225 people viewed this question
Top 321studios Computers & Internet Experts
SHIVAJI YADAV
SHIVAJI YADAV
Matthew Spark
Matthew Spark
Darial Jr Lasaria
Darial Jr Lasaria
Are you a 321studios Computer and Internet Expert? Answer questions, earn points and help others
