Question about Citizen Aqualand Duplex JP104009E Wrist Watch
My watch thinks its always diving, with obvious consequences for battery life
    President:
  • 2,501 Answers
Your watch needs to be reset to normal operation. This is probably done by pressing the "mode" button but as I not very familiar with this watch, I am not sure about this.
If you have lost your instructions You can get them from the Citizen web site.
Go to "citizen.com" and on the upper right there is a menu. Click on "technical support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on "get setting instructions"
Posted on Apr 26, 2010
Testimonial: "Very helpfull, thank you"
Why does my Wave Ceptor WVA-105H work sporadically after getting wet?
Try a new battery. When water got in there it may have shorted the battery and drained it. It may work for a short time and then die. Also put the watch on you car dashboard in the sun to bake it instead of the oven unless you have an electric oven. For electric oven use a thermometer to get temp of 140 F then turn the oven off and put the watch in for an hour.
Aug 16, 2014 | Casio Watches
Which way does the bezel turn on a tag watch
Tag Heuer watches are constructed with scuba-diving bezels-- that is to say, it only turns COUNTERCLOCKWISE. This is so that when you are diving, you set the triangle marker to the time you went down. If you accidentally bump your watch while diving, it will move only counterclockwise, leading you to think you have LESS time left to dive, which is so much safer than thinking you have MORE time to dive, than you really do.
May 03, 2011 | Tag Heuer 2000 CN1110.BA0337 Wristwatch
I've an under water watch can the battery be replaced with out any problems? Will it leak if I have the battery replaced? If I can replace battery how do I know what size if I can do it by my self? Thank...
There is always a risk of difficulty if you try to change a battery yourself. I have seen many cries for help after battery changing.
If you need your watch to be waterproof for diving, then it would be advisable to send it to the makers service center, so that the water resistance can be guaranteed.
Mar 02, 2011 | Relic Watches
I have a Luminox 3050/3950 series which stopped working after almost 2 years from buying it.I thought it was the battery so I tried to change it my shelf, but even after the replacement of the battery the...
Generally after two years power cell life will over.
> are your replaced same battery? check the voltage of power cell _1.5V
> Observe that seconds needle giving any jerks? if its trying to move its overhaul faulty, give it to good service center for overhaul.
> If its not at all moving at all it might be coil or PCB faulty..
Sep 09, 2010 | Luminox Navy SEAL Dive 3901 Wrist Watch
My battery is out on my Jaques Leman diving watch. I wanted to repair it myself. I was told if I took the back off I would break the seal. Im attempting to fix it myself
Thank you for contacting FixYa.
If you have a good quality scuba dive watch that needs to be repaired, such as needing a battery replacement, it can be tempting to do it yourself. After all, don't you just need a screwdriver, a battery and rubber gasket (possibly)?
Well, yes. But if you do it yourself, you run the risk of voiding the warranty.
So if you change it yourself and the watch later floods, you are out of luck. So check your warranty information carefully before you attempt to do anything yourself or have someone other than the manufacturer/authorized dealer do the work.
If the manufacturer changes the batteries or does any other dive watch repair, they will normally retest the watch and certify that it is still water resistant to whatever level applies.
This is not to say that a qualified watch repair shop can't do the job. It's your decision but at least it will be an informed one.
So the long and short of dive watch repair - if it's a good dive watch, you'll probably want the manufacturer/authorized dealer to handle it if you don't want to void the warranty. A cheap dive watch? Probably not worth the bother.
Aug 26, 2010 | Jacques Lemans 1378B Sports Chronograph...
Watch second had is not consistant on how the second hand moves - it still keeps good time is that a low battery issue
If you second hand is ticking in stutter steps, in other words it hesitates 2-3 seconds then quickly steps forward, and your watch is still keeping correct time that is an EOL (end of life) feature...your cell has become very low and it's the watchs way of telling you to replace the battery. Good luck :)
Dec 01, 2009 | Navy Seal Luminox Dive Watch
Do I have to wind the watch after I replace the battery? If so, how do I go about winding it?
No you don't have to wind this watch..it is a quartz movement powered by a battery...the only thing the crown is used for is resetting the time and date, you are probably thinking of a mechanical watch which is powered by a mainspring...:)
Oct 03, 2009 | Luminox Navy SEAL Dive 3901 Wrist Watch
Navy Seal Luminox watch second hand problem
It is a feature of this watch, it is referred to as the end of life (EOL) feature, it is a way of letting you know its time to change the battery before it dies to the point where it cannot keep time anymore
Oct 24, 2008 | Navy Seal Luminox Dive Watch
Tag heuer watch
its actually a new battery needed rather than a service.
Jun 10, 2008 | Tag Heuer 2000 WK1110.BA0317 Wristwatch
How deep can I dive with this watch
Per "Sector" all of their watches are "water resistant to a minimum of 300 feet". Note that they do not say "water proof".
Aug 20, 2007 | Sector 450 2653450035 Wrist Watch
Citizen Aqualand Duplex JP104009E Wrist Watch Logo
255 people viewed this question
Top Citizen Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
