Question about X2Gen MG19MY 19" LCD Monitor
Monitor turns off and on repeatidly
I have not been able to use my computer because the monitor turns on and off repeatildy. does this sound like a short in the power cord? or something else?
  • panther7775 Mar 24, 2008
    how could you even fix the driver problem though, if the monitor will not stay on long enough to do that?
What you want to do is enable low resolution. Before Windows starts where you would normally press akey to get into the BIOS, press F5. This will bring up an option to select an operating system to start. On this screen press F8. You should now see several different ways to start windows. Select enable low resolution. Now, when windows starts update the monitor driver in device manager. Digital flat panel works on my comp.
Posted on Mar 27, 2008
I believe it is a driver problem for your monitor. im having a similar problem.i need to find the correct drivers and not the default vista has for the monitor.
Posted on Mar 24, 2008
Monitor has no sound
if you monitor has a sound input, connect the cable to your computer. Open the computer sound control and select the monitor speakers (it may be the headphone output for your computer). You do not want to have the computer speaker selected.
Mar 03, 2015 | HP W2371D 23 Full LED Monitor 16:9 5ms...
Turn sound on my HP 250 monitor
If you monitor has a sound input, connect the cable to your computer. Open the computer sound control and select the monitor speakers (it may be the headphone output for your computer). You do not want to have the computer speaker selected.
Mar 03, 2015 | HP Computers & Internet
My HP w22 Monitor started to make a crackling sound and than all the sudden turned off, or something. It wont come back on. The computer works just not the monitor. Any ideas on how to fix the problem?
Try checking your Cable connections to the Monitor to the Computer and from the Monitor to the wall outlet.The crackling sound maybe normal.Most Monitors make that sound.
Jul 31, 2010 | HP W22 LCD Monitor
How do i get the sound to work?
Sound has to be connected to the monitor. Plug the audio cable from the monitor into the green audio jack on the computer at the back. Make sure the sound is configured for stereo and not 7 channel surround. Turn up the volume on the monitor(if there is a control) and turn up the volume on the computer.
Mar 31, 2010 | ASUS VW193T Monitor
When I turn on my monitor, its goes straight to a
  • when you turn on computer. after sometime your monitor goes to standby mode and monitor light colour will be orange it means problem with your computer not monitor.
  • After this You Check your VGA Card.
  • When you turn on computer is there any beep.
  • After this also check your RAM.
  • May be problem with your RAM.
Try this Technique .
Mar 13, 2010 | HP w1907 LCD Monitor
I cannot get any sound from my ViewSonic VA1912wb Monitor. I have everything plugged in the mute turned off showing 100% volume the green jack in back of monitor and green match on computer. No sound from...
You may need to load the monitor drivers.
I assume your PC sound is OK.
When you are plugging the green lead in the Moniotr / PC do you hear any noise from the monitor?? if not may be faulty.
Try plugging a friends set of speakers into the back of your PC.
Mar 09, 2010 | ViewSonic VA1912wb Monitor
Dell e771p monitor cant turn on. Noise beeping sound from monitor
The monitor is not worth fixing and I recommend replacement. The good news is that you've confirmed the problem is not with the computer!
Sep 16, 2009 | Dell E771p 17" CRT Monitor
I'm frustrated. Love the picture on my Acer 22" monitor with speakers, but the sound is very poor. I have the volume for the computer turned up, but still can barely hear the sound. What can be done to...
Built-in monitor speakers are usually not the best quality. The monitor should have it's own volume control have you tried adjusting it?
You can use external speakers by plugging them into the same jack in the back (green) of the PC instead of the monitor.
Dec 12, 2008 | Acer V223WBD Monitor
Monitor image flashes off and on
Sounds like you've done all the trouble shooting. If you just need that extra nudge, I would agree... it sounds like you'll be needing to shop for a new monitor.
Jun 29, 2008 | Dell E153FP 15" LCD Monitor
Monitor turning off and on repeatidly
it is probably the power board / video board is causing the problem. If you check power cord is ok.
Mar 23, 2008 | X2Gen MG19MY 19" LCD Monitor
X2Gen MG19MY 19" LCD Monitor Logo
74 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
