Question about Emerson EWF2704 TV
I broke the cable connector off the back of tv. how do i repair it
  • 666 Answers
It would require a tv technician and some sauntering same thing happened to me I only use rca inputs on it now repair cost was priced higher than tv was worth
hope this helps
Robb
Posted on Apr 25, 2010
The cable connection on my tv broke off how can I connect back to the cable
On most TV sets, the cable connector (also called an F-connector) is just press-fitted into the metal housing of the tuner (which selects the channels). It's not very strong mechanically and is pretty easily broken by tripping over the cable, moving the TV if the cable is too short, or often by cable technicians who overtighten the cable connection with a wrench.
The good news is that this can be fixed. There are two ways. The simple method is to replace the tuner. It's quick but costly as a new tuner may run $100. The second way is to replace the broken-off F-connector. On some sets it's possible to do this without removing the tuner, but not always. This repair may take a little more labor time, but saves the cost of the tuner.
Either way, this is a repair that's best left to a professional. Without the soldering skills and equipment needed, it's possible to do major damage to the TV and tuner circuit boards. I would recommend getting an estimate for the repair from a shop in your area. Yes, there are still places that fix TVs, but they are getting scarce.
Another possible "fix" is to forget about using the TV cable connection and use a VCR or DVR to tune the channels, and just use the TV's video and audio inputs. It doesn't repair the TV, but it gets you back onto the cable.
I hope you've found this helpful. Thanks for using Fixya!
Jan 31, 2010 | Samsung TXM3297HF 32" TV
Cable input jack bronken off
Actually I just repaired one of these "similar" units. If you remove the backing of the tv, unpluged of course, Theres a panel facing you if you are looking at the right side of the TV. This panel pops off easily with a light prying motion all around. You'll see where the connector broke off and can solder it back together with a small pin type tip. Solder the center pin to the center probe first,hold in place with needle nose pliers. 2 people are better than one at this. Then lay down agood bead of solder around the perimeter of the connector. Clean up any solder that may have dropped and put it back together, you'll be ready to go in about one hours time. Let me know how it goes!!!
Jul 25, 2009 | Orion STV2763 27" TV
Cable connector broke off in back of tv
had same problem virtually impossible fix if broke off if you have rca plugs use vcr thats what i did!
Jun 30, 2009 | Televison & Video
The female cable connector on the back of the tv broke off
yes,you could also use RCA cords from the cable box to the tv and bypass that by selecting the video channel that you hook the rca's to
Jun 02, 2009 | RCA TruFlat 27F520T 27" TV
Cable connection in rear of TV broke off.
This problem will have to be taken or shipped in to a service center for repair or replacement of the cable connector on the main board. The telephone number for Insignia customer support is 1-877-467-4289. and the website is www.insignia-products.com. You can also call the Best Buy customer support telephone number. 1-888-237-8289. Give them you make and model number of television and the problem you had with the broken cable connection.They will be able to tell you how you can get service for your television. I hope this information helps you with your problem.
May 02, 2009 | Insignia IS-LCDTV32 32 in. Television
In ANT connector broke off
If you have cablebox, use RCA cable(composit) or componentcable to hook up. you will see better picture than repairing connector back on.
Mar 25, 2009 | iLO 3200 32 in. LCD Television
Main cable connector broke off back of TV
Maybe so. Sometimes the connector is fed by an RCA connector which just plugs in inside the TV and sometimes it needs a little solder work. Sometimes you have to solder on the circuit board and if it's a multi-layer board you want an expert to do it but from the manual it doesn't look like that is the case with your TV.
I'm pretty sure Radio Shack stocks such connectors with maybe a little hardware to get the fit right.
Dec 17, 2008 | Televison & Video
Sanyo tv coaxi wire broke
Let me guess you have broken off your I.F connector ,this is what you connect your cable to on the back of your set,if this is what you are talking about ,you will need to try and repair IF connector or replace your turner.sometimes when this piece is broken off turner is also damaged,there for you have to replace turner.
Dec 09, 2007 | Sanyo DS27910 27" TV
Tv repair
Yes, it is worth repairing. Replacing the F connector is a very simple thing, and as long as nothing was forced into the hole left by the missing F connector, the repair should run about $40.
Sep 10, 2007 | Televison & Video
Emerson EWF2704 TV Logo
112 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
