Question about Honda Mmd 5000 Watt Generator W/ Engine Ngk 6000H
How much is a 2005 mmd equipment ngk-7000h generator worth?
No spark
Hi, Check the on/off switch is set to on. replace sparkplug check magnedo. Good luck.
Aug 04, 2011 | Honda Mmd 5000 Watt Generator W/ Engine...
I need to know what gauge wires black and red for battery to generator
This is what I assume is for the starter motor for the generator. I would use for this a #8 welding wire style cable. This will supply enough power for starting.
Jan 30, 2011 | Honda Mmd 5000 Watt Electric Start...
Honda 5000 generator clear oil out leaking thru air intake
There is supposed some oil in there. There is a tube to the carb intake that allows flow like a pcv valve
Oct 05, 2010 | Honda Mmd 5000 Watt Electric Start...
My engine is overheating seriously, what is responsible?
Plugged air filter, plugged exhaust or oil is old or not light enough wait.
Sep 02, 2010 | Honda Mmd 5000 Watt Generator W/ Engine...
I am trying to connect battery terminals to my EQT generator.
Connect the black lead (negative) to the frame of the generator.
Connect the red lead (positive) to the big post on the starter solenoid. There are 2 big post terminals on the solenoid. Connect the battery positive lead to the one that DOES NOT go to the starter motor.
Dec 26, 2009 | Honda Mmd 5000 Watt Electric Start...
Will not get the gas,and it is getting fire 9hp honda generator
try spraying starting fluid in to carb and crank away,itf it woirks then youi need carb work,if it does nothing then check the spark, then the comprussion, should be over one hundred
Dec 18, 2009 | Honda Mmd 5000 Watt Generator W/ Engine...
No power at outlets
there are fuses located on the gen..check those
Nov 17, 2009 | Honda Mmd 5000 Watt Electric Start...
Engine runs on choke If I take the choke off the engine will die
The Choke's function is to limit air intake till engine reaches opperating temperature.It should decrease to nill if auto.If not then try increasing the idle.Good Luck.
Sep 17, 2009 | Honda Mmd 5000 Watt Generator W/ Engine...
NGK-6000H Generator Field Coil Diode
If the doides have a number on them, goto www.nteinc.com and cross reference them to a good number. Then you can find a dealer on the web site also.
May 11, 2009 | Honda Mmd 5000 Watt Generator W/ Engine...
Honda Mmd 5000 Watt Generator W/  Engine Ngk 6000H Logo
203 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
