Question about Universal Office UNV-38016 Shredder
Shredder screen reads door open even if the door is closed and wont let me do any shredding
  • 1,606 Answers
Unplug it and then open i t up. You are looking for a piece of shredded paper that is stuck or jammed. Can even be a accumulation of paper dust. The piece won't be that big but most of the time that is all that is wrong. The paper either jams the door sensor or blocks it and gives the error. It can also be a bad door sensor or switch. Not very common but can happen.
Posted on Apr 25, 2010
Why can't I shred when using another shred receptacle for the shred
There is a switch that the original basket trips when it is installed. IF you don't use the original then the switch wont close and the unit wont start.
May 06, 2016 | Office Equipment & Supplies
I emptied the shredder and now the red overheat/door open light comes on when I turn it on. will not allow me to shred anything. please help!
There is an interlock that prevents your shredder from operating without the bin in place. Something may be stuck inside, preventing the bin from closing the interlock. There also could be a shred of paper preventing operation.
Feb 17, 2015 | Compucessory CCS60076 - High Security...
Spl-s302d shredder door open
Check to see if there's a little piece that broke off from the door. This would be the "safety interlock switch" or little thingy that pushes down the basket sensor. The basket sensor is located on the bottom front of the shredder. I bent a paper clip to hold down the metal switch (basket sensor) and taped it to the front of the shredder with scotch tape.
Jan 07, 2012 | Staples Office Equipment & Supplies
Fellowes S8-95C is full, but can't get it open. Help!
I was able to pull really hard and open the bin 1-2". I turned the unit on its side over the trash can and some shreds came out. I alternated shoving a sturdy metal rod inside (first an aluminum architectural ruler then the longer handle of a squeeze clamp) to loosen up the shreds and tipping the machine on its side to get some loose shreds out. After doing this enough times I was able to dislodge the dense clumps and remove the drawer. Now that the machine is empty there is a red light on and it does not shred.....UPDATE: turns out somewhere along this rough process (paper was in rock solid clumps) a small piece of the door that presses the "door closed" switch broke off. Jammed a piece of cardboard in there and it shreds again, although it does not automatically turn off when the door is open.
Jun 30, 2011 | Fellowes SB95C Cross-Cut Shredder
Shredder keeps turning off and full light comes on but its empty. Have to keep opening and closing door to shred something
Door switch possibly bad I am a shredder tech out of colorado. Call fellows at 800-955-0959
May 05, 2010 | Fellowes DM15C Shredder
Shredder will shred about 3/4 of a sheet of paper then shuts off. If you open the shredder door it resets the power switch and you can finnish shredding the remaining paper. is there easy access to the...
If your shredder has a feature where it won't run with the door open/shredder off the bin, you probably need to make sure that the safety is engaging properly. If the motor seems to sound very labored when it runs, unplug it, and check the blades to make sure there's not a lot of extra stuck in them. You may need to clean them and lubricate it with special shredder oil ONLY.
Nov 24, 2009 | Fellowes Office Equipment & Supplies
ROYAL RL170MX Shredder won't shred
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
Aug 11, 2009 | Royal 1280MX Shredder
Royal VF12mx shredder
Pour some shredder oil in the throat where you normally insert the paper...put some shredder oil directly onto 1 sheet of paper and try shredding 1 sheet. If it wont even shred 1 sheet I would ask is the shredder running???
Mar 05, 2009 | Royal VF1012mx Shredder
Hsm125.2
Because your shredder shred almost to dust level. you may have paper back up inside the machine. you will not be able to see it unless you remove the head and open the cover. Or your main board could be bad. You have one main board that controls your shredder.
At this time, the machine maybe reading as full because the paper backup inside the machine.
you have few screws that holds the base and the top cover.
Good luck.
email me if you have problem
This is known problem with Hsm125...
Jul 21, 2008 | HSM 125.2hs Shredder
My shredder stop shredding. has paper caught in it
Shredder drive gear is probably shredded - hard part to find or replace usually. Could mean a new shredder;-(
Aug 29, 2007 | Quartet gbc 6120S Shredder
527 people viewed this question
Top Universal Office Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Universal Office Office Equipment and Supply Expert? Answer questions, earn points and help others
