Question about Starbucks Barista Burr Grinder
How to clean burrs - Starbucks Barista Burr Grinder
    President:
  • 1,618 Answers
Easiest way run a tablespoon of rice through the grinder.
Posted on Apr 27, 2010
I took everything apart to give it a good cleaning and now all settings produce a very fine grind. Any thoughts?
I had the same problem with too fine a grind when I took mine completely apart to clean (including the lower burr). The solution I finally came around to was to further tighten the star-shaped screw which holds the lower burr assembly in place. I had originally just tightened it until the lower burr until the lower burr assembly started to turn with the screw, but that wasn't enough. So I held the assembly in place and tightened the screw further and I'm back to my previous grind coarseness/fineness.
Jan 13, 2014 | Jura Capresso 560 Electric Burr Grinder
How do I clean my burr mill (Models BMX3, BMX4, BMX5 and BMX6)?
Clean your burr mill before using it for the first time. Then, to ensure optimal mill function and durability, clean it regularly following these simple steps.
  1. Always unplug your burr mill after use and before cleaning.
  2. Open the hopper lid. Empty any whole beans from the hopper. Remove the top burr mill by rotating it clockwise. For better results hold the grind setting button while rotating the burr mill clockwise. This will allow you to clean the grinding wheel and the grinding compartment.
  3. Clean the interior recesses with a soft brush. Note: Never use water or liquid for cleaning the lower grinding section of this appliance. BRUSH NOT INCLUDED.
  4. Wipe the whole bean hopper, its lid and the mill exterior with a damp cloth.
  5. The ground coffee chamber and lid can be washed in mild detergent and water. They both are top rack dishwasher safe. Do not immerse the mill or the whole bean hopper in water or any other liquid or place in dishwasher. Use only non-abrasive cleaners to remove stains.
  6. After completely drying the whole bean hopper and top burr mill, replace the burr mill in position by aligning snaps with receptacle and rotating counterclockwise to lock it in position. For better results, hold the grind setting button while rotating the burr mill counterclockwise. Once the burr mill is in position, pull gently to check it is properly locked in position. If the burr mill comes out, repeat this step again.
  7. Replace the ground coffee chamber and lid, making sure both snap securely into place.
  8. Fill the hopper with whole beans.
Sep 02, 2011 | Bunn NHB Coffee Maker
How to change burrs
1 take the bell(bean container) carefully out. 2 disassemble the upper holder of burr 3 you will see now the burrs, clean good coffee remains than disassemble the burrs 4 after disassembling burrs clean good the lower and upper burr holder. 5 carefully switch on the grinder tan switch off(few seconds) during lower plate is rolling touch with marker the surface of burr holder very softly, if it is ok you will have complete circle / if it is deformed you will have incomplete circle( that you must compensate with letter tape ) after each correction you mark the burr with marker to see did you achieved perfect result. once you have lower burr in place you screw bolts in upper bur holder and assemble it back in his place.
Feb 11, 2011 | La Pavoni Jolly (PA-JL) Electric Burr...
Rocky has a tumbling (unbalanced) sensation when grinding you can feel and hear. Seems less if you back off grind # to 20 from 8. Been using 8 for a year with no problem before today.
  1. take the bell(bean container) carefully out.
  2. disassemble the upper holder of burr
  3. you will see now the burrs, clean good coffee remains than disassemble the burrs
  4. after disassembling burrs clean good the lower and upper burr holder.
  5. carefully switch on the grinder tan switch off(few seconds) during lower plate is rolling touch with marker the surface of burr holder very softly,
  • if it is ok you will have complete circle
  • if it is deformed you will have incomplete circle( that you must compensate with letter tape )under the burrs you apply the letter tape
  • after each correction you mark the burr with marker to see did you achieved perfect result. once you have lower burr in place you screw bolts in upper bur holder and assemble it back in his place.
Aug 20, 2010 | Rancilio (RAROCKYND) Grinder
Burrs spin but no grinding
Try this, remove the bean hopper, and vac out the burr chamber, then put 1 tablespoon white rice in the burr chamber and cover with hand and turn grinder on, if the rice grinds, then your grind might have been set too fine. Turn the grinder towards fine until you can barely turn the burr nut, you will feel them touching, then turn course about 16 notches (do not use numbers, use the small notches around the rim), that should give you a great starting point for your grind.
May 20, 2010 | Mazzer Mini Burr Coffee Grinder
Oily beans seem to have clogged our coffee grinder up. What can we do?
Rotate the bean hopper counter clockwise until it stops. Lift it off. Remove the outer burr with the 2 wings and clean under the burr. Clean the opening going to the chute for ground coffee(inside where the burr was).
Install the outer burr. Install the bean hopper. Rotate the bean hopper to the French press grind (coarsest) and operate the grinder. This will clean the burrs and the passages. If it starts to clog, repeat the last part to clean the burrs and passage. It must be grinding to go to a finer setting, but you can go to a coarser setting any time. Another thing. Turn the grinder upside down (empty) and rotate the bean hopper back and forth to clean the threads of the adjusting burr..
Dec 20, 2009 | Solis Maestro Electric Burr Grinder
I can't remember the simple key to disassembling the Solis Maestro for more thorough cleaning. I need to get beyond the top burr removal stage.
Hi
Rotate the bean hopper counter clockwise until it stops. Lift the bean hopper out. Remove the outer burr with the wing-lets. Can go back in either way. Clean with air or vacuum out grounds. Use small brush to help clean grounds. Reinstall burr. Line up notches of the bean hopper with shell ( large tab in large slot, and small tab in small slot). Rotate bean hopper clockwise a small amount and test.
Nov 10, 2009 | Solis Maestro Electric Burr Grinder
Krups GVX2-12 Electric Burr... Problem:
First, unlock and unscrew the upper burr carrier. Clean and check the upper burr by gently running your finger over the teeth in the cutting direction. It shoild feel moderately sharp. If it feels very blunt, look at the teeth under a good light. If you see a substantial "flat spot" at the top of the teeth, probably the burr set will need replacement.
For the bottom burr, clean carefully its teeth, and the entire area in which it is housed. Include the outlet orofice as well. You may find a lot of oily deposits within here, so just clean them off as best as possible.
When all is clean, insert the top burr holder back in place. Screw it down until both burrs touch, then back it off (say) 1/4 turn, and lock.
Put some beans in the top, and switch on. Adjust the top burr until the desired grind is obtained.
The ground coffee should feel like a coarse sand when close to the desired grind size.
Mar 13, 2008 | Krups GVX2-12 Electric Burr Grinder
Cleaning La Pavoni Burr Coffee Grinder
You'll need to remove the hopper and grind out all the beans. Then, with the lock tab depressed (if it has one), unscrew the grind adjusting collar out of the body. Once it's out, there are three screws (sometimes only two) holding each burr. Remove screws and separate the burrs. Clean away!
Be very careful putting it back together so that you don't cross-thread the collar into the body. Clean threads can help this.
Jan 02, 2008 | La Pavoni Burr Coffee Grinder - Black
Coffee Makers & Espresso Machines Logo
175 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
