Question about Rancilio Silvia Espresso Machine
Temperature problem When i pour through an espresso using my Rancillio machine i find that the bottom of the shot is cold.
    President:
  • 1,618 Answers
Keep portafilter in the head with no coffee in it at all times, preheat portafilter and cup before you brew a coffee.
Posted on Apr 27, 2010
What are the Rancillio classe 8 all settings numbers?
This would depend entirely upon what drinks you are making. Most users set the quantities based on the double espresso drink; as an example 14g of powder tamped to produce a 75ml double shot in 22seconds. Other drinks can then be set from there.
Dec 07, 2014 | Coffee Makers & Espresso Machines
Espresso shots pour very slow for both the single and double shots.
Did you try adjusting the group head screw? And/or cleaning and checking the valve in the group head? Good visuals and instructions here: https://myprojectsandmods.wordpress.com/2014/10/27/delonghi-ec702-espresso-machine-no-water-flow-fix/
Feb 03, 2014 | DeLonghi EC702
Gaggia Classic. Completely disassembled and cleaned. Water path clear. Great water flow thru the group head and filter holder "with no coffee". With coffee or pod in filter; takes 3-5 minutes to pour a...
Hi
If you don't have the pressure it may be the pump. Vibration pump Gaggia Rancillio or you have a blockage in the solenoid. For solenoid , partially remove 1 solenoid screw and try to make a coffee - water will pour from solenoid and hopefully clear the blockage .
Mar 08, 2018 | Gaggia 16002 Espresso Machine
I have a rancillio epoca dual head espresso machine, there are two gages on the front of the machine, steam is coming out of the top gage
You will need to get that manometer changed. Get a hold of a rancilio dealer and tell them you need a steam manometer.
Sep 29, 2011 | Rancilio Silvia Espresso Machine
Milk is not dispensing hot enough from saeco Primea Cappuccino Touch Plus coffee maker?? any ideas
I have the same problem, my wife complain me everyday, now we use our coiffe machine 90$ from sears it`s still better then this 3200$....
Apr 25, 2010 | Saeco Primea Cappuccino Touch Plus Coffee...
Making Espresso shots... how does the macine do this? Not in man
www.partsguru.com look to the left for Saeco Home Models, select that, then go the model you have and download the manual.
On a magic comfort it has two settings for adjusting the espresso shot besides the amount of the shot. .
On a magic comfort plus,
you can adjust the grind size, the amount used for the shot, preinfusion (a short shot of hot water on the grinds before the unit passes all the water through the puck (coffee grinds), temperature and amount of water for shot
Also, when setting the strength on this machine, don't use a full grind amount as it can jam the machine. use a setting of 6 or 7 max for strong shots, not the 8 or 9 setting!!!
Dec 03, 2008 | Saeco Magic Comfort Plus Espresso Machine
Rancillio and Verona commercial coffee machine spares
Espresso Dr. Located at Fortitude Valley. Ask for Michael.
Jun 30, 2008 | Coffee Makers & Espresso Machines
UNABLE TO GET GOOD CREMA ON TOP OF COFFEE:
It could be. Your grind should determine the amount of time that it takes the shot to pour. Standard is 18 - 30 seconds. I prefer 25. If it only takes 10 sec, your crema will be weak.
Are your beans fresh? Older beans produce less crema. By old, I mean more than a month if properly stored.
What is the temperature of you shots? The water coming out of the head should be about 195 F which makes the shots roughly 170-185. If it's too cold, you'll get worse crema. It's also possible to have mostly steam in contact with the grounds which will give the same results. Both indicate other problems.
Make sure your group head screen isn't clogged. And make sure everything is very clean, especially inside the handle (under the grounds basket - just pop it out with a screwdriver). Good luck!
Dec 16, 2007 | Rancilio Silvia Espresso Machine
Rancillio Silvia Steaming problem
Sounds like your Rancilio needs a service, this problem could be caused by the boiler not working correctly, possibly a leak from the boiler or a valve malfunction causing a drop in pressure.
Aug 02, 2006 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso Machine Logo
73 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
