Question about Bunn 10 Cup Home Coffee Brewer
Keeps throwing the breaker switch
My bunn keeps thowing the breaker switch. could i have a short in it. i sent it back a few years ago cause i was having problems with it and i just found it.
  • 189 Answers
It is possible there is a short or other electrical problem with your brewer. If you will get the model and date code located on the bottom of the unit and call customer service, we will be happy to resolve this with you.
Posted on May 19, 2010
My suburban dsi rv hot water keeps throwing breakers
Appears to be a short in tank circuit probably cause by a water leak in tank. These usually wear a rusty hole in the tank inside the cover and are not seen unless the thermostat covers are taken off. I would remove them and do a visual thoroughly. Anytime a fuse blows or a breaker trips is always a dead short unless you have a bad breaker. I would check those as well for vibrating, chattering noises, and/or smoking. If any of this persist, replace breaker. A melted heat element could trip them, but not usually for it leaves an open circuit instead of a shorted one.
Feb 19, 2013 | Suburban SW10DEM Gas Electric Water Heater...
Our generator keep throwing the curcuit breaker.
Check to see you are not overloading the current rating of the breaker. If not the breaker may be worn out and need replacing
Oct 16, 2012 | Coleman Powermate Premium Plus 6250W...
My heater regularily trips my electrical circuit breaker the model no is hm2000t. I bought it about 10 years ago but because of this problem It has been in a cupboard for 9 years. Should I throw it away
Good day!!!
if your machine will trips the breaker every time you plug it in a split seconds only...
that problem is cause of shorted parts inside...The common parts that usually have a high risk of shorted is the heating element itself...
please try to compare the price of your machine to the parts you need to buy...if the price almost the same or too close....I suggest you to buy the new machine because if you replaced the parts and still persist or you have another trouble cause of short circuit..
Thanks for using fixya...
Jul 30, 2011 | DeLonghi 6707E Oil Filled Radiator Heater
Philips MCW770/37 stereo will not power on any longer.
Hi ,
This is just a suggestion. Check your speaker wires at the back and at the speakers. A shorted speaker wire will cause a tripped breaker.
May 19, 2010 | Philips MCW770 CD Shelf System
Central vacuum with new motor shuts off and throws switch
Your mini breaker is probably bad if its a new motor. Its found on the relay board and they can weaken over time, especially if you had a bad motor before that tripped it a lot.
Oct 31, 2009 | Vacuums
Keeps tripping circuit breakers bunn NHb
Hello
Coffee makers have a heating unit in them which draw a lot of current. If it is on the same circuit as refrigerator, toaster and other it will trip the breaker. Also, some breakers are more sensitive than others. Have an electrician run a separate circuit for the coffee maker outlet. Try running it in the dining room outlet, which I hope is separate from the kitchen outlets. Is the house old? Older homes have a lot of mixed up wiring.
John
Aug 09, 2009 | Bunn NHB Coffee Maker
Duo-therm 13500 btu
First I would check the size of the power supply cord to the coach. To small a line will cause a voltage drop which in turn will cause the amperage to increase. Check the supply voltage to the system.
Jun 16, 2008 | Dometic Rooftop RV Air Conditioner
Throws Breakers
Check the power cord for damage, and repair anything you find.
If confident enough, open the unit up and inspect all the internal wiring - check for chafed wires and for terminals that have come undone or that are touching anything they aren't obviously meant to.
Check the unit hasn't got wet inside - mop dry then leave to dry out properly in warm air for a couple of days if it has.
If that doesn't throw up anything obvious, then you're probably looking at insulation breakdown of some component (my money would usually be on the element). For a unit like this, I doubt it's economic to start buting spare parts, so you're probably better off buying a new coffee maker.
Good luck
A.
Feb 23, 2008 | Bunn NHB Coffee Maker
Fisher paykel degx1 electric dryer
Restricted venting is the most likely cause, they did change the thermostats a couple years ago. the small t-stats should look cut out on the metal side they should not be solid, also check to make sure the elements are not shorted to ground.
Feb 08, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Bunn coffee maker trips the breaker
It is possible that you have a short in your limit thermostat, but most likely this is caused by small holes in your main heating element. these units start to split length ways down the element, causing a short to ground through the water. These elements are readily available at your local Bunn repair shop.
Oct 27, 2007 | Bunn RL Coffee Maker
Bunn 10 Cup Home Coffee Brewer Logo
Top Bunn Coffee Makers & Espresso Machines Experts
evans_lloyd
Level 1 Expert
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
