Question about Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis HE Canyon Capacity F1 code?
My Kenmore Oasis HE Canyon Capacity Washing Machine, keeps displaying an F1 code at the beginning of starting a load of laundry, I fiddle with it for a few minutes, it starts but then half way thru after it spins it flashes the F1 code again, I then have to go down and stop and start it again. What is causing this problem?
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!!
Posted on Sep 16, 2010
Code F
These units have several very common error codes. the most common being error code F1. Oasis washer repair is simple. The link below has a video that explains how to replace the main control board on a Oasis washing machine.
Oasis Washing Machine Repair Video
http://www.appliancerepairlesson.com/
Mar 15, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I have the Kenmore Elite Oasis HE washing machine and it constantly stops the washing machine and displays the F1 error code. Has this machine been recalled? I have read several complaints from other...
Hi
Error Code F1 means that the control is either bad or the wiring harness to the control has some issues. Please check the control board for any bad components as you might need complete replacement of the control. Please get back to me if you have any other questions.
Kevin
Nov 10, 2010 | Kenmore Washing Machines
F1 error
yep electronis control board in the console is bad.
Apr 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis Canyon Capacity electric dryer has AF problem. Husband has removed back of dryer and can't find reason for lack of air flow. Dryer spins but no AF. Please help!
If you haven't checked the exhaust running through your home to the outside do so. Be sure that it is clear of lint and debris and if it is over fifteen feet then you may need a fan to help the flow through that venting. If none of that helps then it sounds like a defect in the machine.
Mar 14, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
I have a Kenmore Elite King Size Capacity Washer and it displays an F code. It will not go through a full cycle. What could be the problem? Thanks.
in the back panel you will find a tec sheet with f codes . like f1 f2 f3 f4 f5 and so on but just a F ??? hope this will help mm
Nov 20, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Machine stops several times shows F1 code
this is a main control board failure and needs to be replaced
Sep 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
F1 error
there is a factory defect in the control circuit board of this washer, read and call the number. post is from another owner.
I called 800-659-7026, which seems to be a 3rd party "recall" center for appliance companies, for my F1 error code. All Kenmore HE Elite Oasis machines with Serial Numbers beginning with CS48-CT49 are in the process of being recalled; however the mailings haven't gone out to customers due to hold-ups in legal with wording. Machines with these serial numbers require an upgraded control board and it takes about 10 business days for the part to come in. They ordered it with no questions asked and are coming out July 14th to replace it free-of-charge
Jul 15, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I get a F error message when the cycle is one minute into the start....
I DON'T KNOW BUT IT SEEMS I HAVE HAD NOTHING BUT PROBLEMS WITH THIS WASHING MACHINE. MINE IS NOW STUCK CLOSED WITH ALL MY SONS JEANS IN THERE, AND NOW I HAVE THE F CODE TOO!.
Aug 25, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
217 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
