Question about Peg Perego Vespa Scooter
Vespa P125X indicators and horn not working - Peg Perego Vespa Scooter
Vespa mystery
Try checking your fuses
Apr 26, 2012 | Sport & Outdoor - Others
T5 starts but no lights horn indicators fuel gauge any ideas
Check the main fuse near the battery, it have been poped up and needs to be replace wit the same amperage. If the fuse blow up again, check your wiring there might be a cut or expose wire that maybe grounding the body.
Try also to check the electrical connectors, it might only been disconnected or needs some cleaning up on the contact pins.
Hope that helps you out.
Thanks for using FixYa!
Jul 03, 2011 | 2008 Vespa PX125
All lights and horn stopped working
those run on a different battery source you need to replace the aaa batteries for that
May 30, 2011 | Peg Perego IGMC0006US Vespa Scooter Ride...
the light and horn take three aaa batteries they don't run off of the vehicles battery
Where is the choke positioned thanks on vespa piaggio 50cc
Below the fuel tap on the 'horn'. Little round plastic 'button'. Prone to getting lost though so maybe missing. Should be a little hole or spigot if the choke lever itself is gone.
Oct 25, 2010 | Peg Perego Vespa Scooter
My Piaggio Typhoon 50cc has no indicators or horn
Look under the front panel and make shure all the wires are plug in. check www.scootdawg.com for a complete list to trouble shot it.
Best Reguards
Larry
Jan 24, 2010 | Peg Perego Vespa Scooter
My 1980 Vespa P125X motorscooter is real sluggish it will rev up with the clutch in, but is real weak on moving. I have rebuilt the carb and it hasn't helped. I would really appreciate some suggestions
small cc and that age is normal for the engine to require new piston rings and/or piston to restore power. i used to do it every few years when i lived in europe
Aug 08, 2009 | Bajaj Discover Motorcycles
Vespa et2 clock
there is only 1 fuse on an et2 and if the horn, starter and indicators work, then this iis not the problem.
It is most likely the battery which is at the back of the speedo. to get to this you need to remove the mirrors and screws from the handlebars, split the casing, disconnect the speedo cable and all electric blocks (carefully) and turn the speedo over. there is a little round plug that needs to be removed and the battery is behind it.
I think it is a rechargable battery, so replacing it with a normal battery will only work temporarily.
Mar 04, 2009 | Peg Perego Vespa Scooter
Peg Perego Vespa Scooter Logo
168 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
