Question about GE (PSS26MSRSS) Side by Side Refrigerator
I have a side by side refrigerator and temperature is too high
I have a side by side refrigerator and temperature in both sides is higher than the preset temperature and will not reduce what can I do
  • GE Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerI have a side by side refrigerator and temperature - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Apr 27, 2010
Error code 5E
The means the temperature is higher then the set temp. Check the door and set the temp higher
Mar 26, 2013 | Samsung RS2630SH Side by Side Refrigerator
Freezer is freezing about 25 degree,but the ref. will not get below 40 degree.
It's quite normal if freezing is not reach on 40 degree, it's already high temperature. Remember the lower the temperature setting the higher the freezing of refrigerator, the higher the setting the lesser the freezing.
It's simple as that friend. Good luck!
Jun 12, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
What should the pressures on the low and high side of the air conditioner read ?
low side should be about 30 psi at idle speed, high side 120 to 180 psi depending on ambient temp. higher temp, = higher pressure, as you increase engine rpm to say 1000 low side should drop to 10 to 15 psi & high side should increase about 30 psi. If high side goes over 280- 300psi you have contamination (air) in system or over charged with refrigerant. you will need to recover freon, evacuate & recharge system with proper amount of refrigerant. If the low side drops below 0psi or into vacuum then the refrigerant level is low, you will have to check for leaks , repair leaks & refill refrigerant.
Hope this helps
Paul T
Jun 01, 2011 | 1997 Chevrolet Suburban
Freezer Freezes Refrigerator Barely gets cold
Hello there:
Here is a few things to check to make sure the referigerator is working properly.
The first thing to check is the overall internal refrigerator temperature (see the Appliance Accessories section for a refrigerator/freezer thermometer). The proper temperature should be between 35 and 42 degrees. Here are some things to try: If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly. If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf. If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan. The refrigerator never cycles off The thermostat cycles the refrigerator on and off. The refrigerator normally runs as long as the temperature inside the refrigerator is higher than the set temperature. If the temperature inside the refrigerator is cold enough and the thermostat still does not cycle off, the thermostat may be defective. If so, you need to replace it, because it cannot be repaired. If the thermostat is not defective, you may have a problem with the sealed (refrigerant) system,
Apr 14, 2010 | KitchenAid Architect 24.5 Cu. Ft....
My refrigerator is freezing my food.
i think your temperature meter is not working correctly try to measure temperature of the food articles and then relate it with the 40 deg. F and measure deviation and set it at higher value accordibgly
Feb 25, 2010 | LG LSC27931S Side by Side Refrigerator
Maytag sidebyside refrigerator, refrigerator side
I WOULD INCREASE THE TEMPERATURE SETTINGS TO A HIGHER SETTING. Oh ABOUT THREE OR FOUR DEGREES SHOULD BE ENOUGH
Jul 19, 2009 | Maytag MCD2257HE Side by Side Refrigerator
Kenmore side by side coldspot, model 5687
I'm not trying to be a smart ***,but a lower temperature setting would make it colder.Try using a higher temperature setting.If this was just a poor choice of words you may need to replace your thermostat.
Jun 18, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
100 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
