Question about Onkyo TX-NR905 Receiver
My audio and video periodically freeze for between 10 and 25 seconds. Any thoughts? Cheers
The tv freezes intermittently and repeatedly
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 27, 2016 | Televison & Video
HP Omnibook periodically pauses
You probably need to increase memory size and change spool option to direct one, also to disable in each installed software include acrobat reader auto update option; after you may enable some of them one per a time and see what happened
Apr 03, 2014 | HP OmniBook 6100 Notebook
Video freezes every several minutes for about 15 seconds.
You need a faster broadband connection. What you are experiencing is buffereing. But, The problem may be the server isn't fast enough during the period you are online.
Aug 05, 2013 | YouTube Videos
Ipod HD or logic board gone? SDRAM full test freezes!!!!
Getting the components wet is not a good start. There is most likely liquid damage on the parts even if you can't see them. And even over time corrosion to iPod can happen. Much like the Statue of Libery, it used to be copper, and now its green from long exposure to moisture.
Mar 09, 2017 | Apple iPod video 5th Generation
Hi, I own a Nokia 5230. Before, I was able to record video smoothly and clearly without any kind of problem. Now, 90% of the time when I video, the video keeps going when recording, but the timer...
check if the phone memory is still at large and so on the memory card to,might so many files from your phone or card that's why the operation took some errors or buffer...
otherwise if this problem took on and so on,better reset your phone or restore it to it's factory default to refresh the memory of the phone and can do the operation smoothly...
if this solution helps....please rate me...thanks
Jun 03, 2011 | Cell Phones
I cannot seem to find a solution to this glitching problem.
You must install the chipset driver first and then the other drivers.You also need to uninstall the drivers the operating system installed when it was put on,one by one and in return install the correct drivers,chipset first.Also if a bios upgrade is available with your driver download,do the bios upgrade then the chipset and then the other drivers.If your having problems after installing the drivers you have (if they are the correct ones), sounds like a communication problem between your bios and operating system.
Oct 11, 2009 | Dell Inspiron 6000 Notebook
So i've been having this consistent problem with the laptop. this isn't the first time i've posted theproblem either. in any case, here it goes: my audio and video glitches every second, the whole computer...
The HDD controller driver for an I6000 is native to XP and not a driver you can update outside of a Windows Update. I'd first run diagnostics on the system (Fn+ Power Button) and if no hardware issues are apparent I'd backup my data and reinstall Windows. On a I6000 you should be able to restore the factory image with the CTRL+F11 keystroke at the black screen with the blue bar at the top with www.dell.com in white letters. Screen shows for about a second after the Dell Splash screen so you have to be fast with the CTRL+F11 keystoke. Again backup any important data before the image process
Oct 03, 2009 | Dell Inspiron 6000 Notebook
Audio and Video (Windows Media, Real Player, and player software) freezes up
can u speedtest your bandwith just compare Dell Latitude D620 & Dimension 8400 check ther bandwith.
Mar 13, 2008 | Dell Latitude D620 Notebook
Dell Latitude D620 what anti-virus you install this pc?
if ther an antivirus program just configure your realtime setting.
Mar 07, 2008 | Dell Latitude D620 Notebook
Onkyo TX-NR905 Receiver Logo
83 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
