Question about Canon PIXMA MP150 All-In-One InkJet Printer
Printer will not print
I have a Canon PIXMA MP150 printer. I get a "problem Code" E3 (paper is jammed) when I try to print. There is no paper jammed in the paper feeder. what is causing the problam ? How can I try to fix it ?
    President:
  • Canon Master
  • 1,447 Answers
There's a hidden sensor lever under the white guides behind the platen roller. Either a scrap of paper is holding it up, or it could be bent from pulling out a jam. It is a black lever behind the platen roller slightly to the right of center. You may need a shop to repair.
Posted on Apr 25, 2010
Please help with cannon PIXMA MP150 printer problem, when trying to print, It reads that paper is jammed but I've checked several times and no paper is jammed. Printer will not print due to this...
Hello and Welcome to FixYa!
Paper jam means their may be small bit paper jam in side
, actually there are some "micro sensors" that detect a paper jam. There will be tiny piece of paper inside those sensors, thus tripping the sensor and paper jammed keeps coming up.
To solve this first of all Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
, If you become sure that now really there is no paper, dust or foreign objects then Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If still problem exist then best & final option is to just contact to any Canon Printers service provider.
I hope this solution helps you
Thank you for using FixYa!
Aug 04, 2011 | Canon PIXMA MP150 All-In-One InkJet...
My Canon pixma mp150 sometimes won't print (document remains in print queue). Sometimes it will print one page but will stop with an alternate flashing "E" and "3", followed by a popup...
Welcome to Fixya
Error E3 is a paper jam error. Check the unit if there are foreign object stucked inside. Blow compressed air to clear any blockage inside the unit. You may try to install the printer software if you still have the original disc that came with it for the drivers.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Feb 24, 2011 | Canon PIXMA MP150 All-In-One InkJet...
I have a cannon mp150 printer and am getting a E3 alarm code. I do not have a paper jam and don't know how to fix this
Sometimes a printer may give the paperjam error massage. When this happens you must go thruogh the ritual of clearing paper jam before the printer will respond to the print command again.
So you do the following:
Put of printer and unplug its power cable.
Open all printer covers. (front, back, top as ti applies to your printer)
Close them back firmly
Plug back the power plug
Try printing again.
Good Luck & God bless!
Feb 11, 2011 | Canon PIXMA MP150 All-In-One InkJet...
The alarm light comes on and then the E3 error
Hi the E3 code is a Paper jam
Have a look there maybe a small bit paper inside
All best: pineworks
Jan 14, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon Pixma MP150 keeps blinking E 3 saying there is a paper jammed even though there's no paper in the printer. I found a little screw inside, could this be the problem?
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-5
Aug 02, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Getting code E3. What does this mean?
error E3 means Paper jam ..try to clean any paper inside...
May 06, 2009 | Canon PIXMA MP150 All-In-One InkJet...
CANON PIXMA MP150 Error E3
Hi! Have you checked the correct source for paper feed? you can use either sheet fed paper tray at base of printer and from top loose sheet feed. Make sure selection is correct, button below/to right of pwere switch.
Hope this sorts it, it did this on mine.
Paul 'W'
Onyer~EDson(:0)~[><
Dec 02, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Not print or copy
posible a small piece of paper jam in the senzor. check please the entire paper path
Oct 17, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
173 people viewed this question
old marine
old marine
