Question about Troy Bilt Tb70ss Gas Trimmer
The starter rope, pull is now loose and does not start trimmer, how do I get into,or get the plastic case off from the spindle silver thing, to fix rope pull for TB70SS, Can you help me , thank you Beth
  • Elizabeth Stewart Apr 25, 2010
    No,,,,, I cannot get screw or remove the screw from the out put shaft (silver thing ) to take off the plastic cover............I think the screw is maybe stripped or no screw in there. Can I drill it out to get it off?????????????????????????????????HELP lol
    there is a metal cone on top of plastic cover that is on top of flywheel, I can't get that off to get to flywheel....is it screwed in, or can I pop it off, how to get that off. Please let me know if you can.
    President:
  • 2,468 Answers
Can you remove the "Fly-Wheel" cover off the engine(2 or3 screws or bolts off) the engine, if so, then you can re-wind the Re-Coil spring and add a new piece of starter rope and it should work for you again
Posted on Apr 25, 2010
My Poulan Pro 150E pull cord will not engage to start the weed eater. The rope comes out adn retracts back with no problem, but there is no pressure on the clutch to cause the motor to start. There is...
Sounds like the starter dogs are broken. They are little plastic teeth that engage to turn the engine when you pull the cord. You'll need to replace the whole starter assembly to fix this.
Aug 26, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Replace starter rope on a tb70ss troy bilt trimmer. everything is off but the red plastic casing
you will need to flip the casing upside down and wind the pulley counter clockwise, it should be pressure on the pulley if not then it is clockwise, once you have wound it six or seven times, you will need to feed the pull rope from the outside in, there is a hole on the pulley where the rope comes through, while keeping the tension on the pulley, once the rope is through you will need to knot the end and burn the end of the knot, let go of the pulley it will wind the rope, pull on the rope a few times to make sure the knot is holding, then reassembly the unit. Hope this helps Tim
May 07, 2011 | Troy Bilt Tb70ss Gas Trimmer
When i tried to pull the starter string it wont come out.why?
The starter/recoil design for these machines isn't the best. Sometimes the pulley the rope is in binds up...sometimes the rope will catch a notch in the pulley (the rope pulley is plastic)..and sometimes the crankshaft bearings in the engine become loose and worn and the alignment for all the parts on the shaft is skewed. This includes the flywheel and the clutch and the flexible drive shaft and the starter recoil unit. You will have to disassemble to get down to the heart of the problem.
Aug 26, 2010 | Poulan Garden
I have pulled the cord out of my gas powered trimmer. What is the easiest way to fix this
Remove the pull start mechanism, remove the old rope from the inside plastic, thread a new rope through the hole in the outside and through the hole in the plastic center where you removed the old rope, Now reach between the spool and the edge of the casing and pull some slack in the rope, there will be a notch in the spool, set the rope into the notch and begin spinning the spool to make tension in the spring ( correct direction is the same way the rope is spooled in. go until you have good tension on spring, grab rope left outside casing and pull through, then let rope get pulled into the spool with the spring tension you have created. Now just reattach the handle.
May 31, 2010 | Craftsman 22" Gas Hedge Trimmer
I have a Poulan Pro link trimmer PPB225E. The rope starter pulled out and will not retrack back in. How do I fix it.
It sounds like when it was assymbled that the cord wasnt routed through the holes of the plastic disk right to avoid it being pulled out. If you attempt to fix it yourself its no easy task,the entire casing needs unbolted and seperated. You need to make sure you DONT pull the recoil bands out,and there is a proper procedure of the cord routing and tying.This is a pretty advance repaire for a novice.
Aug 08, 2009 | Poulan Garden
Craftsman weedwacker 358.791070 suddenly stopped
could have been caused by any number of thing's,
take the recoil assembly off and try pulling the rope out while holding the center of the rope spool just enuff to prevent it from popping out in case there's nothing holding it there.
rewinding the rope is alot easier than rewinding the recoil spring Trust Me.. lol
Jul 31, 2009 | Garden
Starter rope will not retract.
inside the rope pull housing is a flat spring,it may have come loose from its anchor, its an easy fix...unscrew the 3 screws on housing, lift off housing, and the rope pull is inside the casing, you will then see if its broken, or just come off anchor, 10 minute job if its just loose......
Jul 21, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Cannot get my trimmer started.
Tom, it sounds like part of the rope has jumped off of the spool. There should be a small piece of plastic with a screw holding the spool in place. It may have worked itself loose.
Jim
Jun 07, 2009 | Echo Garden
Pull cord all the way out, and will not recoil
I started to take mine apart but when i loosened the 4 screws on the yoke the string rewound so ive been running it like that.
May 16, 2009 | Homelite Mighty Lite Lawn Trimmer
Troy Bilt Tb70ss Gas Trimmer Logo
127 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
