Question about Therma-Stor Santa Fe Dehumidifier
Large amount of ice has accumulated behind the back panel in the upper part of the unit on my Sante Fe RX. About 2 to 3 inches thick.
  • 3 Answers
Your post says you have an RX but the picture shows a SantaFe Classic.
In either case the massive frost build up is caused by a defective defrost thermostat. PN 4021470 Parts Dept 800-533-7533 x 8451
The defrost thermostat has an internal set of electrical contacts that are designed to open up and turn the compressor off when frost or ice has accumulated on the tubing and the evaporator coil. If the contacts fail to open, the compressor keeps running and the frost and ice just keep accumulating until such time as the homeowner unplugs the unit or a sevice tech replaces the defrost t-stat.
Dwaine
Thermastor Service Dept
800-533-7533 x 8459
Posted on Apr 26, 2010
I just replaced the two filters in my Sante Fe Compact dehumidifier, and the coil and filters froze up in a week. The temperature is above 70 degrees. What could be the cause?
Air restriction in the connected ductwork.
Dirty coils reducing air flow thru dehumidifier.
Low refrigerant charge.
Phone the factory at 1-800-533-7533 for help troubleshooting.
Sep 10, 2014 | Santa Fe Compact Dehumidifier
Why will my Sante fe works but will not shut off.
initial thought would be faulty switch, need to check it
Aug 13, 2014 | Santa Fe Max Dry Dual XT Dehumidifier
The filter is getting ice on it when I turn it on.
If you haven't already, clean the filter after it has thawed. In addition, the coils behind the filter may need cleaning.
Turn the unit OFF & Unplug it. Remove the filter and the upper half of the front of the cabinet. Clean the cools with warm water and dish washing liquid. Rinse with a damp sponge, dry the coils and apply a light coating of WD40. Reassemble the cabinet, plug the unit in, turn it back ON and take it for a test drive. Be sure to clean the filter at least once every 2 weeks.
Jul 19, 2011 | Whirlpool AD50USS Dehumidifier
Coil frosts within 15 minutes in a warm room. After 1-2 hours they coils are covered with snow like frost 1 inch thick.
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Apr 30, 2011 | Goldstar DH304 Dehumidifier
My Santa Fe RX dehumidifier is leaking lots of water. I manually filled the pan and pump came on, but as soon as I moved it around a bit, lots of water came out.
Your pump hose may be damaged or the adapter that connects the small hose to the pump may be loose. The pump itself may be damaged as well. Unfortunately this means that the unit must be partially disassembled in order to access the pump and associated tubing. The pump is located on the bottom of the dehumidifier next to the fan.
You can call Therma-stor service at 1-800-533-7533 for specific advice on your dehumidifier.
Feb 26, 2011 | Santa Fe Rx (4023673 ) Dehumidifier
My Santa Fe RX runs for about 1/2 hr. The accumulator gets cold and than warm. Compressor & fan run. Humidity is set to max. No water is ever collected (I monitor the pump reservoir).I have removed the...
Are you keeping all of the metal covers in place while the machine is running? If you remove some of the metal covers, the fan may not move the air through the dehumidifier as intended.
If the compressor runs (with all of the metal covers in place) and the accumulator does not become cold, there are a few things that may be affecting your dehumidifier.
1. low refrigerant charge - you may have a refrigerant leak.
2. blocked capillary tube or broken expansion valve.
3. blocked air filter prevents enough air from moving through the dehumidifier.
Good Luck - DryDog
Aug 15, 2010 | Santa Fe Dehumidifiers
Ice Buildup on Model DE45EA.
60 is too low for most dehumidifiers...if you warm up the room a bit to 65 it will work...
Here is a tip that will help you with basic trouble shooting..
http://www.fixya.com/support/r3877515-dehumidifier_problems_dehumidifier
heatman101
Apr 22, 2010 | Haier DE45EAL Dehumidifier
Humidifier iced up.
You are operating the unit in a cold location.wait until it is warmer or move the unit to a warmer location.
Sep 30, 2009 | Dehumidifiers
Iced up coils and will not dehumidify
I did a little digging around on the internet and found out that if the basement (or where ever you have your unit) is in an area where the room temp might dip below 65 degrees the coils may start to become "too efficient" in pulling the moisture/humidity out of the air and it begins to freeze on the coils before it can drip off into the reservoir. The site said to turn off the unit and let it thaw out, then restart it and see if everything works ok after that. If the temperature gets too low you might need to warm up the air in the room/basement before it will operate correctly again/not continue to freeze up. Hope this helps. Mine just did the same thing but we've had some pretty cold weather recently and the basement is fairly cold as well.
Jan 20, 2008 | Comfort-Aire BHD-501 Dehumidifier
Therma-Stor Santa Fe Dehumidifier Logo
385 people viewed this question
Top Therma-Stor Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Therma-Stor Dehumidifier Expert? Answer questions, earn points and help others
