Question about Kenmore Oasis 27042 Top Load Washer
Everytime it goes to spin it starts shaking real bad displays ul then ol not even anything in it i have pulled tub there is a crack in the piece with windings but not affecting windings
  • timdbarn Apr 25, 2010
    the basket has water in the bottom even with it out i can turn it anyway and it wont come out i kinda figure that there might b a crack in basket somewhere
    the rods and springs look good the basket has water in the bottom of it i can turn it anyway and it wont come out no matter how i turn it
    President:
  • 949 Answers
The ul and ol are unbalance load and over load.
I would suspect the suspension rods, if you look you can see the tub is suspended by 4 rods (10 in image) and spring loaded shock built into them.
The crack in the stator is nothing that should cause any worry about.
If the suspension rods, springs and holders are all okay the next likely suspect is the basket itself.
Posted on Apr 25, 2010
Testimonial: "good but i knew rods are good must b basket "
  • Philip Apr 25, 2010
    Would it help if I send the service manual to you? I would need an email address.
    The agitator or wash plate needs to come out before the basket will come out. There should be a cap that will pry off exposing a bolt. Removing that bolt will release the wash plate or agitator.
I have this same problem... my washing machine basket just hits back in forth and my washer is really loud knocking sound and moves really bad i try to re balance the clothes and the rods but it still does it.
Posted on May 11, 2010
Maytag a312 washer shakes bad when spinning
Most likely the tub is off balance. Open the lid, wait for it to stop then move the items around in the tub so that they are more evenly distributed. Close lid and let the spinning begin. If it still shakes but not as much repeat what I suggested. Check that the machine is level and that none of the 'legs' lost anything like the rubber pieces to prevent floor scratches and movement of machine. As stated in the beginning, most likely it is an uneven load. Super simple fix.
May 13, 2014 | Maytag Washing Machines
UL light keeps coming on stops spinning
The uL error code is displayed when the electronic control detects an off balance load. This can be caused by overloading, bad bearings in the tub, something between the tub and basket, or an issue with the electronics.
Feb 03, 2013 | Maytag Bravos MTW6600T Top Load Washer
Kenmore Elite Oasis washer does not lock
First, OL/UL stands for "Overload", so in other words, the washer things the tub is too hard to move because it's overloaded and the motor is struggling or the unit is way out of balance causing the washer to struggle. The most common problem is a nut below the inner tub that needs to "float". Floating is when the tub fills up with water to a certain level the inner basket will rise about 1 inch from the center agitator. What this does is disengage the basket from the motor so that the agitator can rotate independently from the basket. If the basket does not float then when it tries to agitate the whole basket will turn back and forth at the same speed as the agitator and this will cause the OL/UL error code.
Nov 22, 2012 | Kenmore Oasis 4.6 cu. ft. Canyon Capacity...
Tub does not move during wash cycle;just keeps filling;timer jumps from 25 to 4:then drains;flashes OL(small loads)
Nov 21, 2012 | Maytag Bravos MTW6600T Top Load Washer
Washer stops and shows oL over load
The "oL" error code in the Cabrio and Bravo washers means the motor is sensing an overload ("oL") condition. While this could indicate a problem with the motor, it usually doesn't. Most of the time, you'll see this error code when one of two things is going on:
1) There's a piece of clothing stuck between the inner basket and outer tub.
2) The tub is not floating freely, usually because it's seized to the drive shaft by rust and crudus; FYI: this condition is almost always caused by using non-HE detergent in this washer. Also, be aware that, if this is the case, it can be very difficult to remove the basket from a badly corroded drive shaft, could even be a two-man job.
Here is a video to help you get into the machine.
Keep me posted!
Nov 01, 2012 | Whirlpool Washing Machines
OL error code
Hi jbrundage1. I believe you have a UL error code on the washer. It means that the sensors in the washer are sensing the unit is unbalanced. When the washer is empty, set it to a spin or rinse and spin setting. Run the washer through the cycle empty, as it will help to remove any excess water in the tub. Also, make sure the washer is level, as it is balanced on springs, and that could be throwing the sensors off. I hope these suggestions prove helpful. Sincerely, Melanie, Maytag Social Media Representative.
Jun 03, 2012 | Maytag Bravos MTW6600T Top Load Washer
My washer goes into spin cycle byitself and when washing,if u r in spin cycle it sets for 14 mins thats good 4 mins into spin all knob lights start flashing and the screen says uL
One thing to understand is that this is a difficult problem to pin down and may end up requiring the control board to be replaced.
The UL or unbalanced load error is displayed when the control board senses an out of balanced load.
You don't indicate if the washer is actually out of balanced or not when the code appears but the description of banging and shaking would indicate it is out of balanced.
If the washer consistently bangs and shakes in spin then I's suggest you remove the spin basket and check under it for obstructions that might prevent the washer from spinning smoothly.
Jan 23, 2011 | Washing Machines
My cabrio waher will not spin on the last 12 min of the cycle...it displays ul everytime...it is not unlevel we have checked
My washer dose the same thing even with no clothes in it, cause i'v leaveled it and redistrbute the clothes in nothing wroks
Jan 18, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Won't spin
OL error means the Motor Controller has sensed an Overload.
The oL code means the motor control board is struggling to power the motor up. If it recurs after removing some clothes - usually this means a new motor control.... or worse - a new bearing.
If it were a problem with the tub floating up, the unit would spin instead of nutate.
Bearing failure in this machine is very common.
I suspect the drive shaft and bearing are the problem. The bearing and shaft are part of the outer tub.
The new outer tub with bearing W10128830 cost approximately $197 dollars.
If you can get access to the shaft it may be an Emory cloth will help smooth things down so that you no longer get the OL code.
This is an ambitious do-it-yourself project... as most appliance repairmen don't understand how this machine operates.
http://media.fotki.com/1_p,srrtbrrfbdbqgkkxgtqsskgwtqkq,vi/bqkfstqqfxrqqbkwgqdxbwsqrwrtq/1/1303472/5961857/image828956817962821589img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 04, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
UL Code
Solved the unbalanced problem - open the top of the machine (press in with a flat putty knife about 3" in on the front on each side while lifting up as there are 2- 1" wide catches). Once both sides are unlatched, raise the lid then slightly lift the rear of the lid so that it fits into the curved part at the top of the hinges then open all the way - tape the lid to the top so it doesn't flap about and scotch the lid to keep it from falling back down on you. Now, look around - see all that rust?  The rust has fallen into and gotten underneath one or more of the 4 white plastic suspension "ball joints" which have probably totally dried out by now from their factory grease because of the water, bleach, and rust particles.  Having someone help you, simply lift up on one of the 4 corner suspension rods - gravity and weight is all that holds them down. The white ball will lift out of the socket and still be attached to the rod. Clean out the rust, lightly sand the "socket" with emery cloth, then slop in a fingerful of grease. I used automotive wheel bearing grease with graphite in it. Also scrub off all embedded rust on the white plastic ball. Lower that corner back into the newly cleaned and greased socket and repeat for the other 3 corners. Now when you move the tub around notice how the balls pivot in their sockets like they are supposed to. When they were dry and rusty they wouldn't move enough to allow the tub to twist like it should so it slammed around.  Now, shake your head in disgust that after only 2 years there is so much rust that you wonder if it will make it another year before falling apart, close the lid, and try another load.  That totally solved my off-balance problem where even a single handkerchief would give the UL error. It is still a finicky machine, but at least once again works like it did when new.
Jan 12, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Oasis 27042 Top Load Washer Logo
672 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
