Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Can't open bottom freezer draw. It seems to be locked. How do I get it open?
    Scholar:
  • 126 Answers
IF YOU HAVE AN ICE MAKER IT MAY HAVE OVERFLOWED AND FROZE THE DOOR SHUT. AND IF YOU ARE SURE IT IS NOT FROZED WITH WATER THEN YOU ARE GOING TO HAVE TO FORCE IT. OTHER WISE BE SAFE AND UNPLUG. LET IT THAW AND TRY AGAIN AFTER 24 HOURS.
Posted on Apr 25, 2010
The fridge ok. Bottom freezer frosts/freezes up...cant even get the drawers to open...
pour hot water in an around the draws
even a funnel and a smaller hose attached to get past the draws
soak up the ice melt with towels
the draws should open
May 17, 2016 | Refrigerators
Hi the vege draw on the bottom always freezers the veges the draw above is fine i have tried sliding the open/close lever also where to purchase replacement draws and milk shelf
USUALLY A PROBLEM WITH THE AIR FLOW DAMPER CONTROL AND OR THE FRIDGE THERMISTORS> IS THE FREEZER OK? IF U HAVE A BAD DOOR SEAL OR CLOGGED DRAIN PLUG U CAN GET CONDENSATION THAT MAY FREEZE AT BOTTOM AS WELL
Mar 16, 2015 | Refrigerators
The freezer compartment does not seem to be working properly. Top part an everything is frozen but further down it it less cold an on the bottom draw the ice is slowly melting
From your indications, it sounds like your evaporator fan is not functioning and evenly distributing the cold air throughout the freezer.
Jul 07, 2011 | Zanussi ZX57 / 3 Freezers
The freezer is COLD..freezes solid. Setting at low. The frige part is not cold and is set at high. Seems everything is going up to the freezer. Unit is just over 1 year old. Drinks are cool but not...
where is the freezer on top,side by side or the bottom.all a fridge does is blow cold air from the freezer to the fridge side that's it,if the fridge is warm there's a problem most likely in the freezer,a plugged drain or when you open the freezer door do you hear the fan blowing,if not you have a bad evap fan motor,also check your warranty it still might be covered.send the model number and i can help you,if you see water under the bottom draws or in the fridge section if the freezer is on top you have a blocked drain in the freezer.let me know what you find and i can help you
Feb 20, 2011 | Magic Chef Refrigerators
I have an Amana BC20TW refrigerator with a bottom freezer. It seems to be running all the time. I raised the temperature dial to make it warmer and it still runs too much. Put velcro on the bottom freezer...
Accuracy is important --Use a digital thermometer to monitor freezer and fridge temps. Fridge should be around 40 and freezer around zero and then take it from there and draw conclusions
Sep 22, 2017 | Amana ARB9058CS Bottom Freezer...
Hey my ge profile top fridge bottom freezer is broken
I had the same problem, It turned out to be a bad circuit board ($350). Also check to make sure you don't have frost/ice build up in the rear of the freezer. The fridge draws cool air from the freezer through a vent in the freezer.
Feb 04, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Help me with me frige not cooling bottom GE unit.
When you close the freezer door, does the fan turn off? There isn't any thing else on my bottom mount beside the damper that regulates airflow to the refrigerator box.
You should be able to drop a string from the damper opening at the back of the refrigerator down to the duct to the freezer. If you can't there is some obstruction in that duct. I suppose it is possible there is some other mechanism in that duct on your particular model, but I can't understand what its purpose would be.
The picture below shows the vents at the back bottom of the refrigerator box that return air to the evaporator in the freezer box to be re-cooled. If these are blocked, the fan can't draw air in to be blown back up to the refrigerator, unless of course the freezer door is open. 7e3c57e.jpg
Jan 09, 2009 | GE Profile PDS22MHR Bottom Freezer...
Control pad is flashing and can't seem to reset tempeature
try unplugging the unit and waiting 9 minutes then plugging it back in.
Dec 26, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
65 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
