Question about Maytag CWE4800A Electric Single Oven
RECEIVING A F2 ERROR CODE ON DISPLAY SCREEN. CAN ANYONE TELL ME WHAT THE CODE MEANS AND HOW TO FIX THE PROBLEM?
    Scholar:
  • 195 Answers
The oven has had a high temp the temp sensor will need to be replaced , cost about $75 but if you look around you can find it for much less
Posted on Nov 10, 2011
I keep getting the following error message: E6 F2 - what does this mean?
If you have a Whirlpool oven, the F2 E6 error means that the Cancel key line is open. You will need to replace the keypad or the keypad and controller board (if a single assembly) if the keypad doesn't respond to a press of the Cancel Key.
I hope this helps.
Dec 12, 2011 | Whirlpool Ovens
We have a Kenmore Stove C880667020L0 and are getting a message F2, does anyone know what this means?
If you're receiving such fault error, it means that your oven is too hot. Oven Temp Exceeds 590 ° F.
Nov 07, 2010 | Ovens
My RBD275PDB14 Whirlpool double electric oven started displaying an E6 F2 error message and intermitently shutting down after a power outage. I replaced the control panel but it is still displaying the...
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 03, 2010 | Whirlpool RBD245PDS Electric Double Oven
Amana Self-cleaning Oven flashes F2 and F3 and beeps. It doesn't get real hot. Although it does heat up not the appropriate temperature.
Hi, F2 error code on the Amana Oven means "Oven too hot" You have to replace Oven temperature sensor to fix it.
F3 error code means "Open or shorted oven temperature sensor". Yo also have to replace Oven temperature sensor to fix it.
Summarily, both code has to do with the temperature sensor which you need to replace...
Oct 23, 2010 | Amana Ovens
When I turn the GE oven on sometimes it works fine other times it will shut off. When it shuts off it will give the F2 or F3 error sign.Can you please tell me what this means? Thanks
Hi, the F2 Error code means the oven has detected an excess temperature condition. Most often this is due to a bad temperature sensor - the sensor costs about $75 from an online repair site.
The "F3" error code means the oven sensor is open, I suggest you flip breaker off then back, on Re check for error, if OK fine if not turn back off and fix or call for service man...
Oct 06, 2010 | Ovens
Oven will not come on. Display screen flashes F2.
The error code means that bad relay on control board.
It could also mean that sensor is not making proper
connection with the board.
Sep 01, 2009 | GE Ovens
GE Oven JKP26GP2 getting F2 error, even when not in use. I ohmed out the Temp sensor at room temp it is 1091ohms. The other 2 sensors check NO and NC. It's 100 bucks for a new Temp Sensor.....just don't...
F2 usually means the temp sensor is not working. here is a link to "F" codes.
http://www.repairclinic.com/0078.asp#JennAir
It has many manufacturers listed,so scroll to the GE ones.
The reason it beeps when not in use is b/c the EOC is reading the error in the part.
Good Luck!
Feb 19, 2009 | GE JKS06BFBB Electric Single Oven
F2 Error code displays with audible beep.
The F2 typically means an overtemperature conditions:
1. over 650 degrees F unlatched or 915 degrees F latched.
2. cooling fan stalled while over above 650 degrees F or an oper thermal switch in the yellow leads.
Check for:
1.Welded relay contacts
2.Cooling fan stalled or blocked air flow to rear of unit.
3.High resitance in over sensor leads/connectors, especially at sensor in rear.
Nov 03, 2007 | GE JTP20 Electric Single Oven
ER1 F2 error on Whirlpool Super Capacity 465 RF386PXE Oven
HOW DO YOU CLEAN SELF CLEANING OVEN SUPER CAPICITY 465
Sep 23, 2007 | Ovens
Maytag CWE4800A Electric Single Oven Logo
140 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
