Question about Cycling
1 have a mid 90's bike with a Shimano Acera X that will not shift
1 have a mid 90's bike with a Shimano Acera X , St-M290 Dual SIS at the front and a Acera X 7 speed, St-M390 for the back.
After serveral years not being able to ride this bicycle (health reasons), I wanted to use ist again, but I am not able to shift into any gear, besides the ones that are on. the shift indicators don't look into any other numbers, etc. and the grats don't change either. How can I adjust this to get the thing going again?
My solution on the same shifters was to lube the grippers on the levers, they did not engage but after moving them around and lubing they started to grip and problem fixed.
Posted on Jun 09, 2010
    Brigadier General:
  • 8,546 Answers
It sounds like you're saying there is a physical reason the shifters won't move the derailleur(s). If the bike has truly been idle for a long time it's likely the cables have rusted inside the cable housing. Bottom line: a professional bike shop tune-up will bring it all back to working order.
Or if you're adventurous and have all the special tools, surf over to Parktool.com and look around. They have excellent instructions for most everything and the tools to make it happen.
Posted on Apr 25, 2010
Testimonial: "Very speedy help here!"
What kind of components do I need?
Most bikes have Shimano shifters & deraillers; SRAM is the other main vendor. Shimano makes a wide range; the following table attempts to describe these and presents my best guess of where the SRAM line fits in: Model Quality SRAM Equivalent?
SIS, Tourney (or just says Shimano) Mainly designed for riding around the neighborhood
Altus Sufficient for paved or very easy trails; avoid hills 3.0
Acera Slightly better, but won't shift well under stress; capable for easy casual riding 4.0
Alivio Minimal capable for recreational riding; will handle some hard riding 5.0
STX / Deore Entry-level components for hard riding; tough & reliable 7.0
LX The minimum standard for hard riding. Reliable & responsive 9.0
XT More responsive than LX, but still reasonable tough 9.0SL
XTR Light, responsive racing components; tend to be quite expensive; often sacrifices toughness for responsiveness X.0
Look for a component set that fits your expected riding style.
Note:The numbered SRAM components aren't compatible with Shimano components. SRAM does make grip-shifters that are Shimano-compatible.
There are many other manufacturers that specialize in various components (Avid, Cane Creek, Race Face, Hope) and make great ones. Ask the LBS personnel for a comparison if you see a brand you don't know. Also, you can use the same test as forks above: if its not sold separately, its probably more questionable. If you're getting a full-suspension bike, make sure you get a good rear shock as well (it'll probably be something other than SRAM or Shimano).
Dec 16, 2010 | Cycling
New shifters for deore xt x7 delrailer
Shimano make an "EZ fire" which is an integrated shifter/brake lever combination and cheaper than buying seperate shifters and levers.
e.g.
http://www.tredz.co.uk/.Shimano-Acera-8-Speed-EZ-Fire-ShiftersBrake-Lever_24339.htm
Feb 07, 2010 | Shimano Deore Xt Thumb Shifters 7...
Need advice for Shimano ST-7900 nameplate replacement
Don't know if you have an exploded view diagram of the levers . If not you can download from http://techdocs.shimano.com/techdocs/index.jsp
In the road bike drop down list select Dura-Ace, go down to ST-7900 and select document EV-ST-7900-2874. I don't advise you to take mech apart unless you have special tools and bags of experience handling complex mechs. However you will see that name plates are held by single screw which should be no problem.
Nov 19, 2009 | Shimano Cycling
How to adjust shimano acera x ST-M290 shift levers, They do not to index?
There is info at this site:http://www.parktool.com/repair/readhowto.asp?id=117 Also info around this site:http://sheldonbrown.com/gearing/index.html
Aug 30, 2009 | Cycling
Adjust Shimano Acera back derailleur
There is a limit screw on the body of the derailleur that you have to back out slightly. You can tell which one of the two it is by watching carefully as you adjust it. It takes a phillips screwdriver.
Aug 01, 2009 | Cycling
Cycling Logo
1,551 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
