Question about Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator
Loud Buzz upon starting
A tiney metalic buzz when compressor starts. If I lean on / gently pry the condensing coils buzz goes away. If left alone, buzz goes away, slowly, during first minute or so after compressor start. Buzz is very loud: can be heard through out the 3 bedroom house.
    President:
  • Kenmore Master
  • 2,651 Answers
Sounds like just a vibration caused by cols hitting the frame perhaps, sometimes a pull from underneath the unit on the condenser coils will rectify the problem(id give a pretty quick tug, . unit could just be settling into the floor or the house settling around it, vibrations are definitely annoying but usually no need for alarm
Posted on Mar 24, 2008
When thermostat calls for heat, loud buzzing
That sound generally comes from a magnetic coil that is being energized. It could be from a compressor control or a furnace gas valve. In either case there is no danger involved it may buzz for years and unless you have money put aside for a heating mans adventure id just let it buzz until it gets so loud it just has to go. Sometimes the buzz just goes away. I know it sounds crazy and I understand one persons buzz is another persons nightmare. Its yer call. Hope this helped and good luck.
Oct 08, 2014 | Heating & Cooling
Liebherr fridge freezer had Freon top-up to solve problem with warming up. Now there is a constant loud buzz when pump is running ( most of the time). Do I need to replace the pump/compressor?
If it ain't broke, don't fix it! If the compressor is working, leave it alone. Perhaps there is a metal panel or metal shelf inside that is vibrating from the compressor vibration.
Jan 16, 2013 | Refrigerators
Fridge runs great for 3 or 4 days then a loud buzz and everything starts getting warm. think it may be a relay?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 19, 2011 | Maytag MFD2560HES Bottom Freezer French...
I have a Maytag french door, bottom freezer refrigerator. It has started loud humming/buzzing when the compressor is running. It is still cooling fine but the buzzing seems to be getting worse
heatman101
Jul 07, 2011 | Refrigerators
Frigidaire, top freezer bought in 2008. Now will not freeze or refrigerate. Makes clicking sound and buzz. Put in relay switch to no avail. Need compressor?
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Apr 13, 2011 | Frigidaire Refrigerators
No cooling at all every 3 minutes it will buzz loudly for 15 seconds
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Oct 30, 2010 | Refrigerators
Fan in freezer making a very loud buzz and there is frost on the back of the freezer. What should I do??
heatman101
Sep 14, 2010 | Maytag MTB1891AR Top Freezer Refrigerator
The symptoms: fan starts and so does buzzing. buzzes for about 5 seconds then stops, compressor does not start. 1 minute passes fan still running buzzes for 5 sec then stops compressor does not start...
freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Sep 10, 2010 | Maytag MSD2756GES Side by Side...
Freezer/refrig not cooling properly. all coils
If you (or someone you know) is competent at soldering, you may be able to fix this without a pro (nor replacement part).
At the rear of the fridge is a metal panel at top left behind which is the motherboard. If the problem is intermittent - e.g., slamming the door yields a loud 'click' and you hear the compressor start, chances are great that the problem is a bad solder joint on the relay that switches between defrost and compressor modes. (It seems to default to defrost mode.)
Unplug the fridge!
Remove the metal panel. (1/4" hex wrench or socket set req'd.)
Gently and carefully (wiggle and) remove all molex connectors from the circuit board. (There'll be 5 or more, possibly depending upon how many extra features your fridge model has.)
Use a suitable tool - needle nose pliers or strong tweezers - to squeeze the plastic stand-offs with which the board is mounted to the fridge.
Remove the board from the fridge. (Note: it may be easier to remove the connectors at the right of the board AFTER the board is lifted off the stand-offs.)
Look at the solder-side of the board.
You'll almost certainly see charring around a particular solder joint that belongs to the large, sort of T-shaped relay (black box) on the board.
Clean up the carbon with alcohol.
Scrape away some of the (green) coating on the copper trace around the pin that comes throught the board from the relay. (This will entail removing some of the acrylic clear coat with which the board has been sealed.)
Resolder the joint.
Clean up any flux residue.
Reinstall the board - right-hand connectors first, if necessary (i.e., before mounting the board on the stand-offs).
Replace the metal panel.
Plug the fridge in.
Listen to that relaxing buzz of relief...(and $100-$200 savings).
CAUTIONS: 1) Make sure you NOTE and/or remember which connector goes where on the board BEFORE you remove it.
Oct 06, 2009 | GE GTS22KBM Top Freezer Refrigerator
Hp pav dv6000 - buzzing speakers
Does it stop if you mute the system?
Find a pair of headphones and plug them into the laptop and see if the buzzing continues in the headphones. If it does, it's a driver problem. Uninstall Audacity (which I don't think works too well with Vista, unless they've released a new version) to see if the problem goes away. If the buzzing is only occuring on your laptop speakers, but not in the headphones, then you may have blown them by using the wrong impedance out of your amp...
I rather suspect it's an audio driver problem. What happens when you remove Audacity?
Sep 06, 2008 | HP Pavilion dv9000z Notebook
Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator Logo
255 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
