Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer with Curved Shaft #P1500
Poulin trimmer te475 will run but dies. it boggs. if i let go of
Will run but dies. it boggs. if i let go of throttle it dies. i have adjusted throttle, does not help. someone posted somthing about a stone filter. if there is one how do i get to it to check it out. any ideas???
4 Suggested Answers
panilling9
  • 284 Answers
SOURCE: cant find refills for the te475
ordertree.com
part # 952711574
Posted on Jun 21, 2009
  • 64 Answers
SOURCE: i have a poulan pro trimmer, it wont stay running
First of all, YES. boggs is a word in my dictionary. Remove the muffler and carefully take it apart. Pay close attention as to how it comes apart because it is vary important it goes back the same way. you will probable find that it is clogged. If it is then remove the debree. If it isn't then you will have to adjust the fuel mixture screw. First start the trimmer, then let it run for a few minutes to warm up, then gently turn the screw a little bit at a time counter clockwise first, squeezing the throttle inbetween adjustments . If it starts to take off then fine tune it untile your happy. If it boggs worse then turn it clockwise.
But first check the muffler.
Good luck
Posted on Aug 05, 2009
rycgl
  • 1545 Answers
SOURCE: i have a weed eater
For a lighter weight machine with the smaller 25 or 26cc engine like yours, .085" line is sufficient. .065" line is for electric trimmers and .095" line is for trimmers with the larger 30 and 32cc engines.
Posted on Aug 14, 2011
I have a 350 poulan pro ordered a carb. installed new filter line and primer bulk. It will start and run as long as I have the choke on. As soon as I move the lever for the choke I boggs down. Gan anyone...
Hi dennis
Sounds like to me that you have a problem with the high speed circuit of the carb...could be some trash in the jet or the jet may be out of adjustment...try adjusting the jet and try to go to full throttle after your adjustment
Apr 14, 2013 | Poulan/Weed Eater No. Te475 952711797 17"...
Troy Bilt Trimmer Model TB25CS will not run.
I think you should take the carb off take it apart and clean everything with carb cleaner. Also check the pickup in the tank for a pluged screen
Sep 18, 2012 | Garden
What would be wrong with my trimmer if it idles good but wants to die when i try to accelerate
It either needs the L mixture screw adjusted (counterclockwise 1/8 to 1/4 of a turn) or the metering diaphragm inside the carb has become brittle and is not opening the needle valve to allow enough gas to flow into the H (High speed ) fuel circuit to allow it to run. Don't confuse the L mixture screw with the Idle speed screw. The idle speed screw has a Philips head and the L speed mixture screw has a small unconventional head that a normal screwdriver does NOT fit.
Aug 06, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Out the box.Cranks and runs on cold.when you give it full throttle and knock it off fast idel try to let it idel it die's.After u use it a few min. it die's and want start back till it cools.
This is a common problem out of the box for weedeater products. This simply needs a carb adjustment which is not something the consumer can do (requires a special tool), You will need to take this to a weedeater dealer near you to get it done, it's covered under the warranty.
Jul 21, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Feather lite trimmer only runs on half throttle and idle dies on full throttle. unit is new
When I bought a new poulan gas trimmer, I had the same problem. Solution was to return it and get another one. They come with problems, even new. Just keep returning them until you get one that works correctly. Mine works great, but like I said, had to return it and get one that was right.
Jul 01, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Engine idles, but when push throudle dies. Will not run fast.
It most likely needs a new air filter, if the filter is foam you can just clean it in gasoline.
If that doesn't fix it then you will need to remove and clean the carburetor. Its a pretty easy job. The carburetor sits in between the air filter box and the engine. Just pull of the couple bolts holding it all together and disconnect the throttle springs, remember or mark which one is which. Disconnect the fuel line ad it should come right off.
Get some carburetor cleaner from your local parts store and give the whole thing a good cleaning (take it apart as much as you can and clean every part). Then put it all back together and it should run like its new.
Jun 10, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I have a 2007 honda rebel and when you throttle it boggs down when i let up on the throttle it runs right it has backfired a couple of times and it now dies almost immediately after you start itany idea?
you probably just need to adjust your air fuel mixture and idle screws. try leaning out your mixture screw a little bit and then adjust your idle screw accordingly.
May 14, 2010 | Motorcycles
I have a poulan pro trimmer, it wont stay running
Good luck
Aug 05, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Echo trimmer won't start, gasoline flows out of exhaust
look at choke and air filter. ensure choke is operating and clean air filter.
May 24, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Poulan 25cc 2-Cycle Gas Powered String Trimmer with Curved Shaft #P1500 Logo
51 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
