What is a 220v-60hz-single phase,how many wires
  • co346 Apr 25, 2010
    I recently bought a mini-split air cond the 3 wires cumming out of the machine are blue ,brown and yellow green and its a american machine
    yes
  • 8,197 Answers
It will be 3 wires. You will have 2 hot lines and one neutral line. It can also be 4 wires if you add the ground.
The wire size for a 60hz is usually 10 gage wire.
220v means that you have 2 110V lines to one outlet to make 220V.
The 60hz means 60 times per second
Posted on Apr 25, 2010
  • Jyackle5
    Jyackle5 Apr 25, 2010
    The blue and brown are the hot and the yellow/green is the ground
220v 1 phase wiring
220v 1 phase wiring is a EU standard.
Sep 30, 2015 | Miller CST 280 Stick/TIG Welding Power...
I have Hobart D300 mixer which operates at 220V, 3phase supply and whereas the facility has 208V, single phase supply. Is there any recommended phase converters available for this product. Thanks
Hi Bill
I may be wrong here......
But I've been around Electricity for a long time.
Have Never seen a device that does phase conversion.
A Building site or home will either have Three Phase or Single Phase Power Available
BUT...A portable (Hired) generator could be "three phase" and you could use any one of those phases individually or all three phases.
I have 3 Phase supply to my house!
But I use 230 volt Single Phase for appliances.
My Bore Pump uses a 3 Phase Motor,
(so with a voltmeter it would read about 440 vAC to the pump motor).
Some Further Info:
A GENERATOR is basically a motor used the opposite way. Rotate a motor and it Generates.
The Phases refer to the THREE Windings in the supplying generator in your suburb.
A Large Magnet passes each winding in sequence giving you the three ripples in the supply.
Our houses can choose to have 1 Phase or Three Phases from the street when you set up your electric supply.
So... to confirm, look at the wires on the supply poles to the premises. Usually three in our area (Oz)
Most people are not aware that a car Alternator is actually three phase. The Rotor is the magnet that rotates.
The only difference with an Alternator is that each "Phase" is connected to 2 Diodes (6 total) to convert the three phase to DC to charge the vehicle.
The Regulator controls the voltage to the Rotor, thereby controlling the output.
So.... An Alternator could in theory supply 3 Phase in a mobile generator. Custom Made. Constant speed would determine the frequency of 50Hz or 60Hz.
Not sure what country you are in
Hope this Helps or gives you food for thought!
Three phase electric power
Jul 08, 2015 | Hobart Food Mixers
Wire schematic
If the welder is single phase 110v use a dedicated 20A standard household circuit. If 220v single phase use a 50A RV or weld receptacle connected to a 50A dual breaker with common trip. Make sure the breaker is the same brand as your panel. If the welder is 3-phase connect the wires B-O-Y (Brown Orange Yellow) at the breaker (3 phase 50A) and see if a color code match can be applied at the welder, although the only issue is whether the wire feed will run forward or reversed. If the wire feed is reversed then move any two wires of the B-O-Y set to change the rotation.
Aug 25, 2014 | Welding Tools
Electric Phases for Hobart Oven
you must understand this : your electric oven must be indicate if it is a single phase( use 3 wires for 230 2 hot wires + 1 Neutral see the diagram like dryer? you must sure about this. Normally any appliance for home are single phase NOT 3 phase.
2) If you electric oven, say 3 PHASES( use 4 WIRES, 3 hot wires+1 Neutral wires) this for industrial application +comercial 270266c5-a0ad-44dc-9f40-e963255d47f5.jpgNOT for home
However if you system is 3 phase you must need to install 3phase transformer.ba1c9d4d-85e3-4744-8ce5-2f25c6e34ad3.jpg
Jul 18, 2013 | Hobart HEC501-240V Electric Oven
I have a brand new IR compressor model 2475N7.5 with a 7.5 hp 460v 3 ph motor. is it possible to convert it to a single phase power supply? or should i just exchange it? ... I ordered it thru Northern Tool...
When you google home made 3 phase converters, you will find many ways to make use of 220v single phase instead, however you are limited as to the hp that the motor will produce. If you spin the motor first then apply 220v, the motor will continue to turn at much reduced hp. You need full power to turn a type 30 pump depending on pulley combination/ setup. Best to return the unit and get one that will run on 220v single phase. It will most likely consume more power to do the same work however it would cost a great deal to install 3 phase. Most likely not even available at all. Many years ago, I worked at Sears and happened to see an electrician coming down from roof access of building. He told me that sears had a 3 phase generator being turned by a 220v single phase motor to run an air conditioning unit. He said that it worked quite well. Does not sound cost effective.
Jan 08, 2011 | Ingersoll Rand - Rand Type - 30...
Changing from 480v 3 phase to 220v single phase need diagram on a Miller Dynasty DX tig welder Serial # KH577649 stock 903519-01-1
i have a old miller thunderbolt CC*AC/DC welder its wire single phase 480 can it be switched to 220 single phase
Dec 02, 2009 | Miller Welding Tools
I have a doerr electric motor, lr22132 single phase 220v, 3/4 HP with wires t2, t3, t4, t5, t6, t7, t8 and earth, how do i hook up, any help would be great, paul
i have a doerr electric motor, lr22132 single phase 220v, 3/4 HP with wires t2, t3, t4, t5, t6, t7, t8 and earth, how do i hook up, any help would be great,
Nov 20, 2009 | Kitchen Appliances - Others
Wiring a 220v single phase motor and capacitor
Black and white are usually power. an ohmmeter will confirm. Brown are for capacitors. There is almost always a diagram on the motor someplace. Eric
Jun 17, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
Converting from three phase to single phase
Do you want to convert 3 phase to single phase?What voltage do you currently have (220v 3phase)?
May 07, 2009 | Kitchen Appliances - Others
Heating & Cooling Logo
168 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
