Question about Philips Magnavox DVD/VCR Dual Player
With my new Comcast CISCO RNG150 cable box, it appears that even programs on NBC, ABC, CBS etc., are protected and not recordable.
  • amretired2 Apr 26, 2010
    First.....
    I have a Go.Video DVD/VCR recorder, 3845.
    Second.....
    Do you mean that I need to get an Engineer in to certify that I comply, just to record NBC, ABC, CBS etc., they need to get real.
    Amretired2
  • 566 Answers
Hi retired
To answer your question;
This has to do with the new HDCP encryption used by cable companies.
What is hdcp?
HDCP stands for High-Bandwidth Digital Content Protection.
In other words it`s a protection for copyrighted material and is applicable in the HDMI format.
You can find more info HERE
Or by searching HDCP(bypass?).
At this point it is an industry nightmare and no one seems to know exactly where it`s going.
So the best i can do is to leave you with that info.
Posted on Apr 25, 2010
  • Jacques Marin
    Jacques Marin Apr 26, 2010
    can you tell me which connectors are in use at the back of your comcast?
  • Jacques Marin
    Also ; was the setup made by the cable company?
Do I need a digtal converter box to pick up local stations via antenna?
Some local broadcasting will still be in analog but this is just jor simple programming such as college stations. To get local programming such as NBC,ABC,CBS etc. you will need to get a converter since the government has mandated all broadcast be in digital to free up air space.
Note that it may be a case by case basis for some smaller areas.
Dec 29, 2010 | GE 31GT720 31" TV
Won't allow recording ESPN and other cable channels.
It sounds like the programs are copy protected. I've had the problem with an E 27 error, but I've had success with recording other programming.
Jun 14, 2010 | Toshiba DR420 DVD Recorder
I can't see NBC with the digital conveter box
Is it only NBC? Or are the other over air channels (ABC, CBS, Fox) also not seen?
Are you going through a splitter with the incoming signal? if so, make sure the splitter frequency range is at least 5 to 1000 Mhz.
You should see the 'temporary lost signal' wording on the channel. Check all cable connections to make sure the cable to connector plug are tight and not loose.
Oct 04, 2009 | Insignia Digital-to-Analog Converter for...
Trouble with Channel setup
It is important for the TV to know what type of
signal-Cable TV (CATV) or a normal antenna
you are using. Choose your signal (Antenna or
Cable):
Press MENU to see the main menu.
Press CH+ or CH- to highlight Setup.
Press OK
to enter the Setup submenu.
TV/CATV is highlighted. Press VOL+ or
VOL-
to select TV or CATV.
Choose CATV if you have Cable TV
service. (See page 4 for connection
details.) If you do not have Cable TV
service and you connected an antenna
to the TV, choose TV. (See page 5 for
connection details.)
Press MENU repeatedly to exit the
menu or the menu will automatically
disappear within a few seconds if no
buttons are pressed on the remote
control.
And here is the manual if you need .
http://tv.rca.com/RCATV/Assets/pdfs/27F520T_1641312E_IB_e-06.pdf
Good luck and please rate
Sep 24, 2009 | RCA TruFlat 27F520T 27" TV
I have a 13' Orion tv, model #TV1326BW with rabbit ear antenna. I have connected everything correctly to the converter box for digital signals. I can pick up all stations except the local CBS affliciate....
I have the same TV & cannot get into the TV menu to program the cable... it was bought secondhand without the original remote. There are no buttons anywhere on the TV itself to bring up the menu & the universal remote's menu option doesn't do it, either... how do I set the channels?
Aug 04, 2009 | Televison & Video
Samsung DVD-VR 375 records but sometimes I get only sound
Some program have copy protection or your installations cable and setup try to set lower resolutions and make sure you see the picture on TV before record
Or tell me how are your installation from which device to where
I may able to help you
Cheers
Dec 09, 2008 | Samsung DVD-VR375 DVD Recorder/VCR
Cannot get local channels back after dropping cable.
Are you positive that your city has not done the Digital Conversion? Some Cities are doing it early before the February deadline. Also make sure you are tuning in to the correct channels. Meaning that if on your Cable Provider ABC was on Channel 3 that does not mean that ABC with still be on Channel 3 after you have your Cable turned off. Most of the Time the Local Stations Tag will let you know what channel its on. It will be something like "KWAS ABC 27" So on your TV you would Tune it to channel 27 to get ABC and the same fore NBC , FOX, CBS , etc...
I hope this helps Take Care =)
Dec 07, 2008 | Televison & Video
Direct TV DVR Recording Problem
call tech support & ask them to hit your box to reset it, in the meanwhile unplug it for 15 seconds
Apr 22, 2008 | Directv (R10) DTV Receiver / 70-Hours...
Tv thinks its a HD tv
Tell me the problem in laymen's terms, please...accordianman
Feb 15, 2008 | Apex Digital AT2702 27" TV
Philips Magnavox DVD/VCR Dual Player Logo
795 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
