Question about RCA 35V432T 35" TV
Doesn't rcognize DVD players
Tried to help my friend connect a DVD player to his 35V432T RCA. It has front and rear jacks, but there was no recognition from the TV when we connected several different DVD players. He bought it as a floor model with no User's guide. We couldn't find anyhting in the on-line menu to allow or facilitate the set-up. First TV I've found that I couldn't figure this out on.
Also, RCA has no on-line user guide available for this model - not even in the old archives they route you to. Help would be greatly appreciated.
  • Beverley J Apr 21, 2008
    I hooked up my laptop to the television set using an S-cable. I did what I was suppose to do from the computer end but I am not getting an image on the tv screen. What do I have to do to get the picture to show on the tv? Bev
  • 53 Answers
You aren't trying to use channel 3 or 4 are you? That's for RF connections only.
There are probably AV input channels on the set that aren't accessible from the channel up/down buttons. On my set there is another button to switch between inputs and channel select.
Posted on Mar 24, 2008
How do I turn off pscan on a rca dro2oon DVD player
IMPORTANT:
If you don't have a Progressive Scan TV or you don't have the DVD player connected to the correct Input Jacks, and you activate Progressive Scan in the DVD player you won't see a picture! Don't panic-try the following:
First, press the PREV/VIDEO button on the front of the DVD player (it will go to the next video output option, which is an interlace output so a picture should appear on the TV screen). If that doesn't work, press and hold PREV/VIDEO button on the front of the DVD player for 3 seconds. Now, press the PREV/VIDEO button again (it will go to the next video output option, which is an interlace output so a picture should appear on the TV screen). If you still don't see a picture on your TV screen, make sure the yellow cable (provided) that is attached to white and red cable (called audio/video cables) is connected to the DVD player's PREV/VIDEO jack and the TV's Video Input jack. Change your TV channel to your TV's Video Input
channel that activates the TV's VIdeo Input jack where you have connected the yellow cable (page 9 of your manual has more information).This PREV/VIDEO jack on the DVD player always outputs interlace video, so you should see a picture on the TV screen.
As a last resort, you can reset the DVD player to the factory default settings:
Press and hold the STOP button on the remote control and the NEXT button on the front of the player at the same time - wait at least 5 seconds before you release both buttons
Sep 25, 2016 | RCA Televison & Video
Sanyo TV connect to cable box connect DVD player
If your DVD/VCR combo player has three RCA connectors (yellow, red, and white), you can connect them to the corresponding inputs on the front of your TV.
Dec 29, 2012 | Sanyo Televison & Video
It will not play the tape or eject the tape. The light area has RAV, FAV, RVV, DV, AND CH027 What does this mean? how can I FIX IT? I
RAV= Rear Audio/Video jacks, the RCA type jacks, FAV means the front jacks,
Don't know what the others mean.
Hope this helps some, Wally
Aug 30, 2011 | RCA DRC8300N DVD Recorder/VCR
How to connect dvd to tv.
Good day!!!!
Please try this procedure on how to connect your DVD player to your TV..
Follow this instructions:
1. Check the back of your DVD player. It will have up to three different types of outlet connections enabling it to be linked to the TV. The most ideal is an HDMI connection, which is a thin rectangular outlet marked "HDMI." It provides the highest quality signal to your flat panel TV. If your DVD player doesn't have an HDMI outlet, you can also use a standard RCA outlet. This consists of three round cable jacks labeled with a color coding. The yellow jack is for the video signal while the red and white jacks are for audio signals. Some DVD players may have an S-video outlet as well. It will be a circular jack with a number of holes. While not as effective as the HDMI jack, it provides a clearer picture than the RCA cables.
  • 2. Look at the back of your flat panel TV for a series of "In" jacks corresponding to your DVD player. There may be a number of them under different labels (Input 1, Input 2, HDMI 1, HDMI 2 and Component Video are common). All of them work, however, and all can carry the DVD signal into your TV. Simply select an "In" jack that matches the DVD outlet you have selected and note the precise label.
  • 3. Connect the "In" jack from the TV to the corresponding outlet on the DVD player, using the proper cable (RCA, HDMI or S-Video).
  • 4. Turn on the TV and press the input button to select the jack connected to the DVD player. (The exact label for the input button will vary by model. Some will say "Input," while others will say "TV/Video" or "Signal.") A menu should pop up onscreen giving you a list of jacks in the rear of the set. Select the jack connected to the DVD player. The name of the player brand should appear on your screen.
  • 5. Place a DVD in the player and watch as normal.
  • I hope this procedure will be helpful...Thanks for using fixya..
    Aug 13, 2011 | Panasonic Televison & Video
    I have an RCA 52 " projection TV thats now 6 years
    you have to run theater system eather through your vcr or your dvd player for mor out put jacks and input jacks on older tvs but the thing is your dvd player remote will be your tv remote the same as your vcr remote.
    Feb 13, 2011 | RCA P52937 52" Rear Projection Television
    II HAVE A 13 INCH BRAND MODEL DWT 1304. I JUST WANT TO USE IT FOR A DVD PLAYER. I HAVE NO REMOTE ,HOW DO I CHANGE THE TV TO PLAY DVD OR VEDIO
    Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
    Dec 20, 2010 | Durabrand DWT1304 13" TV
    5.1 speakers connected to a dvd player ?
    You need an RCA - RCA cable,that means that you need a cable with RCA at both ends. At the back of the dvd player,look for sound section (RCA jack) In the sound section look for "right" and "left" connect the two RCA jacks in there and you`re done.
    ------- If you don`t know how an RCA jack looks like,see this image
    Jul 18, 2010 | Logitech X-530 Computer Speakers
    How to hook up protron pds-2315
    First of all, the PDS-2315 is not a DVR (this question is incorrectly categorized), it is a home theater system. Also, this system is not a receiver -- it is a DVD player (DVD/CD/HDCD/CD-R/CD-RW/Kodak PCD Playback) with a "full function" Karaoke feature with two microphone inputs. If you haven't figured out how to set it up in the past 11 months, this is how you do it.
    1. Connect the supplied RCA cables (labled FR, FL, SR, SL, Cen, and SW) to the corresponding RCA connections in the back of the DVD player and the back of the Sub-Woofer.
    2. Connect the DVD Player to your television.
    A. Video:
    There are several options here depending on your available Television inputs: Coax Cable, Component (yellow jack), S-Video and Composite (composite providing the best video resolution and coax the poorest). HDMI is not available. Use s-video or composite if you can. You will note that the composite RCA jacks are colored Orange, Blue, and Green. In a pinch, any RCA Cables will work - just don't cross the color codes between the DVD Player and the television. If you need to use coax you will need a coax to RCA adapter. If your television only has a component jack (yellow), it's a simple connection between the two.
    B. Audio:
    On the back of the DVD player you'll find two RCA jacks labled "Main R" and "Main L". These will be connected to your Audio Out connections on the back of your television. If you don't have Audio Out RCA jacks on the back of your television, but have an earphone jack, you can purchase an RCA adaptor to make that connection. With rear audio out jacks, you should have an option in your television's audio setup menu to select those outputs. (DO NOT CONFUSE "AUDIO OUT" WITH "AUDIO INPUT" because the will look identical.) If you don't have either of these connections, you will not be able to use the system to listen to television signals.
    3. Connect the speakers. Each of the speakers is labled with their position (FR, FL, CEN, SR, SL). The speaker wires are color coded to the spring connectors in the rear of the sub-woofer/amplifier. Press the spring lever and place the wire into the opening. For proper biasing, place the color coded wire into the colored spring connector and the other wire into the black connector for the specified speaker. Connecting the speakers should be very easy. If the ends of the speaker wires become damaged, simply strip the wires back half an inch and connect as above. Place the speakers as specified by their position lables (FL, CEN, FR in front of the television and SL and SR to the right and left of the seating.)
    4. Plug it in and power on. You'll need to plug in both the DVD player and the sub-woofer. Press the power button, hit the open/close button on either the DVD player or the remote control and put a disc in the machine. If you don't have a picture or a "Protron" title screen, hit the "P-SCAN" button on the remote (top left corner below the "STANDBY" button).
    5. Hit the "SETUP" key and enter your system's information and you're done. Your system will work just like any other DVD player with theatre quality sound. --With the added feature of functioning as a Karaoke machine! Just add proper Karaoke CDs, a couple microphones, a bunch of friends and copius amounts of alcohol . . .
    Feb 21, 2009 | Protron PD-DVR100 DVD Recorder
    Samsung CXD2512 TV/VCR Combo...Cannot hook up DVD player
    We also don't have a remote. We hooked a DVD/VCR combo to the Samsung combo by attaching the cable from the cable line to the DVD player and an additional cable from DVD to TV and it used to work but after we lost the control, the DVD can only be listened to but not seen. The VHS from the DVD player works perfectly though.
    When we had the remote (before connecting the other combo) we used line-in to see a DVD or VHS using the yellow red and white cables from the Samsung to the other player.
    Sep 05, 2007 | Samsung CXD2512 25 in. Combo
    RCA 35V432T 35" TV Logo
    Top RCA Televison & Video Experts
    jason
    matt martin
    matt martin
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
