Question about Dryers
Dryer problem hotpoint wd640p dryer not working. Goes through drying cycle but no heat and clothes are still wet.
    Champion:
  • 210 Answers
Check voltage at outlet-240v. Model # not right. how old is unit?
Need correct model number.
Posted on Mar 23, 2008
Dryer works OK on timed dry but doesn't dry the clothes in Auto dry.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum 9 this is why in some cases the dryer will operate at lower cycles like gentle or low heat but not at higher settings?)
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :
http://www.ehow.com/info_12203962_check-dryer-thermistor.
GOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
How to Check Dryer Thermistor eHow
Jan 07, 2016 | Dryers
Why is my hotpoint tcm570 tumble dryer leaving a puddle on the floor
Since no dryer I am aware of uses any liquid, I suggest you may be putting wet clothes into the dryer.
This can happen if the washer does not spin the clothes nearly dry. Many dryers have small holes in the dryer drum to let excess water flow out, I would guess that may be the case with yours.
Are your clothes nearly dry when they come out of the washer?
If not, perhaps the washer has a loose belt or has a problem with the "dry" cycle.
God bless your efforts.
Nov 02, 2015 | Hotpoint Dryers
Gas dryer does not dry in "timed Dry" setting
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Mar 06, 2015 | Whirlpool LGB6300 Gas Dryer
My hotpoint BWD129 , dryer does not work clothes are barely warm
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Washing Machines
How do i use the drying cycle of the hotpointWD420 model. My clothes come out soaking wet. Thank you
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
May 19, 2011 | Hotpoint Dryers
NO HEAT WHEN CLOTHES ARE ADDED
Check to see if vent hose is not restricted. If it goes up inside wall, it could have lint clogging it. Most dryers regulate heat with air flow. Wet clothes can restrict flow even more if vent is clogged or pinched. Air flow is crucial to heat cycle. If the vent is resrticted, heat will rise quickly, but not cool down fast enough to allow heat thermostat to cool down and turn on heating element again. It may seem hot inside dryer but if no air flow it will increase dry time or not dry them at all before timer shuts off. If vent goes up inside wall, buy a small chimney brush and try cleaning out vent from attic if you can.
Jul 24, 2009 | Maytag MED5800TW Electric Dryer
Hotpoint wd440 heating but not drying
yes, the dryer is pants im afraid. weve had ours going on 4 years & it has broke down every 6-10months - seriously! the dryer will leave clothes hot & steamy but when hung up for 1/4hr they r dry! _ Hotpoint advised us that he machine is esigned his way - but dont believe a word from their corporate b***hit mouths!
Aug 11, 2008 | Hotpoint Aquarius WD640 Front Load...
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Washing Machine not spinning
Bring your sample to appliances store let them chech if their available.
Check the heat sensor detach one line test the continuity both terminal if open replace it.
Jan 05, 2008 | Hotpoint Aquarius WD640 Front Load...
Dryers Logo
51 people viewed this question
Top Dryers Experts
