Question about Linksys WPC54G Wireless-G Notebook Adapter V2.0 (WPC54C)
No lights coming on any more, can't reinstall as its not detected....
    Brigadier General:
  • 10,406 Answers
First, install the device-drivers.
Second, insert the device.
If it is not detected, repeat the above on another computer.
If it still is _NOT_ detected, then it is "dead", and must be replaced.
Posted on Apr 25, 2010
My tablet wont turn on
if the charge light comes on then the unit may need to be replaced. Try connecting it to a PC to see if it detects it. If it does, you may be able to reinstall the firmware.
Feb 12, 2014 | Coby Kyros 716829701508 Tablet PC
Have had check engine light on over a year first code p0442 changed gas cap' purge soleniod,charcoal canisterdidnt work changed leak detection pump now codes p0440 and p0499 are coming up any idea
you can look this obd2 trouble code table.
for p0440, you can try this:
Remove and reinstall the gas cap, clear the code, and drive for a day and see if the codes come back.
Inspect the EVAP system for cuts/holes in tubes/hoses
Inspect for damaged or disconnected hoses around the Evap purge solenoid
Check and/or replace the sensor
Check and/or replace the purge valve
Have a professional use a smoke machine to detect leaks
Aug 04, 2011 | Dodge Dakota Cars & Trucks
When i cut on my machine a black screen comes on sayin cannot boot insert cd and press enter
Could be your hard drive. Make sure all connections are good. You should have a 2 little lights on the front of system case, one is your hard drive activity light, it should be red. See when you turn it on if it blinks. Take the side of the case and listen if the hard drive is spinning when you start the computer up.
Nov 02, 2010 | Computers & Internet
Imac is not detecting my LaCie External Hard Drive
Do you have a CD disc software installer of your external hard drive (F.A. Porshe 160GB).? If you got it, you must reinstall it, so that your Imac can detect it. Otherwise, find it at the internet and download it.
The power failure could have damage some stored data about your External Hard Drive in your Imac. That's why, you have to reinstall it. Send us your e-mail comments for us.
Oct 17, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Belkin f5d7051 not detecting
ivegot the same problem, it worked previously and then randomly it stopped working. I have reinstalled windows 7 and it is still the same, i cant install itand cant detect the usb adapter. Have you found the solucion? Please email me to marcos15eliseu@hotmail.com
Jul 27, 2009 | Belkin (F5D7050) (F5D7050VSNPDQ) Wireless...
Modem device detection
Could be a daffy modem, did you totally reinstall windows?
Nov 21, 2008 | Dell Inspiron™ E1505 PC Notebook
Engine light on, codes PO455 and PO411 pulled.
P0411 Secondary Air Injection System Incorrect Flow Detected and P0455 Evaporative Emission Control System Leak Detected (Large Leak). These 2 particular codes are sometimes inter-related.
With a p0455, the most common repair is to:
  • Remove and reinstall the gas cap, clear the codes, and drive for a day and see if the codes come back.
  • Otherwise, replace the gas cap, and/or
  • Inspect the EVAP system for cuts/holes in tubes/hoses (you may hear a vacuum noise or smell fuel), repair if necessary
Let me know if you have anymore questions!
Sincerely,
JC
Nov 13, 2008 | 1998 Audi A6
Scanner light on HP Officejet J5780 does not come on.
uninstall your driver soft and then reinstall it. reboot the pc. set the printer as default in printer properties.
Jan 13, 2008 | Office Equipment & Supplies
Q : How come my optical mouse cannot detect by windows but has light on it.
I had the same problem several times, the light basicaly means that there is power reaching it. Try reinstal ur usb drivers. If nothing, unplug it and look into the part of the plug that goes into the computer. I alway had problems with those little pins bending or breaking. If one was bent I would get a pair of pliars and gently straighten it. If it were missing i would attempt soldering a new 1 on (the latter only worked once). However this can distroy equipment and it would b advisable to contact profesionals
Apr 07, 2007 | A4tech A4 OP-620PS2 3D Optical Mouse PS/2
Open Questions:
Linksys WPC54G Wireless-G Notebook Adapter V2.0 (WPC54C) Logo
332 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
