Question about GE GTS18 18 Cu. Ft. Top-Freezer Refrigerator with Upfront Illuminated Temperature Controls & Spillpr...
The electric is on but the fridge is not cooling
Our electric was out for a few days, now the fridge and freezer is back on and the light comes on when we open the door but it's not cooling down.
    Scholar:
  • 126 Answers
ARE YOU USING A 3 WAY TO 2 WAY ADAPTER OR EXTENSION CORD. THIS MIGHT BE THE PROBLEM. TRY A NEW EXTENSION CORD TO A DIFFERENT OUTLET TO ELIMINATE THE POSIBILITY OF AN OUTLET PROBLEM. OR IF THERE IS A RECTANGLE COVER PLATE ON THE BACK OF THE REFRIGERTOR WITH THE CIRCUIT BOARD IN IT THEN THE BOARD MIGHT BE BROKEN. I KNOW THIS IS STUPID BUT THIS HAPPENS. MAKE SURE IT IS ON. LET ME KNOW WHEN YOU HAVE MORE INFO.
Posted on Apr 25, 2010
Hotpoint FZ175G red warning light comes on freezer still freezing after reset light comes on again after a couple of hours
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 17, 2013 | Freezers
Fridge/freezer cooling inefficiently
Either the repair guy did not wire up the heater correctly or he replaced the wrong part, if the heater was good it was likley to be the defrost thermostat...I would call the repair guy back to check.
Jun 23, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Freezer only cools on the bottom half
check the seals on the fridge sounds like there might be a section not connecting with the fridge
Jun 07, 2009 | Freezers
Hotpoint fridge freezer green and red light on, switch offering 0
It could be a few problems to do with electrics, but try this first:
Dec 04, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
GE Refridgerator
I suggest that you check your defrost heater in the freezer. If this is the problem, then if you empty out the freezer section you will see a solid sheet of ice on the back panel. If the ice is there, then you may need to replace your defrost heater, we had this same problem just a few days ago. Once the heater was replaced, the fridge started cooling about an hour or so.
Oct 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge side by side and freezer not cooling
The fridge is working again and I don't understand why. Thanks anyway all is good.
Jul 22, 2008 | Whirlpool GS6NBEXR Side by Side...
Brand new refrigerator not cooling
ok what he was trying to say is that the freezer does all the cooling for both sides as nothing in the fride side cools and in order for the fridge to reach its proper temp the freezer should run any where between -0 to-10 then the fan in the freezer draw-es air from the fridge and cools it and circulates to the fridge now i need to know a few things is the compressor running is the freezer fan running do you see any frost on the back wall of the freezer section is the fan running in the back that's near the compressor to cool the condenser coils then i can better advise pleas hold my rating till we are done where did you purchase the unit
Jul 22, 2008 | LG LRTBC1825T Top Freezer Refrigerator
Hotpoint ultima fridge freezer
It's just simple.Keep the refrigerator open for few days with power on.After when the electricity bill comes,eveerything will be cooled.
May 28, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
GE GTS18 18 Cu. Ft. Top-Freezer Refrigerator with Upfront Illuminated Temperature Controls & Spillpr... Logo
98 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
