I just got a new Kenmore air cleaner/ionizer. For two days it emitted a very chemical smell, so strong that it made us nauseous, burning eyes and headaches. We tried running it all night to see if it would let up but it only became worse. What would cause a strong smell like this? Nothing is hot and we checked the filters and motor and they were cool but for something that is supposed to clean the air, it made the air smell terrible.
-   I've had the same problem. I bought one for my baby's bedroom to help make some white noise and clean the air but the smell was terrible. I took it back and got another one just in case something was wrong with it. I'm having the same smell with the new one. I have an older model in my other daughter's bedroom and that one never smelt like this. -   loripalla
Solution #1
posted on Sep 24, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I just bought the same model and also have the smell. My previous one did not so I returned the first unit and the second units smells the same. I called Sears Customer Support and they told me that it is probably due to the factory smoke test they do on each unit. He said let it run for a few days and it should dissapate. I went a step further and am trying a new filter and if this works he said call the store and they will get me a new filter.
I need to replace the two bulbs, for the Airmaster Ultra air purification system. I will not use the...
(More)
I need to replace the two bulbs, for the Airmaster Ultra air purification system. I will not use the local rainsoft dealer! The parts are: LAHV91, Rainsoft PN: 65048 and the LAHN90L PN: 65501. Can you tell me where to buy them?
i have the fresh aire model just replaced rci cell cleaned filter and cleaned the ozone plate. the...
(More)
I HAVE THE FRESH AIRE MODEL JUST REPLACED rci CELL CLEANED FILTER AND CLEANED THE OZONE PLATE. THE FAN KEEPS TURNING ON AND OFF?? STARTS RIGHT BACK UP ON ITS OWN AND THROWS NO EROR MESSAGES??
side by side refrigerator....need to take out top inside of refrigerator to replace part. How do I...
(More)
side by side refrigerator....need to take out top inside of refrigerator to replace part. How do I get the top out?
Hi, I have a Hunter Quietflo Air Purifier that has quit working on me after about 3 years of use. It...
(More)
Hi, I have a Hunter Quietflo Air Purifier that has quit working on me after about 3 years of use. It seems to be getting power bc the lights turn on like normal but thats all that seems to get power. Is there a way to check if the motor is working without replacing it? thank you
I purchased this unit at an auction sale.
I have cleaned the filter. I have the energy...
(More)
I have cleaned the filter. I have the energy timer set to 3
hours, the fan speed set to LOW and the humidly setting to On.
When I switch on the unit it runs for less than a minute,
then shuts down for about 6 minutes
before restarting again.
During the shutdown time the panel lights still operate. I
can change the fan speed and humidity control indicator but nothing happens
during the shut down period. Its like the unit has gone into sleep mode with
the panel on.
