Question about Invicta Reserve Subaqua Venom Swiss Quartz Chronograph Watch
How do you remove links from the subaqua venom
How do you remove links from the stainless steel braclet on a subaqua venom
  • 2,334 Answers
Find how to remove or add links here: Use this link and browse through my TIPS AND TRICKS: http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524.
Posted on Apr 25, 2010
How to change watch band on invicta angel stainless steel band
Turn the watch over and you will see that the band is attached to the watch with spring loaded pins. There is room to put a spring removal tool in the available slot and depress the spring which will allow you to twist the band away from the watch. Be careful to not loose the spring loaded pin as you may need it to install another band. Almost every watch uses this method of band removal. Those that don't usually have a long screw that is accessible from the side of the watch.
Feb 19, 2013 | Invicta Reserve Subaqua Venom Swiss Quartz...
I have an Invicta Venom #6111 with Poly strap. I want to put a Stainless steel ******** instead. How do I remove the caps covering the Screws holding the ********?
The caps are just for decoration. They dont cover anything. To remove the strap, you have to release the spring loaded pins from the underside of the band. There are two on both ends. Reuse the pins with the stainless band but be careful not to have a pin go into the wrong hole because they can't be removed without breaking them!
Oct 24, 2010 | Invicta Reserve Subaqua Venom Swiss Quartz...
Extra links for tag heuer 2000 stainless steel and gold braclet
Links need to be ordered from TAG.They cost about £30.00 per link best contact www.rolexrepairs.co.uk if you send them the watch they will supply and fit with a free estimate first.
Regards
Aug 10, 2010 | Tag Heuer AquaracerWAF1110.BA0800 watch
Need a manual describing how to set the date for an Invicta Reserve Subaqua 6208
mcdevito75 here, Best Bet, online to shopnbc.com to Invicta watches, or give Invicta a call , info at the website at ShpNBC.com
Jul 03, 2010 | Invicta Reserve Collection Subaqua Noma...
How do you remove the links from an invicta subaqua venom stainless bracelet?
it's not much harder then normal push pins, just a little trick..push the pin out, doesn't matter which way. You will probably have to pull it out with pliers once you get it started.
once that pin is out, the band still won't come apart. There is another pin, a tube actually that the other pin went thru. it connects the center links. to remove it, you have to first remove the outer links. to do this you push them inwards, toward where your wrist would be if you were wearing it. (the links are actually two pieces-the center 'snake-skin' piece, and the outer bars. the outer bars are connected behind the center piece) the outer bars are what you push inward, they will pop out once the first pin is out.
Now you will just have the center piece connected to the adjacent center piece. That second pin (the tube) will just about fall out if you turn the band on its side. Now the bracelet will come apart.
To put back together, just line up the to center pieces, slide in the tube, then put the outer links in from behind the center piece (this actually locks the tube in place) then put in the long pin.
Ideally it will slide in halfway easily, then carefully tack it in fully. if it doesn't get in halfway jiggle the links and tap lightly. Don't use too much force until it's past 2/3 inserted or you will bend the pin.
Jun 10, 2010 | Invicta Reserve Subaqua Venom Swiss Quartz...
Invicta Reserve Subaqua Venom Swiss Quartz Chronograph Watch Logo
605 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Invicta Watch Expert? Answer questions, earn points and help others
