Question about Sony Grand WEGA KF60WE610 60" Rear Projection Television
Picture keeps jumping horizontally and a little vertically cannot find any horizontal or vertical adjustment on t.v. or remote
  • 666 Answers
It is most likely a transceiver error try checking all the connections cable box dvd so on if you have it set to hd it might be an auto picture feature messing with it even though it is not needed checking those too would be thorough
Robb
Posted on Apr 25, 2010
TV has a great picture but wont "hold it". Keeps going to a single flat horizontal line across the middle of the screen. Tapping on side of TV used to bring it back but now, nothing. Just a line.
Vertical scan output section circuit fault. Absence of vertical scan causes the single horizontal line on screen. Horizontal scan output section is OK. Contact any service technician to troubleshoot the vertical scan output section circuit. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Horizontal line fault to CRT based TVs are given.
Oct 06, 2014 | Televison & Video
I have a Philips TV model: 27pt9015d. at the top of the screen several horizontal lines have appeared. it looks like the top inch is being cut off and then flipped back. that is - when credits are...
sounds like the vertical adjustment has spanned beyond the screen, causing it to jump up and then upside down. after the cover is removed look for vertical adjustment and with a non-conductive screwdriver, adjust it a little bit either way to see if it fixes it, if it doesn't fix it, then look again for the right one.
Jun 18, 2008 | Philips Televison & Video
Tip
How to set convergence on Projection TV ' s
I have given an general explanation on most projection TV ' s
  1. Enter the menu on your TV. Use the remote control and bring up the menu.
  2. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  3. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  4. Press "Enter." A crosshair pattern will appear on your screen.
  5. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  6. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  7. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  8. Repeat these steps for all colors.
on Mar 18, 2010 | Televison & Video
My RCA tv picture is jumping
Vertical jumping may have a vertical hold issue, horizontal may have a horizontal hold issue. Most older tv sets will have some knobs or adjustable screws for vertical and horizontal hold. Turn your set on and check for these knobs on the back of your set and adjust until your picture is in as well as you can get it
Aug 21, 2014 | Televison & Video
Vertical size too large. Cannot adjust enough in menu
Try adjusting the horizontal out first. You may have to do this a little at a time back and forth between the vertical and horizontal.
Oct 21, 2013 | Pioneer PDP-505CMX 50 in. Plasma...
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    It has tripple vision and looks like a bow tie.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    Tv not showing a picture
    Hello e26pitts,
    If the line is horizontal then it could be a problem in your vertical deflection section, if the line is vertical then the problem is in your horizontal deflection section. Now for a little more detail.
    If Horizontal line is present the vertical section of the yoke transformer is nit responding to current flowing through it due to being open, or the vertical coupling capacitor is open, or even the vertical drive transistor might be defective.
    If Vertical line is present the horizontal section of the yoke transformer might be bad. Now this gets kind is easy in a way, because the yoke would be the sole cause of your problem here (maybe there is some circuitry doing some horizontal coupling check that to) because the horizontal section controls other functions that would also respond if this were a horizontal drive issue. In any event these problems should be checked by a qualified TV technician, I would suggest that you take the TV to a repair shop to have it worked on.
    I hope this helps
    Thank you,
    Shuttle83
    Mar 21, 2008 | Televison & Video
    Horizontal and vertical adjustments
    sorry there is no adjustment for this .you probably have a bad component in tv
    thanks Doctor video .
    Oct 17, 2007 | RCA 32V550T 32" TV
    Picture has a horizontal row
    this symptom is caused by a trouble in the integrated circuit of in the vertical oscillator circuit. try to look if your tv has a vertical hold control at the back or inside, if it does not have, u have a problem in the vertical oscillator circuit. by the way, its not the horizontal that u should concentrate into, its the vertical. coz this is a vertical sync problem.
    Jan 12, 2007 | Konka K2001UM TV
    Sony Grand WEGA KF60WE610 60" Rear Projection Television Logo
    62 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
