Question about GE Â 17.9 Cu. Ft. Top-Freezer Refrigerator
Electric went out now the fridge is back on but is not cooling
Our electric went ou for several days, Now the fridge is on but the freezer and fridge are not cooling but the light goes on when we open the door so we know electric is reaching it...any ideas?
    Scholar:
  • 126 Answers
ARE YOU USING A 3 WAY TO 2 WAY ADAPTER OR EXTENSION CORD. THIS MIGHT BE THE PROBLEM. TRY A NEW EXTENSION CORD TO A DIFFERENT OUTLET TO ELIMINATE THE POSIBILITY OF AN OUTLET PROBLEM. OR IF THERE IS A RECTANGLE COVER PLATE ON THE BACK OF THE REFRIGERTOR WITH THE CIRCUIT BOARD IN IT THEN THE BOARD MIGHT BE BROKEN. I KNOW THIS IS STUPID BUT THIS HAPPENS. MAKE SURE IT IS ON. LET ME KNOW WHEN YOU HAVE MORE INFO.
Posted on Apr 25, 2010
Fridge temperature too hot won't go down with temperature controls
This looks like there is a problem with thermstat in the fridge. We had a fridge that would not cool and we found it to be the thermastat problem. You have to replace the thermstat on the fridge. Not 100% sure but a high possibility.
Mar 23, 2014 | Frigidaire Refrigerators
Fridge is not cooling, fridge is working fine
Hello Dan, Is Your Fan in your freezer compartment on ? sometimes the evaporator coils will freeze up not letting the air cool the refrigerator
Dec 25, 2013 | General Electric GFSS6KKXSS Stainless...
We just moved the fridge to paint behind it. However, afterward the fridge is just cool but, the freezer works great. We have the fridge on max cool and still just cool. I also don't notice any...
I am not 100%, but there is an electronic door that allows cold air to pass through the freezer to the refrigerator.This is located in the refrigerator in the top left hand side. If you can here the fan in the freezer than you are probably have an electric door which is controlled by your thermostat. Make sure you set the thermostat back to the factory settings when you replace the evaporator fan electric door. I hope I helped you.
Sep 02, 2010 | KitchenAid KSRB25FKSS Side by Side...
The electric is on but the fridge is not cooling
Apr 25, 2010 | GE GTS18 18 Cu. Ft. Top-Freezer...
GSS25KGMB CC side by side GE fridge not cool
The main control board is going bad . This is the electronic board behind the 8 x 10 inch panel , on the back of the refrig . Your relay on the compressor is ok .
Feb 20, 2010 | GE Refrigerators
Any info on electrolux RA1300 gas fridge. Freezer works well but fridge compartment doesn't chill
If you had an electric fridge the problem is usually the evaporator fan motor ($30).
I suspect that you may have the same problem. Generally, freezers are cooled only, when the fridge needs cooling, the evaporator fan comes on and blows cold air from the freezer to the fridge compartment. The advice below is for an electric fridge but may also work for you, it's worth a try I suppose.
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Available from a parts supplier or electric motor company.
Unplug fridge, or disconnect gas etc. Fan should be located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan spins the same direction (CW OR CCW) as your old one, if you don't know which way it should spin then be sure it pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Nov 10, 2009 | Electronics - Others
Freezer Working, but Fridge side is not cold.
ou most likely have a defrost problem is there a large build up of frost in the back wall; of the freezer??
Jan 26, 2008 | Frigidaire FRS26KF5C Side by Side...
GE Â 17.9 Cu. Ft. Top-Freezer Refrigerator Logo
90 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
