Question about McCulloch 16" Electric Chain Saw 35 HP
Motor does not turn sprocket - McCulloch 16" Electric Chain Saw 35 HP
  • 2,841 Answers
I am assuming the kickback chain brake is not on. Push it forward to make sure. If the engine revs but the drive sprocket will not turn and the chain is adjusted correctly then the centrifugal clutch is bad or the spring is broken. You will have to take the clutch out to see exactly what has broken.
Posted on Apr 25, 2010
  • NOT ME Apr 25, 2010
    Excuse me, push the chain brake backward.
WEN 6014: Motor is running, but chain doesn't move. Chain sprocket seems fine, cogs are only slightly worn, sprocket fits perfectly, no wear. Is there an internal clutch or connector? Motor worn out?
There is a clutch behind the metal housing where the chain sprocket at the engine end attaches to the chain . There are wear parts with springs on them that have to be changed. ChainSaw Shed Chain Saw Parts for Wen Wagner Brand Chain Saws Chains Bars... You can get parts here.
Sep 15, 2016 | Garden
Remington Pole Say
check for a roll pin in the gear or shaft that has sheared off
check that the square end of the drive shaft is not rounded off or that the square drive in the gear is in fact locking on the drive shaft and not turning from worn out
Jun 20, 2016 | Remington Electric Pole Saw
When you turn throttle on top sprocket turns freely but when chain is on it will not turn th wheel
It has an electric motor I would check the sprocket on the motor see if it has a key way it could of broke or fell out
Oct 13, 2014 | Razor Dirt Quad Electric ATV
My gear will turn without having the chain on . When chain is attached it the motor just works. No chain movement
I wasn't familiar with your saw but I looked at the parts diagram for it in the link below thinking there may be a replaceable drive pin or something like it that would possibly have sheared.
http://www.masterparts.net/111409-01.html
I didn't see any. That would indicate that the sprocket may be stripped out on the inside and would require replacement, or, that there is something stripped inside the gearcase. If you look at the diagram, the motor shaft is parallel with the handle. So to drive the sprocket gear that drives the chain, they use gears inside the housing to turn the sprocket that's at a right angle to the motor shaft. Do you follow me? It would appear from the parts diagram that if it is those internal gears, that it would require replacement of the whole motor/gear assembly ...... probably as expensive as a whole new saw!
The reason that the sprocket turns without the chain on is that there is evidently enough friction between the shaft that the sprocket mounts on, and, the sprocket. But not enough of a connection to drive the chain.
To check further, leave the saw unplugged, and use your finger to try to turn the sprocket. If it turns by hand like that, it would indicate that something is stripped out as I said. To see if it is the sprocket, remove the "Retaining Ring, 5/16" that is shown in the diagram, and inspect the inside of the sprocket. If that appears good, then it would be an internal problem and probably not worth fixing.
Ed
Oct 31, 2013 | Remington 111409 - 01 6" Branch Wizard...
Looking for belt drive 2042 rail sprockets
Notes on replacing drive sprocket on Genie 2042 belt drive garage door opener.
The unit originally came with a cast metal sprocket disk with a plastic sleeve insert that formed the sprockets themselves. The plastic insert's sprockets shattered when I tried opening the garage door that had frozen shut with ice. Genie's service assistant was of no help, as she suggested that I remove the entire rail then call them back. Removal of the rail was totally unnecessary. I purchased an all metal sprocket designed for the 2042 from an on-line supplier. Neither the owner's manual nor on-line instructions were available to assist me. I followed these steps:
    1.With the door open, loosen the tension on the belt by turning the bolt in the tension assembly located on the rail opposite side of the motor. Slide the belt off the pulley and let the belt hang.
    2.The sprocket housing is located on top of the motor. Unscrew the two Phillips screws that hold the sprocket housing onto the motor assembly.
    3.Using a screwdriver, force the cover up. The cover is on a hinge-like appendage that is riveted onto the rail frame. With the housing pried up, the belt and sprocket can be seen.
    4.Pull the belt out of the housing to allow the old sprocket to be removed. Be careful to locate the black plastic bushing/spacer on top of the old sprocket and save it for the new sprocket.
    5.Install the new sprocket and bushing/spacer into the motor shaft along with the belt.
    6.Replace the two Phillips screws on the sprocket cover.
    7.Place the belt back on the tension assembly and tighten to manufacturer's specifications.
    8.If the motor won't run from the wall switch, the up/down limits need to be reset. The motor will move the garage door up and down using the control buttons on the bottom of the motor unit. Follow the manufacturer's instructions on setting the up/down limits, which include holding the "set" buttons for over 5 seconds once the garage door is in the desired up and down locations.
Mar 29, 2013 | Home Security
Motor runs, but chain does not move
check to see if the chain is on the sprocket to do this you will probably have to remove the side cover on the saw if chain is on sprocket and still will not move then you may have a sheared key in the key way if this saw has one, if it does you should be able to see the key way on the end of the shaft coming out of the motor. there should be a nut that holds the sprocket in place if that nut is loose and the shaft is splined instead of having a key way the the sprocket could slip while the motor is turning.
Feb 25, 2011 | Remington Electric Chain Saw
Handa nighthawk 700 S starter does not ingage motor
There is a one way clutch that grabs onto a smooth cylinder on the side of a large gear inside the motor. The smooth barrel surface is damaged or chattered so the one-way clutch will not grab on the side of what Honda calls the "starting sprocket". A chain connects the starting sprocket to a smaller sprocket that has the starters spline plugged into it. The chattered surface does not allow the three small barrels of the starter clutch to grab and turn the motor over. The sprocket runs about $70 and the gasket runs about $30. This is an internal motor part so you will have to take apart the motor to get to it. If you go to bikebandit.com you can look at the microfiche for the motor and see the parts you are looking for.
Sep 27, 2010 | 1985 Honda CB 700 SC Nighthawk
Starter runs but does not turn the moter
There is a one way clutch that grabs onto a smooth cylinder on the side of a large gear inside the motor. The smooth barrel surface is on the side of what Honda calls the "starting sprocket". A chain connects the starting sprocket to a smaller sprocket that has the starter spline plugged into it. To replace this you will have to unbolt the motor and at least rotate it far enough to remove the rear cover. The chattered surface does not allow the three small barrels of the starter clutch to grab and turn the motor over. The sprocket runs about $70 and the gasket runs about $38.
Sep 09, 2010 | 1981 Honda GL 1100 Innerstate Gold Wing
Electric Chainsaw - chain stops when you try to cut!
Remove the bar and chain--check the sprocket and shaft for any mechanical damage. Try to turn the sprocket by hand in a CCW direction, does the shaft move with it? Does it seem to turn the motor? If the sprocket and shaft seem ok, then you may have a damaged gear (likely plastic) within the gearbox. Hope this helps!
Jul 09, 2010 | Black & Decker Garden
Bissell Proheat 2x Series 8920 - Brush Belt Metal Shaft Sprocket won't turn
Most likely the brush motor is bad and not turning, part #2036757, would sell for around $23. To get to it, start taking out screws on the top cover, that motor is under the that top access cover.
Jan 22, 2008 | Bissell 8910 ProHeat Clear View Upright...
McCulloch 16" Electric Chain Saw 35 HP Logo
109 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
