Question about Toshiba SD-V295
Set clock on sd-kv550-su - Toshiba SD-V295
    Sniper:
  • 52 Answers
There are two ways to set the clock on your machine, firstly by using the 'auto clock' feature and also a manual setup, if the auto setup doesn't work then you will need to setup your machine manually. the 'auto clock' feature will atempt set itself up and will take approx 4 mins for the machine to adjust itself. There is also a daylight saving setting which you can either have set to on or off. The auto and manual steps that I have added below have been taken from the user manual for your your Toshiba SD-V295 pages 24 - 26.
Hope this helps,
James
Auto Clock Adjustment
Preparation:
• Turn ON the TV and select the corresponding video input.
• Press VCR DVD selector to select the VCR mode.
(The VCR mode indicator will light.)
1. Connect the Antenna or Cable system.
If you use a cable box, turn it on.
2. Plug the AC power cord to the AC outlet.
3. Make sure the DVD/VCR is turned off.
If you press POWER, the Auto Clock set is not programmed.
4. Wait at least three minutes and press POWER.
5. Press CALL DISPLAY to check the clock setting on the on screen display.
6. If the clock is not set, check the antenna
condition. The AUTO CLOCK may not function properly if the reception condition
is not good.
Manual clock setting
1. Press VCR MENU.
2. Press SET + or – to select “SYSTEM SETUP”, then press ENTER.
3. Press SET + or – to select “CLOCK SET”, then press ENTER.
4. Press SET + or – to set the month, then press ENTER.
5. Set the day, year and time as in step 4.
6. After setting the clock, date and time starts functioning automatically
Posted on Apr 25, 2010
Power indicator light blinks-7 times. will a new power supply fix it
Physically disconnect the SU board and the SD board. (See precaution # 5)
Plug in the TV and turn it on.
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
blink 7
There is a sequence that you have to check to figure out which board is bad,
Feb 16, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
Picture went out and no audio, red light on power blinks seven times and repeats.
blink 7 times?
Yes
No
(See precaution #3)
Yes
No
Yes
No
(See precaution #3)
(See precaution #3)
(See precaution #3)
No
(See precaution #3)
blink 7 times?
blink 7 times?
Feb 15, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
Can not turn on the unit. Looks like a burned power supply. How do I check it and fix it?
open yout toshiba, use volt meter to check the voltage at your toshiba power supply, if there any voltage its mean your toshiba power supply still ok, if there're no voltege tis mean it was burn
i hope this helpfull, please rate very helpfull if you think this helpfull
thanks for using fixya
Jan 22, 2011 | Toshiba SD-KV550
TV will not turn on. Power light blinks 7 times, then pauses, blinks 7 times again. What could the problem be?
If you are a DIY then you will need to try to unplug the SD board and reconnect and try again, if it stills shutdown with 7 blinks then the SD board is bad and maybe the
blink 7 times?
Yes
No
(See precaution #3)
Yes
No
Yes
No
(See precaution #3)
(See precaution #3)
(See precaution #3)
No
(See precaution #3)
blink 7 times?
blink 7 times?
Jan 11, 2011 | Panasonic TH-37PX50U 37 in. HD-Ready...
Mi portatil thoshiba no lee mi sd 4g despues que le puse w7
Hablas ingles? Yo intiendo que usted tienes problemas con su 4gb SanDisk Thumbdrive y su Toshiba laptop despues que puses Windows 7.
Usted tienes dos alternativos. 1. Reforma su SD 4gb Thumbdrive con Windows 7 2. Retorna su Toshiba a Windows XP
------------------------------------------------------------------------------------------- Traducion en ingles:
I understand that your SD 4gb Thumbdrive isn't working with your Toshiba laptop after you upgraded to Windows 7. You have two possible alternatives: 1. reformat your SD 4gb Thumbdrive using Windows 7 to format. 2. Go back to Windows XP, or whatever operating system you were using before the upgrade.
Aug 03, 2010 | SanDisk 4GB microSDHC Memory Card
Power light flashing
if flashing 7 time need replaced sd board and su and sd board
Panasonic TXNSD1RJTU SD BOARD BOARD, SD (Y SCAN DRIVE LOWER ASSY)
Panasonic TXNSU1RJTU SU BOARD BOARD, SU (Y SCAN OUT UPPER) ASSY
Panasonic TXNSC1RJTUS SC BOARD BOARD, Y SUS DRIVE BOARD
Jun 03, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
I had the 7 blinking lights problem after tv shut
7 blinking Defective Board (possibility)
SC, SU, SD, P board (SC,SU,SD>D,P).
Connect
the connectors SC2(*2),
and SC20 to the SC board. Remove the SU board. Turn the TV on. Does the TV power up
and stay on IF YES REPLACED SU BOARD IF ON
Install
the SU board and
Remove the SD board. Turn the TV on. Does
it power up
and stay on? IF YES REPLACED SD BOARD
Feb 03, 2010 | Panasonic TH-42PX75U 42 in. Plasma...
Dvd hack needed for sd-kv550
hi
only just seen this post in case of still wanting the dvd code you could try here video help
just type make model in to search for dvd codes.
riz.
Jan 02, 2008 | Toshiba SD-KV550
Toshiba SD-V295 Logo
386 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
