Question about HP Computers & Internet
TROUBLE CONNECTING AN HP6988 DESKJET TO WIRELESS ROUTER
  • 1 more comment
  • joaninbend Apr 25, 2010
    I've tried every description in the book that I can think of. I don't have my original driver, so some solutions are not available.
    I have tried using a USB to connect the printer to the computer through a wireless router, using the wireless router IP address and the WPA password, and when I go to print a test page, it will not work.
    Well, I've explained my problem, and gotten no answer. What's the deal????
  • 712 Answers
What is the trouble, anything regarding the connection or installation or softwares?
Posted on Apr 25, 2010
  • Sebin Punnacheril
    Sebin Punnacheril Apr 25, 2010
    Explain your problems please. Don't just say that you are having a trouble.
  • Sebin Punnacheril
    Sebin Punnacheril Apr 26, 2010
    It was 2 a.m here when you added your last comment and so I left hoping that I can contact you today. Sorry for that.
    Well, have the system recognized your printer when connected through the USB port?
I can not get my wireless router to find my or take my ip address
Your wireless router once you connect to it will give out an IP. You can only setup in the router software what your machines MAC address and preset it to be given an IP of your choice.
So in short your wireless computer should find the wireless router via.. SSID and its password then once authenticated your machine will be given and IP and gateway to access your network.
If you are having trouble connecting to the wireless router. Then I suggest connecting to it via the wire first make the needed adjustments and then retry the wireless connectivity.
this link will bring you to the manual for your router http://www.dlink.com/products/?pid=DIR-615&tab=3
GL
hope this helps
Don
Aug 08, 2011 | D-Link DIR-615 Wireless Router
Have install netgear range booster to wireless router but says limited connectivity
This can occur when the wireless adapter has trouble connecting to the wireless router.
It may not get an IP address from the router or the wireless adapter encryption setting didn't get an the encryption authentication from the router.
In this case right click on the wireless adapter on the Task bar and click Repair. This will make the router re-issue an IP address and authenticate the adapter's encryption setting.
Feb 19, 2011 | NetGear WPN111 RangeMax Wireless USB 2.0...
Trouble connecting to router
Make sure SSID broadcast is switched on under wireless settings. You will have to connect via ethernet cable first to do this.
Then, if PC's can see it, once logged in and set to automatic you can turn off SSID if you like.
Personally I leave it on and set high security using MAC addresses so I don't mind if my router broadcasts it's existence.
Apr 20, 2010 | Linksys Wireless-G WRT54G Router
I have a 2 wire wireless router. Both computers
you should your lan to ruter cable install it again carefully.
Feb 20, 2010 | 2wire (1000-400108-001) Router
When attempting to connecting to xbox live..it informs me that it cant obtain ip address from my att 2wire 2701hg-b wireless gateway..cant figure this one out
Shut off your securtiy setting on the wireless router. Some x-box's had trouble connecting with encription on the wireless.
Nov 14, 2009 | 2wire Computers & Internet
I have just set up wireless internet and am having trouble connecting my GT704WG, every time I connect it to the modem I cannot get online? How do I properly set this up?
Place your modem in bridged mode First and then try connecting the Router.
Ensure that all the settings for the wireless are entered correct.
Check the SSID and Security Mode and configure properly
Sep 24, 2009 | Actiontec GT704WG Wireless Router...
Connecting a brother hl2170 wirless printer to a linksys wrt54g
Take note all the wireless settings of the router first. Now go to the printer and Press Menu/Settings, look for wireless setup wizard. It should find the network, highlight it and connect. If it asks you for the network key, type your wireless network key. It only allows WPA-Personal(TKIP) and WEP. If you have WPA2 or AES, it will not connect
Sep 23, 2009 | Linksys Wireless-G WRT54G Router
Cant connect ps3 wireless to dlink router
The router should assign an IP address to your PS3 if it isn't manually configured. If you are connecting wirelessly make sure your security setting on your PS3 match your router. If the problem persists disable wireless security on your router and then try to connect with the PS3 with security disabled as well. Sometimes consoles have trouble connecting with WEP or WPA security encryption.
Jan 06, 2009 | D-Link AirPlus DI-524 Wireless Router
Trouble Connecting
The modem only attaches to one address following boot. Turn off the modem, turn off your wireless router...turn on the modem, wait several seconds for it to boot and then attach it to to the wireless router. Start the wireless router. Attach with your computer through the ethernet to the router first and configure it to use DHCP over wireless. Then attampt connecting to the access point over wireless. If it works, then configure WEP. Be sure to use the Hex key that it generates and not the WEP key you built it from. For example, if your password is "Rosebud" use the one it creates that looks like "fcae9969e..."
Dec 06, 2008 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
