Question about Samsung SyncMaster 955 DF 19" CRT Monitor
Positioning After repair work the sceen is appr. 1 inch to the right,failed to get a manual when I purchesed monitor. How can I correct this using the control buttens. Ed. Klassen
  • Samsung Master
  • 19,396 Answers
Use orizontal alignment setting in menu
Posted on Mar 23, 2008
  • Ginko
    Ginko Mar 23, 2008
    press the menu button on screen, you will have a series of pictures, horizontal alignment is two squares pictures one inside the other. You may also need to change wideness.
    Do not be scared of playing with the monitor menu settings, you can't do damage over there, just try the options until you find the one you need.
  • Ginko
    Ginko Mar 23, 2008
    Here is breackdown of procedure:
    Part 1 - Changing
    the Horizontal Position
    1. Turn on monitor.
    2. Push the
      Menu button on your Monitor. The OSD menu appears.
    3. Push the
      + or - button on your monitor until the H-Position screen appears.
    4. Push the
      Menu button to open the H-Position screen.
    5. Push the
      + or - button on your monitor to change the Horizontal position of the image
      on the screen.
    6. Press the
      Exit button on your monitor to exit.
    Part 2 - Changing
    the Vertical Position
    1. Push the
    2. Push the
      + or - button on your monitor until the V-Position screen appears.
    3. Push the
      Menu button to open the V-Position screen.
    4. Push the
      + or - button on your monitor to change the Vertical postion of the
      image on the screen.
    5. Press the
    Also check knowledge base:
    How Do I Center The Image On My CRT Screen?
    Remember to accept the best solution
    Genius:
  • 1,665 Answers
You can download a manual here
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Mar 23, 2008
    Attention! This manual is multipart. Download all, before decompressing
CN-0G606T-74261-23Q-0RHL
LCD (pre the manual you threw away, and my exp.)
1: does it have A.C. power, use a desk lamp to test that jack.
2: does the power lamp come on, ? on monitor.
3: does the OSD work? (press mon, keys? see a box> )
4: does the monitor work on other systems, PC,TV,laptops.etc?
5: try a new cable?
if all 5 fail, or to correct it, the monitor is toast.
Oct 03, 2013 | Dell U2711 27 inch LCD Monitor
Laptop sceen black
If everything else is working, hook a spare monitor to the video output, if picture okay! the inverter board just below the screen is more than likely faulty, or the backlight behind the display has failed, but if both show the same symptom it is the video graphics card usually built into the motherboard, I suggest a computer repair shop to address.
May 05, 2012 | Toshiba Computers & Internet
Green light on and no back ground light in it and no pic i turn it off and on and still no good ,but as of now am used and old sceen till i get it fix right now and i bought this computer in jane of...
Service manuals: http://elektrotanya.com/?q=showresult&megnev=acer&megnev2=al1706&kategoria=monitor&kat2=schematics
Please read my guide and look at pictures of failed monitors and bad caps.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Nov 10, 2010 | Acer AL1706AB LCD Monitor
Monitor has stretched images. I use CAD programs that require equal vertical & horizontal. I am using only a VGA cable plugged into my HP Pavilion. AOC suggests DVI cable, but did not include one...
You should set your PC video resolution to the native resolution of this monitor: 1920x1080 at 60Hz . Right now you do not have it set to the correct aspect ratio for this wide sceen monitor.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Oct 28, 2010 | AOC F22 Monitor
Picture not centered on my philips 47'' lcd tv
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD
By dmorrow54 on Nov 13, 2007
Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
Guest
  • Rank: Guide
  • Rating: 0%, 0 Votes
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Add a comment
    • c7carl
    • 5 minutes ago
    WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
    Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
    Comment:
Feb 05, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
Auto-tune isse
you could try adjusting the screen resolution in My Computer/Control Panel/Display this may help.
Also have a look to see if the Adaptor, is set for optimal refresh rate.
Mike @ Compurepair.
Sep 16, 2008 | Computers & Internet
Horizontal Position Unstable
Sounds like a electrolytic capacitor has aged/failed in the positioning circuitry. The failure could also be internal to a micro circuit chip. With out skematics and signal tracing I can't say what the problem is. It is possible, however unlikely, someone has spilled a liguid into the adjustment controls and the position switch is shorted causing a constant signal to move the screen.
Good luck
Jan 04, 2008 | Polyview V17E 17" LCD Flat Panel Monitor
Dell touch screen monitor not lighting
Repairing the Dell E153FP with this complaint is not that hard but one that should be done by a qualified service technician or monitor repair specialist. Usually when you have this type of problem it is because either the inverter board, filter capacitors or the main board has one or more burnt components.
Any TV/LCD repair man can test this out for you if you don't mind paying them to do tht typical charges at our shop for such a diagnosis run around 35-50 dollars... this cost is usually included if you have them repair the item for you.
Jan 01, 2008 | Dell E153FP 15" LCD Monitor
Picture is not centered on monitor leaving a 2 1/2" black border on Philips LCD
Nov 13, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Samsung SyncMaster 955 DF 19" CRT Monitor Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
