SOURCE: Looking for mower deck belt diagram for a Husky
THAT NUMBER IS NOT COMEING UP CAN YOU SEND ME THE NUMBERS FROME UNDER THE SEAT
SOURCE: bolens garden tractor will not start
At this age, the engine will have points under the flywheel. If the coil is OUTSIDE the flywheel, forget fixing it and just replace the coil with a later solid state unit, then cut the points wire.
If the coil is UNDER the flywheel with the points, you'll have to stick with them, but replace them AND the condenser. These parts (and replacement coils) are still available, but decide quickly - Tecumseh have gone, and when all these old parts are used up, that's it.
SOURCE: Changing the oil filter on a lawn tractor
If it is a screw on type oil filter, apply a film of oil on seal, then screw on. If you want to, go ahead and pour some oil in the filter, in my opinion the oil will circulate faster if there is some oil already in the filter.
SOURCE: we have a huskee supreme
If you found the drain plug, Normally find the correct wrench, loosen the plug remove the plug, drain the oil into a container. Open the oil filler cap to vent, (could be a vacum in engine). If the oil is really cold it may run slow like molasses. Ussually it is best to drain the oil when engine is hot.
righty tightly lefty loosey. turn wrench counter clockwise to loosen
