Question about LG SteamDryer 7.3 Cu. Ft. Extra-Large Capacity Electric Dryer
I am getting a caution to "Clean Filter". What does this mean?
    Novelist:
  • 145 Answers
Most clothes dryers have a lint filter. Has it ever been cleaned? If so look for another filter that the dryer may have (the users manual can tell you).
Posted on Apr 27, 2010
Tranmission fluid filter
The transmission would need to be partially disassembled to get to the filter inside.
Jul 08, 2013 | 2008 Buick Enclave
Canon L120 - What does this error message mean?
Check Scan Platform, means:
The scanning platform is dirty, or not set into scanning position.
Solution
Clean the scanning area, or lift the scanning platform into place.
Nov 26, 2011 | Canon L120 Fax Laser Printer
How to clean a carburetor filter
If you mean the air filter, if you have access to an air hose, blow it out,and if it isn't a k&n brand, throw it away and get a new one.
If you mean the fuel filter, can't clean them, replace it.
Sep 18, 2011 | 2005 Datsun 720
I have a front loading Bosch washing machine and it was working fine on Friday. On Saturday morning I went to take a load of clothes out and the door won't open - I am getting an E13 signal. My...
Hi!
The door lock uses electrical power to keep the door closed. Unplug the machine from electrical power and the lock will be released in a couple of minutes. Please be sure not to flood the room if the water level inside is above the door level.
Regarding the E13 error itself, it means too long draining time, and it can be caused commonly by something stuck in the drain filter. To get to this filter and clean it, you have to look at the lower part of the machine and remove the circular panel, then insert a little screwdriver into the hole and twist , the acces pannel will get open. Now twist the handle of the filter and pull it out. Now it can be cleaned. CAUTION: opening the filter will cause all water inside the machine to get out, so have some towels handy to avoid water to spread all over the floor.
Hope it helped,
Bogdan
Aug 28, 2011 | Bosch Washing Machines
My whirlpool duet steam washing machine has the error code F21 flashing on it and i was wanting to know what it meant and how to fix it
This means you unit is unable to drain the water out in a timely fashion, most likely you have a clogged filter in the pump causing this. Remove the access panel under the door, 2-3 screw at the bottom. The pump has a screw handle head on it the you can unscrew ad clean out the filter. Use caution, will contain water and once removed it will pour out, use a bucket to collect the water.
Stay dry...
Jul 23, 2011 | Whirlpool Washing Machines
I have an error EE 2 on my lazer 56 toyostove Does anyone know what that means?
EE 2 means its not getting fuel, your flame sensor could be dirty, or there could be a problem with the circuit board. The heater goes thru a 3 min warm-up/purge before the pump comes on. If the pump is making a loud ticking sound then it isn't getting fuel. You should then check your filter and the strainer in the fuel sump. If the pump isn't making a noise you could check the flame rod and clean it with some steel wool. You should check to make sure the igniter is working also. After you turn your heater on the cover on the igniter will start to get warm and will get very hot before the purge is done so use caution. Hope this helps.
Apr 03, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Says to clean the air filter
The air filter on this set is on the bottom of the light engine which means you have to remove the light engine form the set to access the filter, i have the guide right from panasonic service manual, no picture as the manual does not have one but here is the info:
THE FILTER ON THE PROJECTION UNIT
CAUTION:
Operating with torn or damaged Air Filter may cause damage
to the Projection unit.
Remove the Projection Unit from rear.
The filters are located on the bottom and in new engine
designed the front of the engine.
clean the filters onthe Projection Unit. Gently remove any
accumulated dust from
filter with a vacuum cleaner; use extreme care so as not to
damage or tear the filters.
The engine is a little tricky to get out you really need to be sure each connector removed is inserted and no cable has stress on it when it is being removed, there are no photos of the process just a tech jargon from the service manual.
Hope this helps,
Apr 01, 2010 | Panasonic PT-52LCX66 Projection Television
How to change the automatic transmission oil and filter. On 4 cylinder engine
Check fluid level every 12 months or 7500 miles, whichever comes first. Transmission fluid and filter should be changed every 100,000 miles. On THM 250C transmissions, intermediate (front) band requires adjustment every 60,000 miles, or as required.
1. With vehicle on level surface, apply parking brake and let engine run at curb idle. Move selector lever through all ranges, ending in "PARK". Remove dipstick and wipe clean, reinstall, then remove again and check fluid level mark on dipstick. Fluid level should check between "ADD 1 PT." and "FULL HOT" marks on dipstick.
RECOMMENDED FLUID Use only Dexron II or equivalent automatic transmission fluid.
CAUTION: If vehicle has been operated for an extended period of time at high speed, or in city traffic in hot weather, or if vehicle has been pulling a trailer, an accurate fluid level cannot be determined until fluid has cooled down (approximately 30 minutes after vehicle has been parked).
So let's get started... 1. With vehicle raised and drain pan placed under transmission, remove front and side transmission oil pan bolts. Loosen rear pan bolts approximately 4 turns each.
2. Carefully pry pan loose with screwdriver, allowing fluid to drain. Remove remaining bolts and oil pan with gasket. Remove screen/filter-to-valve body bolts and remove screen/filter with gasket.
3. Thoroughly clean pan and screen with solvent and dry with compressed air. Paper type filters should be replaced. Install new gasket or "O" rings, lubricated with clean oil, into screen/filter assembly.
4. Install screen/filter assembly to transmission. Use new pan gasket and install pan. Add proper amount of fluid to transmission through filler tube.
5. Start engine with shift selector lever in "PARK" position and with parking brake set. Check fluid level and add as required. CAUTION: DO NOT overfill.
Best of luck :)
Oct 20, 2009 | 1986 Pontiac Fiero
Smell still in clothes
Try adding baking soda to the wash. We have the same issues (son works on a dairy farm) and will on clothing resort to chlorine bleach even on colors in small amounts. Eric
Jun 17, 2009 | Frigidaire Affinity ATF7000E Front Load...
Replace Fuel Filter
2005 Chevrolet Colorado
FILTER REPLACEMENT: May Require special Tool for Quick Disconnect Lines
Removal Procedure
CAUTION: Refer to GasolinelGasoline Vapors Caution in Cautions and
Notices.
IMPORTANT: Inspect the fuel tank internally and clean the fuel tank if you find a restricted fuel filter. Refer to Fuel System Cleaning.
1. Relieve the the! system pressure. Refer to the Fuel Pressure Relief Procedure.
2. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
NOTE: Clean all of the following areas before performing any disconnections in order to avoid possible contamination in the system:
• The fuel pipe connections
• The hose connections
• The areas surrounding the connections
IMPORTANT: The quick connect retaining clips will remain with the fuel filter.
3. Disconnect the quick-connect fittings from the the! filter.
4. Cap the the! pipes in order to prevent the! loss and possible the! system contamination.
5. Pry open the locking tabs (3), only enough to slide the the! filter (2) from the the! filter bracket.
6. Drain any remaining fuel.
Installation Procedure
1. Slide the the! filter (2) into the the! filter bracket, until the locking tabs (3) are th!!y engaged.
2. Remove the caps from the the! pipes.
Connect the quick connect fittings to the fuel filter.
3. Lower the vehicle.
4. Inspect for leaks.
5. Turn ON the ignition, with the engine OFF for 2 seconds.
1. Turn OFF the ignition for 10 seconds.
2. Turn ON the ignition, with the engine OFF.
3. Inspect for fuel leaks.
Oct 08, 2008 | 2005 Chevrolet Colorado
LG SteamDryer 7.3 Cu. Ft. Extra-Large Capacity Electric Dryer Logo
81 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
