Question about Yard Machines Tecumseh 148cc Front Tine Tiller #21a 251e000
Will start but not run
Have an 18'' front tine MTD rotatiller, it will fire, but it dies out, and will not stay running. Checked fuel, no porblems there.
SOURCE: I need a manual for my MTD Huskee 5hp rear tine tiller
I went to MTD web site and they had all the manuals for all there products. You will need a model and serial number to get them. Thank you for responding back to me.
I got the manual for the tiller and the engine.
Posted on Apr 13, 2009
SOURCE: tines wont turn
Without really knowing what is broken it will be tough to give a firm idea of the cost. However, you can head over to www.partstree.com. They have a great detailed parts break down and costs associated with it. Looked up your part numer and can find at this link: http://www.partstree.com/parts/?lc=mtd&mn=210-031-000+%281990%29
Posted on May 07, 2009
  • 221 Answers
SOURCE: mtd rear tines tiller won't engage tines. F and R
It sounds like the shift shaft or something in the gearbox the shift shaft engages. I know you didn't want to hear this but it is not uncommon. Most operators don't use the clutch bail when starting, stopping, and shifting as they should.
I hate to say it but this may require a trip to your service center for repair.
Posted on Apr 30, 2010
  • 221 Answers
SOURCE: have a rototiller it moves ok but the tines do not
Seems to be a fairly common problem with these units. If the big pulley is turning which I assume it is as the drive wheels work, it is most likely a problem in the gear box. The shift mechanism in these units leave a lot to be desired. You can try to repair it your self or take it to a service center. Labor will be high due to the amount of time required to separate the engine and transmission.
Posted on May 06, 2010
  • 221 Answers
SOURCE: I have a MTD yard machine rear tine tiller. Goes
You will have to get into the gearbox. It isn't too hard but is time consuming. Sounds like the drive for the tiller has broken. Could just be the chain in the gearbox for the tiller drive.
Posted on Jul 01, 2010
My 2003 tahoe will turn over but it want start and stayed running it will back fire and die
Have you checked fuel pressure with a gauge ? Is the check engine light staying on when the engine is running ?
Feb 11, 2014 | 2003 Chevrolet Tahoe
Have Honda HRB215 mower. Fired right up first use this season and operated fine. Week later fires first pull then dies after couple seconds. Drained gas and replaced, checked fuel filter, gas lines etc....
Have you checked the spark plug? Mine was doing the same thing. Not staying cranked and sputtering while running. I changed the plug and it runs like new. Hope this helps
Jul 11, 2012 | Garden
98 chevy k1500 will fire then die right away will not stay running
That is usually the fuel pump in the tank you to check the fuel pump pressure in all conditions as these are sensitiveJohnny
Mar 16, 2012 | 1998 Chevrolet K1500
My yardmachine snowblower won't stay running. It starts if I pump the primer. Fires up than dies. The fuel line isn't clogged, but once it starts it seems like the throttle cable has no tension (floats...
empty the fuel bowl & tank. start out with fresh fuel for one. then get a new spark plug if it still dont start. as far as the cable thats another deal completely but it shouldnt cause it to stall out. but if it ran last year it will this year too. always run it empty for summer storage. its your personal choice if you use a summer storage lubricant.
Feb 09, 2010 | Mtd 22" Yard Machine Push Mower
Won;t start
I got a new air filter for mine today, plus cleaned out the metal fuel canister under the carburator and the little brass bolt and my mower started right up. I was having hte same problems getting my mower to run and stay running. Glad I checked this site!
Sep 09, 2009 | Mtd 22" Yard Machine Push Mower
Garden want stay running
maybe air supply is restricted. sounds like the fuel side is working. Also you may turn carburator adjusting screws all the way in then back them off 1-1/2 turns. after it starts you can adjust them to the right adjustment, you just have to play with them.
Jun 07, 2009 | Mtd Products Yard Machines 158CC Tiller
MTD 12.5 HP Ride On Mower won't stay running
It could be a needle valve sticking or a mal-adjusted float but more common is a fuel filter that is restricted, once you use up the fuel in the line and float bowl it runs out and dies. A less common but easily tested issue is when the mower has run for the amount of time it begins to sputter and die, loosen the cap on the fuel tank just a bit, if it helps or resolves the issue the vent in the cap may be clogged.
May 26, 2009 | Mtd Garden
Tiller won't stay running
If you choke or prime the engine, it starts up for a second or two and dies, the carburetor need to be cleaned/repaired.
May 25, 2009 | Mtd Products Yard Machines 158CC Tiller
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Yard Machines Tecumseh 148cc Front Tine Tiller #21a 251e000 Logo
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
