Question about Kenmore 24902 Top Load Washer
The hot water does not work...i check to hot water coming into the washer and its fine.
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Also see the following Whirlpool / Kenmore Service Manual for top load, direct drive machines.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It has a troubleshooting section as well as testing procedures.
It sounds like a bad Water Inlet Solenoid. I'd follow the procedures for testing it.
See the following for how to release the console and cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Posted on Apr 26, 2010
  • 619 Answers
SOURCE: KENMORE HE5T NO Hot Water
Check the hot water line going to washer have hot water?If donot have trace the line from Hot water tank going to washer if yuo rfound it open the valve. hold the pipe you can feel the hotness.attache to machine.
Posted on Jan 10, 2008
faggly
  • 74 Answers
SOURCE: Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Posted on Mar 19, 2008
localwonder
  • 6784 Answers
SOURCE: Whirlpool Top Loading Washer not filling when set on hot only
check the water inlet valve assembly. Also, this could be a timer issue as well. check the Hot valve block connector on the control panel board. it could be lose or separated or broken. there is a wire that leads to the valve on the hot side as well. check this.
Posted on Mar 13, 2009
SOURCE: LTE6234DO Whirlpool Thin Twin-No hot water
The inlet valve that the hoses attach too the solenoid for the hot side may be stuck closed or clogged with sediment. May need new inlet valve.
Posted on Mar 18, 2009
SOURCE: kenmore washer wont fill using hot water, cold water works fine
try taking off the hoses and maybe the screens on the washers for the hoses are plugged
Posted on Mar 30, 2009
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
No cold water coming in, only hot. hose is fine.
check screen in washer machine-turn off cold water unscrew the cold hose that goes into washer-check to see if screen is clogged a small filter
Oct 19, 2009 | Kenmore Washing Machines
New Maytag washing machine, but hot water only comes out in pulses. Cold water works fine. Unsure what's wrong.
Check the hose washer on the washer end of the fill hose. (there is probably a screen in it that may have dirt in it. Clean it if this is the case) Are you positive yout hot water valve is turned all the way on?
You may have to remove the valve stem to check the washer which may have come loose.
Turn the water off before you take the top off the valve!!!!
If you need more help, let me know. I want to assist you.
a
Sep 26, 2009 | Maytag Centennial MVWC500V Washer
No cold water to my Maytag Top loading washer
Pull the washer out from the wall and disconnect the water lines from the washer. Check to see if a build-up of minerals is clogging the screen on the cold water line where it enters the washing machine.
May 14, 2009 | Maytag PAV2300 Top Load Washer
Mar 13, 2009 | Washing Machines
No hot water
I guess you have check the settings on the machine.
So I am guessing possibly the acuator (electric) that switches the hot water flow on and off and being initally controlled from the timer circuit. Both hot and cold have actuators. These are usually what the flexible hoses screw into. The will have connections on them inside the machine.
You need to have the machine looked at.
WARNING
If you tamper with or check the wiring yourself, ensure the plug is removed from the powerpoint.
You can still get an electric shock of the neutral wire if it is plugged in, even if the powerpoint is turned off
Sep 14, 2008 | Kenmore 24032\24036 Top Load Washer
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Hotpoint washer , top load
This sounds like a faulty water valve. Water is coming in the cold water valve when it shouldn't. If the machine has an automatic temp control make sure it is turned off.
Jan 01, 2008 | Hotpoint VBXR1090D Top Load Washer
GE Washer wbsr3140d5ww water problem
Hello Chad
Welcome
Sounds like the cold water knob or switch is not switching and may be faulty.
I have a problem with my washer
For some reason when I try to start the washer and I have it set to cold it does not work if I put it to hot then its fine
The cold water does work though because if I change the washer to a later cycle cold water comes out just fine.
So it almost seems like its the timer knob
any ideas?
Thanks
Please remember to leave a rating
Jun 04, 2007 | GE WBSR3140D Top Load Washer
Kenmore 24902 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
