Question about Whirlpool GU2400XTP Built-in Dishwasher
Won't pump the water out. I checked the hoses and they seem ok. Itt doesn't seem to want to go into the pump out stage? When I hit the cancel button it pumps out but with ver little pressure
    President:
  • 949 Answers
It sounds like one of two possibilities here.
The most likely is a blockage somewhere between the drain pump and the drain in the house (under the sink).
Places to look for this would be an air gap or the fitting where the drain hose connects to the house plumbing. Take the drain hose from the dishwasher off of the house pipe under the sink, run that hose into a bucket and see how it drains then. If it is poor then follow back toward the dishwasher until you find the next junction or fitting. If you are sure all these are clear and still not draining, you will most likely need a new drain pump, the part number for the pump is 661662 and runs about $70.00. It is right up front a bit to the right when you take the front toe panel off, it is pretty easy to replace
Posted on Apr 25, 2010
Testimonial: "Great help"
I was getting the F H error code on my washer. I hit cancel twice to clear the code to see of a cycle restart would remedy. Now the wash cycle is stuck on 45 min. remaining & the cancel button is no...
The FH error code on your Kenmore Elite washing machine is an indicator that there is a problem with incoming water. When there is little water coming into the machine, the FH code will appear and the washer will stop. There are a couple of common problems you can check while you are resetting the FH error code. You will need to remove the power supply to the washer to reset the code.
  • 1 Look for the "Pause/Cancel" button on the washer control panel. The button will be below the digital time clock and to the lower right of the wash cycle selector.
  • 2
    Press the "Pause/Cancel" button twice to cancel the wash cycle. Unplug the Kenmore Elite washer from the wall outlet.
  • 3 Check for kinks in the water supply hose while the washer does not have power. Turn off the water supply spigots and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
  • 4
    Connect the water supply hoses back to the washer and turn on the water spigots. Plug the washer cord back into the wall outlet.
  • 5
    Select the wash cycle and press the "Start" button.
  • Apr 29, 2013 | Washing Machines
    My lg intellowasher wf t8501tp won't go into a
    Check the pressure switch and hose. Pressure switch is what turns the pump on and off. Trouble is usually in the hose so check it first. Look for the hose to be unattached or clogged.
    Jan 13, 2013 | Washing Machines
    GE GLD6700N dishwasher won't drain
    remove the drain hose and make sure its not plugged with food debris then hit the drain/cancel button and put the drain hose end in a bucket and see how much water comes out of the end of the hose if any,if the 2 green lights are flashing this too is a clue to this problem,also make sure you can hear the drain pump running when you start it as explained in the above statement
    Oct 16, 2012 | GE GLD6700NBB / GLD6700NWW / GLD6700NCC...
    I have a Bosch Logixx 8 1200 When i turn it on it bleeps and f 37 comes on but it is in a warm dry kitchen, the door won't lock, when I hit the temperature button twice the frost light appears ?
    this a problem water level switch
    Remove the air hose from the water level switch, and blow into the hose,as hard as possible, to clear any debris that may have accumulated in the hose.
    Remove the lower panel, and remove the filter from the drain pump and check and clear any debris from the filter and the interior of the pump, and hoses.
    Oct 02, 2012 | Bosch Washing Machines
    Machine stopped mid cycle, won't spin or did not drain, no error code displayed, tried unplugged and restart. no luck
    next time send the model number,open the door,look around the opening where you put the clothes in and you'll see a tag with the model and serial numbers,it has to drain first before it will spin,check the pump,get a shop vac and vac out all the water,remove the bottom panel and look at the pump,if the middle of the pump can be removed turn it counter clockwise slowly until the water starts to leak out and vac it up until all the water is out,then remove the middle part of the pump and clean it out,if the middle doesn't come out remove the hoses and check the pump to see if anything is in it and check the hoses,after you remove any debries you find fill it with some water and put it into a drain to see if the water drains,if it doesn't you can check the pump again to make sure you cleaned everything out,stick your finger in and fell around the impellar to make sure it's clear,if it's clear replace the pump.usually an error code will come up but if it fills and agitiates but won't drain i would start at the pump.hope this helps.
    Aug 15, 2011 | Maytag EPICz 3.7 Cu. Ft.
    The dishwasher washes the dishes ok, but the dishwasher does not fully drain.
    Since the drain pump will pump the water out using the "cancel/drain" button, if it did not work then your problem is likely to be in the drain hose system or the garbage disposal downstream from the drain pump. Check for kinks in clogs in the drain hose. Grease can build up in the portion of the drain hose just before it attaches to the garbage disposal.
    Oct 02, 2010 | Dishwashers
    Whirlpool Dishwasher DU850DWGX1 won't completely drain
    Check the drain pump, it's located behind the toe panel near the front of the machine. Also pull the lower spray arm and filter screen, see if anything is stuck in the sump.
    Feb 23, 2009 | Dishwashers
    Tried to start my 1998 Gd. Cherokee Lmtd. but it seems doesn´t pump gas
    Hi, you should start by checking all your fuses,if they are all good ,check fuel pump relay, if this is ok , check fuel filter, if filteris good ,you should run a fuel presure text, this will determine if your fuel pump is ok, good luck.......
    Sep 11, 2008 | 1998 Jeep Cherokee
    My dish washer does not drian completly
    the water must pump uphill to the air gap. the last water in the line drops down the hose, and is in quantity equally to the volume of the hose from the bottom of the pump to the top of the hose. that flows to the bottom of the sump in the unit. if enough, it appears as residual water in the bottom. its ok.
    m
    Oct 27, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
    Whirlpool GU2400XTP Built-in Dishwasher Logo
    238 people viewed this question
    Top Whirlpool Dishwashers Experts
    Mike
    Owen Barnes
    Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
