Question about Kenmore Elite HE3 Steam 8674 Dryer
Kenmore elite oasis gas dryer
Brand new. first load. gas kenmore elite oasis dryer. Lint appears to be bypassing lint catcher. some lint in housing below lint catcher. lint catcher is properly placed.?????
  • 15,935 Answers
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here's the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here's a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don't own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT - DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
Kenmore Elite Oasis ST electric dryer does not heat
You need to replace the heating coil that is usually the problem when you get air and and the tumbler is moving but no drying you can also check the lint catcher and clear out your dryer outgoing vent remove the hose check the dryer vent where the vent hose is connected and the vent going outside the house before changing the heating coil .
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
How to clean lint out of inside of Kenmore Oasis Elite dryer
Here is a "youtube" video showing how to take the dryer apart. Right around 3:20 is where you need to take the plactic cover off to be ablwe to clean all the lint off.
Jun 26, 2014 | Kenmore Elite Oasis ST 7806 Dryer
Kenmore Elite Oasis 6806 Electric dryer with burning smell
you must disassemble the unit and clean the lint out of the heating unit area, it is lint catching fire and could be dangerous to continue using your unit in this condition. a vacuum cleaner should do well to clean the lint and the drum must be removed to do a proper cleaning
Apr 15, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
I've cleaned my kenmore elite oasis dryer lint trap and ducts, yet it continues to run for extended amounts of time. it is not a case of large loads and I believe it must be a sensor but cannot find...
You must have a week limit switch that keeps resetting itself. Most of the time, the limit switches are by the burner. I wish I had a wiring diagram for it, the I could tell you where it is. Maybe there is someone else out there that can tell you a little more about it. Sorry wish I could help more.
Apr 12, 2011 | Kenmore Elite Oasis 7808 Gas Dryer
Sears kenmore elite oasis dryer 110 67032600 check lint screen flashes doesn t heat
Check the vent on the back. This is indicating a air flow issue. If the vent is clear ohm the heater out check it for continuity.
You can watch a video that explains how to complete this repair on your sears Kenmore Elite clothes dryer at the link below.
Sear Kenmore Dryer Video
Mar 11, 2011 | Kenmore Elite Oasis ST 6807 Dryer
My 18 month old kenmore elite oasis quiet pak 2 gas dryer smells as if there were a fire in it!!!!  and ironically, when i noticed the smell i also saw water around the base of the kenmore elite oasis top...
Hello plz make sure the gas burner does not have any lint build up on burner assembly inside the machine / plz clean.That usually causes a burnt smell. If there is no error codes on the display and the machines is operating fine you are chasing a ghost. If there is a pump or motor over load an error code should come up on the display.
Dec 11, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Oasis Electric Dryer, Model #110.6708*, 6709*
ck behind bottom panel if it has one or in console if it is mounted on top rear for tech sheet with codes (can tell from image where your console is ..sorry)
Jul 04, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Oasis Dryer with Airflow problem
same problem removed back cover cleaned lint found pulley had unscrewed and belt was off.installed pulley rev threded and put belt back on.
Mar 02, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE3 Steam 8674 Dryer Logo
118 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
