Samsung HT-DB600 System Logo
Posted on Apr 25, 2010
When I turn the system on, The display reads "protection" and shuts off? Please help.
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on Apr 25, 2010
Anonymous
Contributor
Level 1:
Answers
22
Questions
Helped
5169
Points
30
Remove all of the speaker leads from the unit, plug in one at a time...could most likely be a shorted wire. or the volume is maxxed when you turn the unit on
When i turn the system on the display will read "hello" then "protect" then shuts off. Whats up ?
The "protect" function is shutting the syetm down to protect the electronic components inside it. Usually caused by a lackof earth in the plug or extension lead. Plug it straight into the wall and check it, if it is still the same then it could be a speaker wiring short circuit, disconnect the speakers and plug it in on its own and test it
2answers
I have no sound..display reads protect...then shuts off
The amplifier board is burnt and needs to be replaced
1helpful
Need help with HT-z410
When your home theater's display reads PROTECTION, it means the home theater is over heating and the unit will shut down to prevent any damage. This can happen if the unit is stacked along with other electronic devices or the unit is in an enclosed area that prevents the unit from cooling properly. To decrease the chance of overheating, relocate your home theater to a more open area.
If the home theater display reads PROTECTION every time you turn it on, no matter where or how the unit is placed, it needs service. To set up service call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
1helpful
Once switched on, PROTECT appears on screeen and system turns off
1helpful
Hello Protection Samsung HT-DS900
Can't get the disc drawer to open/ close
Hope this helps!
2helpful
2answers
Protection
sounds like you may have your speakers connected wrong or too many speakers. Check all your speaker wires for a goo tight connection and speaker compatibility with your Home theater system. Hope this will help you
1helpful
Protection displayed and shuts off
The protect message indicates that the output amp section has a problem. Normally this requires the replacement of the output transistors or the output amp pac. Expect the repair cost to be about $20-$60 for parts plus the local labor rate.
Dan
3helpful
4answers
Protection
Protection means the unit is detecting a short somewhere. Disconnect speakers and components and attempt to power on the unit again. If it will power on with nothing connected, repeat the process (turn off, connect something, then power on) until you find the bad component or speaker.
MHC-GS100 Shelf system
to restart, press stop, clear and display at the same time.
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
