Question about Whirlpool RF378 Electric Kitchen Range
Cracked glass on cook top. Can it be replaced without buying the heating elements?
    President:
  • 949 Answers
Sorry to hear about the trouble, yes the glass and frame can be ordered separate from the elements. If you can send me the complete model number from the tag on the side rail visible with the lower drawer open I can get you the part number and approx cost.
Posted on Apr 25, 2010
Need new glass top schott hob
You need to buy the new glass top without the elements, there is no fixing it, or should not be fixed, it should be replaced.
Apr 09, 2013 | Cooktops
My scholtse glass top won't work with my utencils
THe glass top is just that, glass! If the elements beneath it are not producing enough heat your utensils will not cook. Pull off the glass top by removing fasteners (either in the front of the stove or under the back panel of the stove). Then, turn on each electric burner to see if it turns RED hot. If not, wait till everything COOLS and reseat each heating elememt and retest those that failed. If that doesn't solve the problem, you can buy heating elements at Home Depot or other stores...
Nov 12, 2012 | Kitchen Ranges
Can I cook on a cracked cooktop
The glass cook tops are made of tempered glass. Even small crack can eventually lead to shattering if the glass if heated in a condition where it has a weakness. In addition, depending on the severity of the crack, any liquids that boil over while cooking can end up directly on the heating elements. This could lead to catastrophic failure of the elements and/or an electrical shock hazard. It is strongly recommended that the cooktop is replaced as soon as possible.
If you need guidance on how to replace a cooktop, the following link explains:
http://www.fixya.com/support/r4249512-replacing_glass_cook_top
Repacement parts can generally be purchased on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites offer great service with competitive pricing, so shop and compare. The first three sites include helpful exploded view parts illustrations to assist you with locating and properly identifuing any parts you may need.
I found the following part number(s) : WB62T10475, WB62T10476, WB62T10477
The correct part number and price will depend on your COMPLETE MODEL NUMBER and COLOR of your range.
If you have any further questions, please post back and let me know. I hope this helps you.
Dec 23, 2010 | GE Profile JB900BK / JB900KK / JB900TK...
Kenmore 911.9562991 glass top stove-glass cracked
I have Yamaha RX-v473 can not turn on , I try tone+info+power still not working. It’s have other way to turn no power ?
Oct 23, 2017 | Kenmore Kitchen Ranges
Kitchenaid 36" glass cooktop with small crack
A small crack, turns into a big crack, Short of ordering a new piece of glass, there is no "fix" sorry. YOu can continue to use it, but eventually it will run across the cook top, and then shatter the glass... Better be safe than sorry.
Jul 31, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Broken glass top on my Maytag Schott Clean (upper
u have to replace the whole top and its about 400 to 500 dollars just for the part cheaper to buy new
Mar 20, 2009 | Maytag MER6772 Gemini Electric Kitchen...
REPLACE CRACKED GLASS COOK TOP
First of all, if the cook-top broke as a result of a manufacturer defect, the repairs should be covered under the manufacturer's warranty. In this case, the repairs would be done at no cost to you. If, however, the glass top was broken as a result of the consumer, the repair will not be covered (even if it is still under warranty). If this is the case, it does not require an engineer to replace a glass cook-top. It can be time consuming, though. If you are somewhat savvy with fixing things, it can be accomplished by the average do-it-yourselfer. The following link explains how to replace most glass cooktops:
http://www.fixya.com/support/r391448-replacing_glass_cook_top
The tedious part of replacing the cook-top is carefully removing and handling each burner element. These are usually ceramic and are very fragile. You must be handled with care. If there is no common disconnect, you also will be required to unplug each burner assembly one at a time and label the wires. A digital camera can come in very handy for this as well. The easiest way to do this is to remove the old shattered cook-top, first and lay it side by side with the new one. Remove and install one burner element at a time.
If you wish to pursue this and require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 28, 2009 | Whirlpool GR773LXSS - Stainless Steel...
I have a Kenmore electric range oven Model # 79095201103 that has a glass top. The top cracked and I ordered a new glass top for it. What steps do I need to do to replace the top. Is it complicated???
Here ya go...
This advice is for Electric Ranges equipped with glass smooth tops. If it becomes necessary to replace the cook top due to wear or damage, here's some helpful tips on how to complete the repairs yourself.
WARRANTIES: Most warranties DO NOT cover cosmetics. That is, if your cooktop paint starts to wear off, most manufacturers will not replace it. Warranties also DO NOT cover accidents such as dropping something on the top and breaking it. Warranties DO cover blistering, warping and heat related breakage (if you are using the recommended cookware). This is why it is important to follow all the manufacturer's use and care instructions that come with your range. I know this does not include ALL manufacturers, but this is true with most.
This is a recommended two-person repair job. Please read through the instructions carefully before starting the repairs, and follow any safety recommendations.
1. UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
2. If the old cook top is broken, you will need to get rid of a much of the glass shards as you can and thoroughly vacuum the area around the oven box. Use extreme care when handling broken glass. Wear safety glasses and gloves.
3. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
4.On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, Follow these steps:
Unplug the cook top and leave the elements in place.
Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
Remove the surface element assembly leaving all the elements wired together.
Place the new cook top face down in the same manner and lay the surface element with wiring harness directly on to it and screw in place.
Install the new cook top back on the range and you are DONE.
5. If the wiring harness does NOT unplug, follow these steps:
There are a series of screws holding the element assemblies in place. Leave these assemblies wired together for ease of replacing. It is recommended that a second person holds the assemblies in place to support the wires until all the screws have been removed.
Lay the intact element assembly, with wires still connected, on top of the oven box. Handle the surface elements with care. They are very fragile. Care also must be taken not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure.
If you have to remove the elements, individually, make sure you write down how the wires were connected to ensure you reconnect them in the right order. Make sure you also take note of the numbering scheme on the element and make sure you place the mounting brackets in the same holes that they came out of. Use care when screwing into the new cook top. CAUTION: The screw holes are usually painted and a little force may be required to thread the screws. Do not apply too much pressure on the glass, or you can damage it.
Prop the new cook top in place and install the surface element assembly from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
Lower the new cook top into place and secure with screws.
Good luck and I hope this helps.
Apr 06, 2008 | Kitchen Ranges
Whirlpool glass top stove
The glass top can be change, but be aware that if you have all your cooking element fixed togetter, this could cost plenty of $$$. If your heating element can be remove easyly, you are a lucky owner.
Dec 10, 2007 | Whirlpool ED2FHEXN Side by Side...
Whirlpool RF378 Electric Kitchen Range Logo
113 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
