Question about Samsung Televison & Video
Samsung 56in big screen lights flashing-cuts off
Samsung 56 inch TV - approx 4 yrs old. Turns on - standby/temp, timer and lamp lights come on. TV stays on for approx 3 mins then shuts itself off. Removed the back, cleaned the inside, made sure the temp. sensor was properly seated, made sure the blue lever on temp. sensor was fully down when back was replaced, made sure lamp housing was properly seated. Tried using an outside fan to cool - left off for 12 hours and turned back on - same problem. I hate to pay for a lamp and it end up not being the problem. Has anyone else had this happen and do you have any other suggestions?
  • 2 more comments
  • hatinsamsung Apr 26, 2010
    Dear TOMBOU300619
    What is a defective cap in the power supply? Is that a part within the TV?
  • hatinsamsung Apr 27, 2010
    Dear TOMBOU300619,
    Thank you so much for your helpful comments. I have a friend who has an ohm meter coming to check the caps in the power supply later this week. It is a SAMSUNG HL-S5086W
    Dear TOMBOU300619,
    Model code: HLS5086WX/XAA manufactured in June 2006.
Theres defective caps in the power supply
Posted on Apr 26, 2010
  • Anonymous Apr 26, 2010
    CAPS ARE IN POWER SUPPLY TELL ME COMPLET MODEL CODE
Samsung tv lights flashing standby/timer lamp
Possible lamp or color wheel---remove the lamp and look to see it is not shattered inside.
May 30, 2012 | Televison & Video
Hello I have a Samsung TV Model# HL50A650C1FXZA I have 3 lights blinking 2 green and 1 red light what is the problem
Hello, I try to help. But your questions not spesific.
Below are conditions lamp indicators that appear blinking and solutions:
1. If Timer and Lamp blinking --> Auto timer on/off was been set, picture will appear ~ 25 second.
2. If Timer and Standby/Temp blinking --> A cooling fan inside the set is not operating properly.
3. If Lamp and Standby/Temp blinking --> The lamp cover on the rear of the set is not installed properly.
I hope that solve your problem.
Thanks.
Feb 22, 2011 | Samsung DLP HL-P5663W 56" TV
Heard a loup pop when I turned the tv on; the timer/lamp/standby/temp lights on the power on button are now flashing; when I pushed the power button again the lamp light on the power button flashes and...
Color Wheel - Pull out the Lamp using a flash light look right into where Lamp was you should see the color wheel turn TV on watch to see if wheel is turning,From what you have said Problem will be the Color Wheel. Encompass Parts Distribution has them 1-800-638-3328
Sep 26, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Please Help. I have a 56" DLP Samsung and the lights just flash
Sounds like the lamp might be burned out. The Lamp should be replaced every couple years. If they are not replaced they will eventually burn out. Replacement is not that difficult and just requires a screwdriver. The lamp is located at the back of the DLP TV on the left side. The lamp can be purchased online from Samsung for about $130 dollars. You might be able to find a aftermarket one for less. Just use your telivision's model number located on the right side of the TV on sticker to cross reference the bulb that is needed or there might be a sticker on the back at the lamp housing that has the lamp part number. And make sure to spend the extra money and get the Lamp with the housing together. You can buy just the lamp for cheaper but that will require you to remove the old lamp from the housing and they are fragile. Much easier installation with the housing/lamp combo.
Jan 12, 2010 | Samsung DLP HL-P5663W 56" TV
My 56 inch Samsung DLP keeps shutting off. I have
Once before I had this same problem and FixYa gave me the solution. When you replace the lamp door, there is a switch inside so be sure the door is put in at an angle so to hold the switch up. It solved my problem after numerous repairmen missed it.
Sep 02, 2009 | Samsung DLP HL-P5663W 56" TV
Live Chat Session
i have 3 lights blinking on my samsung dlp...the lamp light flashes a few times then timer and standby/temp flash....can any1 help
Jan 01, 2009 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
559 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
