Question about Poulan Pro 48Inch High Lift Lawn Mower Blade (3 Pack)
The belt came off the mower deck and I need a diagram
The belt came off the 48 inch Poulan Pro mower deck and I need a diagram of how it goes back on.
What size deck belt goes on a 42 inch poulen pro riding mower
42 poulan pro lawn tractor parts
Google the above line.
You'll get manuals, parts, prices, etc.
Aug 10, 2015 | Garden
Dont know wheter to get primary mower belt or secondary mower belt for craftsman gt3000 48 inch deck mower...?
primary belt goes from the engine to the deck the secondary goes on the deck and connects the blades together
Aug 24, 2012 | Craftsman 48" Cut Riding Lawn Mower Deck...
Mower deck belt diagram for poulan 42 inch ride mower
Go to Craftsman, Order Tree or Parts Tree.com and input your model number. Choose the correct tab and go to the mower deck. It will give you a good over view of how the belt routes. Hope this helps.
Nov 02, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
We are needing a diagram on how to put a deck belt on a 42 inch yard machine
Needing a diagram on how to put drive belt on 42" 20hp poulan pro lawn mower
Jul 23, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Ignore previous message - Belt that operates my mower blades popped off. Looking in my manual it appears diagrams for the belt is missing. Anyone have something to help me get this thing back...
I had one, the deck belt routing diagram was not only in the manual, it was also on a little decal attached to the top of the deck. A google search goes a long way, check for AYP and MTD websites as they make about all the mowers, regardless of the label on them.
Jul 22, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I am trying to replace my deck drive belt and do not remember how the belt goes around which pullies. Can you describe how to reinstall teh belt. My tractor is a standard lawn riding tractor by Poulan 18.5...
you may have missed it but the diagram is on the deck , look closely you should see it, anyway it should look like an upside down t if you were siting and looking at it from the drivers position. you should have to remove only one pin to get the belt on and it would be on the right side of the deck
Oct 25, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
How to put deck belt on
need a diagram of how to put a deck belt on a 15.5 hp/38" cut 5 speed poulan lawn mower model number 9601200-3801
Jun 22, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
POULAN 42" 19HP RIDING LAWN MOWER
42 inch poulan belt broke on mower deck diagram to replace new belt
Jun 14, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
I have a Poulan riding mower and it has a 42" deck. I need to replace the deck belt but don't know how. Can you tell me the easiest way to replace it?
The easiest way is to find your owners manual and find the picture of the belt in there. Using the picture as a guide you can change the belt in a matter of a few minutes. Just make sure that you get the new belt under all of the belt guards or you will destroy the new belt in no time. If the pulley is flat on the running surface, it goes on the back side of the belt, if it is a "v" on the running surface, the inside of the belt goes in the "v". There may also be a routing diagram under the foot board on one side or other of the tractor. Some of the AYP units have it, some don't
Apr 07, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan Pro 48Inch High Lift Lawn Mower Blade (3 Pack) Logo
206 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
