Question about Paradyne (6218-A1-200) Wireless Router (6218A1200)
My paradyne has no IP ADDRESS, HOW DO I PROGRAM THE IP ADDRESS INTO WINDOWS 7
  • 62 Answers
Start menu
-search programs and files
-run
-cmd - enter
-ipconfig (press enter)
-you'll see defult gateway, thats the ipaddress of you paradyne.
Posted on Apr 27, 2010
How to Find my IP Address (Windows 7/8, Windows XP)?
If you go to your windows search box and type in CMD you will be defaulted to dos and then you can type in : IPRelease command and then type in : IPRenew and your new IP address should show in dos. Hope this helps.
Oct 19, 2016 | Computers & Internet
Paradyne 6218
The router must provide new internal IP's. Make sure it is set to DHCP. IPs are never shared.
Mar 29, 2013 | Paradyne (6218-A1-200) Wireless Router...
How to reset Paradyne (1740A1400) Router ?
Hi Samsungvt!
You will have to access the Web Interface of the Paradyne Router to reset it to Factory Defaults.
First, connect your PC to the Paradyne Router. Check your IP address is in the range 192.168.1.xx (xx = any number from 1-254). Open your web browser, type 192.168.1.1 then press enter. Enter the default username and password (shown below) to access the router's web interface. On the left pane, click Erase and Reboot; this will reset the router to factory default.
Default IP address is 192.168.1.1
Default Username and Password: root
Let me know if there's anything else...
Anthony
Jun 21, 2010 | Paradyne (1740A1400) Router
What is the default ip of the paradyne modem6381
The default ip is :192.168.1.1
The default User-name and Password is : Admin
Some model came with default ip 192.168.0.1
Subnet to use is 255.255.255.0
Ok make sure you are using an ip address with the same range.
That is you can set your ip 192.168.1.x where is 2 to 252
ok try this
Jan 22, 2010 | Paradyne 6381 ADSL2+/ReachDSL Router...
What is the ip address of paradyne 6381 a3 300 router
To configure your router, open your web browser. Type the default IP address (http://192.168.1.1) into the Location field of your browser and press the Enter key. A Login screen will appear. Use the below to log into your router.
The default IP address is 192.168.1.1
The default user name is Admin
The default password is Admin
Both are case-sensitive.
Jan 08, 2010 | Paradyne ADSL/R 6381 Router (6381-a2-200)
Paradyne 6218 12 200. With dynamic IP address, this modem/router will assign addresses to both fixed all 4 ports, and wireless laptops. How do we program it to do the same when ISP has assigned a static IP...
If desired change the IP address or Gateway will please right click the name (My Network Places), then right click (Local Area Connection), (Properties), have at the bottom to select, high light the name (Internet Protocol (TCP / IP), Lift Click the Properties, to trim after you customize IP add and modify the following required.Good Luck
Jul 23, 2009 | Paradyne (6218-A1-200) Wireless Router...
How to configure my paradyne 6381 router
Go under LAN setup and enable NAT and Firewall services. Then go to LAN configuration to enable the dhcp server. Set the Start IP range and ending address.
Feb 24, 2009 | Paradyne 6381 ADSL2+/ReachDSL Router...
Port forwarding
try to use another port number aside from 8080, like 3000 or 5000. make sure that the ip address set on the router is the ip address of your camera (note: it should be set to static).
hope this'll help you
ciao
Oct 22, 2008 | Paradyne 6211 ADSL2+ Router (6211I1200)
Paradyne 6218-12-200 won't connect all computers
A public IP address is usually assigned to the WAN port (outside/public side), which is how your router is conected to your Internet provider service.
A private IP is always assigned to the private network side (LAN = Inside). Unless you are hard coding your IP addressing on each of your devices, you will need to have DHCP enabled in your router with enough user IPs for your devices (more than 1).
Apr 11, 2008 | Paradyne (6218-A1-200) Wireless Router...
IP ADDRESS TO OPEN ROUTER
assuming that you are plugged into your router and it has dhcp enabled...
IN WINDOWS XP:
go to start menu --> run --> type "cmd.exe" in the text field (a black window should pop up) --> in the black window type "ipconfig" (it will display your current network settings) --> look for where is says "Default Gateway" as the number to the left of it is your routers internal ipaddress
Apr 04, 2008 | Paradyne 6381 ADSL2+/ReachDSL Router...
Paradyne (6218-A1-200) Wireless Router (6218A1200) Logo
347 people viewed this question
Top Paradyne Computers & Internet Experts
Michael Galve
Michael Galve
Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
