Question about Kenmore 24 in. 16352 / 16354 / 16359 Built-in Dishwasher
Soap dispenser cover will not open when in wash mode
Kenmore diswasher, model #665.16354300 Soap dispenser will not open when washing dishes in any wash mode. How do you fix it? Does this part have to be replaced? How do you get the part off?
    President:
  • 949 Answers
First be sure nothing is blocking the dispenser from opening like the rack broken or an attachment to the rack out of place. If this is all good then clean good around the latch for the door, make sure soap or anything else is not causing it to stick. If all this is good you will need to replace the dispenser.
The part number for the dispenser is 9744543.
To replace it you will need to turn the power off and open the door of the dishwasher, remove all the screws that are on the inner liner on top and the 2 sides. This will allow the the inner door panel to separate from the outer door panel. You should be able to see the screws on the back side of the dispenser from there, 6 total. If the coil (the piece the wires hook to) is melted then I would suggest replacing the control board in the console at the same time as the dispenser, this would be a very rare occurrence but if it is melted it could have caused damage to the control.
Let me know if this helps
Posted on Apr 25, 2010
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite 665-16959000 dishwasher - soap door
It appears your dispenser wax switch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Dishwasher - soap dispenser won't open while washing dishes
A simple was motor is used to open that.
This video shows how to change a door latch but the dispencer basically does the same thing. HERE
Jan 15, 2010 | Kenmore 64802 Top Freezer Refrigerator
Soap dispenser does not open during wash
Well you can please follow the below steps -
1. Remove any dishes in the dishwasher. Unhook the dishwasher's dish trays or racks from their tracks, and set aside. Empty the soap dispenser if it contains unused soap that failed to dispense. Use a wet rag to wipe down the interior of the dishwasher, as well as the inside of the dispenser.
2. Close the dispenser, and shut the dishwasher door. Turn the dishwasher on to a manual setting, then stop it and open the appliance. Check to see if the dispenser is open. If it is, continue to Step 2. If the dispenser is closed, skip to Step 4.
3. Switch dishwasher soap. Some dishwasher dispensers have difficulty with dry or liquid dishwashing soap, depending on the make and model of your dishwasher. Incompatibilities typically result in the dispenser sticking shut, which explains why the dispenser opens when empty. Switch to liquid soap if you are using dry powder soap, or vice versa.
4. Check the dishwasher soap dispenser's spring. The spring is located behind the dispenser top's hinge. Consult your dishwasher's original manufacturer's manual or user guide to find a replacement spring. Pop the old spring out with a screwdriver, and replace with a new spring. This should resolve any issues related to the dispenser failing to open.
Please post comments if you need more help or information..........
Good Luck!!
Thanks
Jan 08, 2010 | Kenmore Dishwashers
Soap does not dispense from cup.
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 07, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
Dishwasher not washing and leaving residue on dishes
We have the same problem with the soap dish. I found that we have to be careful how the dishes are in the bottom rack. Sometimes the dishes will block the cover on the soap dispenser and keep it from opening.
Jul 12, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
Soap dispensing problems on a kenmore dishwasher elite 577-0
is your soap door open when this happens if it is then make sure there's no water or other liquids in the dispenser from loading the washer one tablespoon of water in there will clump up the soap and it won't drop when it pops open
Dec 25, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
OLD KITCHENAIDE MODEL KDI-20 LEAVES SOAP GRANULES ON DISHES.
I have this same problem, plus the pre-wash soap dispenser doesn't open sometimes even though a service guy replaced that. Could he have replaced just one side and not the other? this dishwasher also has a new motor. sometimes it washes beautifully. but other times it does not. even if both dispensers opened.
Dec 04, 2008 | KitchenAid Dishwashers
My soap dispenser does not open properly and soap streaks on my door and detergent is always left over in tub no dishes are cleaned any suggestions?
ck water level ..i assume you mean diswasher water should be almost to bottom of float..if water ok are you sure main wash motor working
Aug 04, 2008 | Maytag Washing Machines
I just bought a used Kenmore standalone dishwasher and ran it for the first time. The dishes on the top did not get clean and the soap did not come out of the closed soup dish. at one point I took a shower...
The inlet filter is probably clogged. Try letting it fill up. Open the door to stop it right after it starts to wash Pour a gallon or two of hot water in and see it it works better Stop and do this everytime it goes to fill up. If the door opens , soap is used and dishes are clean ,clean the filter in the fill valve and possibly replace it. or the whole valve. (around $25) The soap door may be a seperate problem. I don't remember if Kenmore uses a spring or a small heat element to open the soap dispenser. Try cleaning it really well, shut the dispenser, open the door and turn the timer very , very slowly and watch to see if the dispenser opens. (WIth the door open the dishwasher will not run, but leave it plugged in.) It should open sometime during the cycle.
Jun 29, 2008 | Dishwashers
Dishwasher
If you are you using a liquid soap or packets that will be the main problem.If your unit fills with water circulates the water and drains the water,and also heaters are working then you probally need to change to cascade powder soap.The film on the dishes is soap.The unit has so much build up in it that when it gets to the rinse cycle it is rinsing dishes with soapy water.You need to get 2 medium bowls fill both 2/3 up with white vinager,place one in upper rack and one in lower rack and run unit on longest cycle letting the vinager splash out during wash.do this with no soap and no dishes.Having soft water will allow you to use less soap.
Apr 23, 2008 | Dishwashers
Kenmore 24 in. 16352 / 16354 / 16359 Built-in Dishwasher Logo
165 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
