Technika tv stand by button just flashes red and cant turn it on at all
    Problem Solver:
  • 7 Answers
If this is an lcd television ?it is the psu than needs 2 capacitors replacing they are 15nf 400v, i replace them with 15nf 1000v if it not an lcd this will not be your fault.
Posted on May 01, 2010
Panasonic TX-L42S10B has power but won't turn on
ok, this may be a silly question but when you turn it on and it starts flashing red, have you tried pressing the stand-by button on the remote. if a tv has been put on stand-by by the remote, and is then switched off by the set, when the set is turned back on it is still in stand-by mode and you need to press the stand-by button on the remote.
other than that I don't know.
Nov 08, 2013 | Panasonic TXL42S10B 42 in HDTVReady TV
Tv light flashing cant turn tv on
Sounds like your TV's projector lamp has burned out, ususally the TV provides you a diagnostic by flashing the power or stand by button in red or green. So look up your TV online and search for the projector lamp.
Oct 10, 2013 | Boston Acoustics TVee Model Two TV...
Have purchased a Technika TK81R universal remote control to use with my Goodmans LD 2667D but canot get it to work any idea what to do?
Setup codes for Technika TV with universal remote contol are:
0031 0004 0005 0009 0051 0053 0105 0109 0170 0000 0174 0001 0008 0012 0042 0058
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
    Code Search Method
    1. Manually turn on the device (TV, VCR, etc.) to be controlled.
    2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
    3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
    4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
    5. Press and release MUTE to install the code. The indicator light goes off.
    Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Apr 27, 2012 | Televison & Video
Lost 4 digit code for Technika 1stba08 freeview box
Hello
Four digit universal remote codes for Technica are
Direct Code Entry
May 26, 2011 | Televison & Video
Technika flat screen: Will not switch on, the blue standby light just flashes
Technika flat 32 screen: Doesn't not switch on, the blue standby light just flashes.
Apr 14, 2010 | Televison & Video
Faulty technika tv
A good way to test if a remote is working is to get a normal phone that has a camera on it.
put the camera option on the phone and point your remote at the camera phone. Press the button you believe to be faulty. whilest looking through the phone. if you see a little white light the button is working fine if not try a few of the other buttons to see if its the hole remote that is at fault.
the way this works is camera phone's dont like IR (infrared) so this will show as a little white light on your camera phone.
if it is the remote you could always buy a sky digibox remote. as the Default code will work your Technika tv. ie volume, channels, power, also the help button will change your source/av on your telly.
Hope this helps
Cheers
Little Dish Fitter
Sep 02, 2009 | Televison & Video
Technika tv cant get universal control to work, no codes in back of book for Technika and it doesnt find it when i do an automated search ?
1 turn on the tv
2 press the code button on the universal
3 then press and hold the power button until the tv turns off, and that's it
Jul 21, 2009 | RCA Universal Remote Control
Technika sky code volume needed 42-502
0246 is the code 1st cover the top of the remote with your hand press TV you can now move your hand, now press and hold select and the red button togeather the remote light will flash twice enter the code 0246 then press select cover top again and press SKY button it should now control your tv
Jun 03, 2009 | RCA DIRECTV Satellite Remote Control
CANT TURN TV OVER USING REMOTE CONTROL
Hi, use another set of batteries.
May 15, 2009 | Televison & Video
Technika tt- 706 universal 2 in 1 remote
turn the tv on. hold tv and set buttons untill the power button flashes. point the remot at the tv untill the tv turns its self off. press any button on the remote. turn the tv back on and test it.
Oct 10, 2007 | Televison & Video
Televison & Video Logo
615 people viewed this question
Top Televison & Video Experts
Electro Med Services...
